    Backup to local NAS
    Duet Web Control
    625
    • tecnoundefined
      tecno
      How can I do this, want to backup my sys and the SD card as separate backups to my local NAS.
      fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @tecno
        @tecno said in Backup to local NAS:
        I just enable FTP on the Duet board and use just about any FTP client to download/upload files as needed.
          There's also this https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor
          Which you could probably automate if you were so inclined.
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @Phaedrux
            @phaedrux
            Hmmm, how to I get this working? Where to install?
              It's a command line tool, so installation is simply extracting it somewhere. To use it, you'd probably want to create a batch file that calls the executable with the parameters you want to use. The usage is described in that link. To automate it you could use your OS task scheduler to call it on a schedule.
              • tecnoundefined
                tecno @Phaedrux
                @phaedrux
                OK, thanks. No easy tool for me. I was envisioning something within RRF to do this.
                • fcwiltundefined
                  fcwilt @tecno
                  Well you can select files within the DWC and download them as one ZIP file.
                  • tecnoundefined
                    tecno @fcwilt
                    @fcwilt said in Backup to local NAS:
                    Yes that I know but I can not point to where to save the file, or can I ?
                      Yes it should offer to save the file somewhere on your computer as it would for any other download.
                      • tecnoundefined
                        tecno @Phaedrux
                        @phaedrux said in Backup to local NAS:
                        Nothing I can change so now it saves in downloads, not so good as it forces one to move the file to the NAS where I want it to be.
                          Phaedrux Moderator @tecno
                          That's probably configurable in your browser.
                          • tecnoundefined
                            tecno @Phaedrux
                            @phaedrux
                            I can not find anything to change the path for these *.zip files to be saved at.
                            Phaedruxundefined zaptaundefined 3 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @tecno
                              Well perhaps you would be happier with a backup program that supported FTP connections.
                              Most backup programs I have used allow scheduling backups and versioning of backups.
                                @phaedrux
                                I suspect that your browser is configured to download immediately to the downloads folder rather than asking you each time. Check your browser settings. However that setting would then apply to all cases, so you might find that more frustrating if it's constantly asking you where to download something.
                                • zaptaundefined
                                  zapta @tecno
                                  This post is deleted!
                                  • zaptaundefined
                                    zapta @tecno
                                    @tecno, if you are using Chrome, looks at Settings | Advance | Downloads.
                                      deckingman @tecno
                                      Another option is to use a different strategy. What I do is maintain a folder which mirrors the SD card on a PC and only ever upload files to the SD card from there. This folder is backed up (synchronised) to my NAS and also cloud storage in the form of Google drive. So I never make any changes or add anything directly to the SD card - only ever upload from a PC. This way, I always have copies of the contents of the SD card, on my PC, my NAS and on remote storage.
                                      tecnoundefined 1 Reply Last reply Reply Quote 2
                                      • tecnoundefined
                                        tecno @deckingman
                                        @deckingman
                                        Sounds like a very good solution. How do I mirror the SD card?
                                        deckingmanundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                                          deckingman @tecno
                                          @deckingman
                                          Numerous ways of doing it. It's been so long ago that I did it I can't remember exactly. IIRC, what I did was create a folder and give it a name e.g, "PrinterSDCard", then put the SD card in my PC and copied the entire contents to that folder - including any subfolders and of course the files therein. As I said, that's a one off process because thereafter, if ever I need to make any changes, I make them to the contents of that PC based folder and then upload them to the SD card.
                                          • Dougal1957undefined
                                            Dougal1957 @tecno
                                            @deckingman
                                            You could configure the duet to allow FTP then just FTP all the contents back to your PC (Most FTP Packages allow a sync as well).
