    230v heatbed thermal runaway
    821
    • Poul Erikundefined
      Poul Erik @T3P3Tony
      @t3p3tony
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
        T3P3Tony administrators @Poul Erik
        @poul-erik ahh ok that makes more sense.
        And how is the SSR wired?
        If you start up the Duet does the bed begin heating immediately or only when you set the temperature?
        Poul Erikundefined 3 Replies Last reply Reply Quote 0
          Poul Erik @T3P3Tony
          @t3p3tony
          Yes, it starts heating rightaway.
            Poul Erik @T3P3Tony
            @t3p3tony
            i would have to take the printer apart to answer how the it is wired.
              Poul Erik @T3P3Tony
              @t3p3tony
              Thank you Tony, I really appreciate your time.
              The wiring is pretty standard and worked until yesterday.
              I suspect you are asking for somthing other than what the image is showing! But what?
              Kind Regards
              Poul Erik
              achrnundefined 1 Reply Last reply Reply Quote 0
              • achrnundefined
                achrn @Poul Erik
                @poul-erik said in 230v heatbed thermal runaway:
                SSRs do fail, and permanently-on is the most common failure mode, which would match your symptoms (bed starts heating as soon as mains power is applied, no control over it).
                Poul Erikundefined 1 Reply Last reply Reply Quote 0
                • Gixxerfastundefined
                  Gixxerfast
                  Is the bed marked as active in the DWC?
                  Also have you measured the input of the SSR, does the LED on the SSR (if there's one) light up ?
                  Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                  Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                  Ender 3 Pro with BTT SKR-2 + RRF
                  • zaptaundefined
                    zapta @Poul Erik
                    @poul-erik , if you disconnect the driving wires between the Duet and the SSR, does the bed heats when you turn the printer on? If so, you may have shorted SSR.
                    Also, does your SSR have a led, indicating the control signal? I so, it will help you identify if the problem is on the duet/firmware side or the SSR.
                    And whatever you do, think safety first.
                    Poul Erikundefined 1 Reply Last reply Reply Quote 1
                      Poul Erik @achrn
                      @achrn
                      Thank you, much appreciated!
                        Poul Erik @Gixxerfast
                        @gixxerfast said in 230v heatbed thermal runaway:
                        HI @gixxerfast The heatbed will turn on even if the bed is not marked as active.
                        Thank you.
                        Poul Erik
                          Poul Erik @zapta
                          @zapta said in 230v heatbed thermal runaway:
                          Thank you @zapta
                          What might cause the SSR to short?
                          //pe
                          • achrnundefined
                            achrn @Poul Erik
                            SSRs are not 'bulletproof' and are more finicky than many people believe.
                            The main problem with SSRs is that most of the ones on ebay, amazon, etc. are fakes and only good for a fraction of their stated rating. Even if you have a genuine one, the rating is that for an ideal situation - no heating, no inrush current, no capacitive load etc. Admittedly, a heater element is much closer to that than many loads.
                            Personally, my rule of thumb is always use an SSR that has a rating at least twice and preferably three times what the load actually draws.
                              Poul Erik @achrn
                              Thank you @achrn
                              Your time is much appreciated.
                              I will change the SSR and see if this solves my issue.
                              //pe
                              dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                dc42 administrators @Poul Erik
                                @poul-erik I suggest you disconnect the SSR from the Duet. If the bed heater still turns on as soon as you turn the power on, then the SSR is shorted.
                                • zaptaundefined
                                  zapta @Poul Erik
                                  @poul-erik, I recommend one of the ssrs listed here https://vorondesign.com/sourcing_guide?model=V2.4, for yours mains voltage.
                                  3A sends to be on the low side.
                                  • Th0mpyundefined
                                    Th0mpy
                                    I'd also recommend looking at a physically bigger model. I have had good luck with this style, plus you can mount it on some aluminum to dissipate heat: https://www.digikey.com/en/products/detail/kacon/KMSR-DS0104/13148008 rated for 10A which should be enough.
                                    Usually the team that scores the most points wins the game.
                                    Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                                      Gixxerfast @Th0mpy
                                      @th0mpy I agree. This is the one that I use:
                                      https://www.filafarm.de/en/products/solid-state-relais-1?variant=17214068163
                                      They also have the heatsink to match.
                                      No fun burning down the house ... I have a heater mat with a built in thermostat and also an external temp fuse plus dual thermistors.
                                      • zaptaundefined
                                        zapta @Gixxerfast
                                        No fun burning down the house...
                                        A thermal fuse can be another safety measure. Nero3DP has a video on youtube demonstrating how he builds a mains bed with a silicon pad, thermal fuse, and high temp silicon adhesive. On my own printer I have two 115C thermal fuses in series. I also have a mains relay that is connected to the duet's PS ON output such that if the duet thinks something is funny, it turns off power to bed and 24V DC/DC.
                                        Keeping the house intact is very important because it protect the 3D printer from the elements.
