    Backup to local NAS
    Duet Web Control
    625
      There's also this https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor
      Which you could probably automate if you were so inclined.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @Phaedrux
        @phaedrux
        Hmmm, how to I get this working? Where to install?
          It's a command line tool, so installation is simply extracting it somewhere. To use it, you'd probably want to create a batch file that calls the executable with the parameters you want to use. The usage is described in that link. To automate it you could use your OS task scheduler to call it on a schedule.
          • tecnoundefined
            tecno @Phaedrux
            @phaedrux
            OK, thanks. No easy tool for me. I was envisioning something within RRF to do this.
            • fcwiltundefined
              fcwilt @tecno
              @tecno said in Backup to local NAS:
              Well you can select files within the DWC and download them as one ZIP file.
              • tecnoundefined
                tecno @fcwilt
                @fcwilt said in Backup to local NAS:
                Yes that I know but I can not point to where to save the file, or can I ?
                  Yes it should offer to save the file somewhere on your computer as it would for any other download.
                  • tecnoundefined
                    tecno @Phaedrux
                    @phaedrux said in Backup to local NAS:
                    Nothing I can change so now it saves in downloads, not so good as it forces one to move the file to the NAS where I want it to be.
                      Phaedrux Moderator @tecno
                      That's probably configurable in your browser.
                      • tecnoundefined
                        tecno @Phaedrux
                        @phaedrux
                        I can not find anything to change the path for these *.zip files to be saved at.
                        Phaedruxundefined zaptaundefined 3 Replies Last reply Reply Quote 0
                        • fcwiltundefined
                          fcwilt @tecno
                          Well perhaps you would be happier with a backup program that supported FTP connections.
                          Most backup programs I have used allow scheduling backups and versioning of backups.
                            @phaedrux
                            I suspect that your browser is configured to download immediately to the downloads folder rather than asking you each time. Check your browser settings. However that setting would then apply to all cases, so you might find that more frustrating if it's constantly asking you where to download something.
                            • zaptaundefined
                              zapta @tecno
                              This post is deleted!
                              • zaptaundefined
                                zapta @tecno
                                @tecno, if you are using Chrome, looks at Settings | Advance | Downloads.
                                  deckingman @tecno
                                  How can I do this, want to backup my sys and the SD card as separate backups to my local NAS.
                                  Another option is to use a different strategy. What I do is maintain a folder which mirrors the SD card on a PC and only ever upload files to the SD card from there. This folder is backed up (synchronised) to my NAS and also cloud storage in the form of Google drive. So I never make any changes or add anything directly to the SD card - only ever upload from a PC. This way, I always have copies of the contents of the SD card, on my PC, my NAS and on remote storage.
                                  tecnoundefined 1 Reply Last reply Reply Quote 2
                                  • tecnoundefined
                                    tecno @deckingman
                                    @deckingman
                                    Sounds like a very good solution. How do I mirror the SD card?
                                    deckingmanundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                                      deckingman @tecno
                                      @deckingman
                                      Numerous ways of doing it. It's been so long ago that I did it I can't remember exactly. IIRC, what I did was create a folder and give it a name e.g, "PrinterSDCard", then put the SD card in my PC and copied the entire contents to that folder - including any subfolders and of course the files therein. As I said, that's a one off process because thereafter, if ever I need to make any changes, I make them to the contents of that PC based folder and then upload them to the SD card.
                                      • Dougal1957undefined
                                        Dougal1957 @tecno
                                        @deckingman
                                        You could configure the duet to allow FTP then just FTP all the contents back to your PC (Most FTP Packages allow a sync as well).
