    Music skipping beats after firmware update (3.4.0beta6)
    28
    2.1k
    • o_lampeundefined
      o_lampe @gtaman
      @gtaman
      Downside is, that it totally blocks Daemon.g for other purposes.
      Would be cool to block it only while playing the sound.
      Any ideas? Renaming the original file and replace it with Davids two-liner and back again?
      jay_s_ukundefined gtamanundefined dc42undefined 3 Replies Last reply Reply Quote 1
        jay_s_uk @o_lampe
        @o_lampe maybe add a variable thats turned on at the beginning of the macro and then off at the end?
        o_lampeundefined 1 Reply Last reply Reply Quote 1
        • o_lampeundefined
          o_lampe @jay_s_uk
          @jay_s_uk
          Yes, replace the while true line with a real boolean variable 👍
          • gtamanundefined
            gtaman @o_lampe
            @o_lampe
            Hmm, I don't think I've used Daemon.g, so I don't even know what it does. I'll have to look more into it. Both of those ideas seem good though 🙂
            o_lampeundefined 2 Replies Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe @gtaman
              @gtaman
              It's actually the same:
              • create a global variable blockDaemon
              • set global.blockDaemon = true at the start of the M300 file
              • set global.blockDaemon = false at the end
              Then anyone using Daemon.g for real can add these lines
              while global.blockDaemon = true
                        G4 S1000
              gtamanundefined 1 Reply Last reply Reply Quote 4
              • gtamanundefined
                gtaman @o_lampe
                @o_lampe Nice! 😄 I saved it and I’ll try it out tomorrow. Heading to bed now, Have a good one! 🙂
                • o_lampeundefined
                  o_lampe @gtaman
                  @gtaman said in Music skipping beats after firmware update (3.4.0beta6):
                  I does what your imagination (and the conditional meta commands) are capable off.
                  It could run a playlist for instance
                  • DonStaufferundefined
                    DonStauffer @gtaman
                    @gtaman I noticed the same thing.
                    • jens55undefined
                      jens55 @DonStauffer
                      Anybody have a good source for a bill receptor (if that's what it is called) ? User feeds it a dollar and in turn it plays a music track. Feed it $5 and get an hour of 3D printing service (or 6 music tracks). Find a pub, arrange to locate the printer and watch the money roll in 🙂
                      Just got to figure out how to deliver the printed part to the customer in such a way that they can't mess up the process.
                      gtamanundefined 1 Reply Last reply Reply Quote 1
                      • jens55undefined
                        jens55
                        ... and if it's not obvious, add a smiley face to my last post!
                        • jens55undefined
                          jens55
                          But seriously folks, I would love to have the printer play a different jingle for all the major events that require operator attention. Unfortunately my printer is run 99% remotely so I'd never get to hear it 😞
                          engikeneerundefined 1 Reply Last reply Reply Quote 0
                          • engikeneerundefined
                            engikeneer @jens55
                            @jens55 you just need a bigger speaker 😉
                            i3 clone with a bunch of mods
                            jens55undefined 1 Reply Last reply Reply Quote 2
                            • jens55undefined
                              jens55 @engikeneer
                              @engikeneer .... I am not an engikeneer so I didn't think far enough. Wish I would have finished my degree ...
                              I am sure the neighbours will also really appreciate the sound tracks !
                              • gtamanundefined
                                gtaman @jens55
                                @jens55
                                Conveyor bed that automatically ejects prints 😄 I've seen it somewhere just not in a public machine. I think the hardest part would be reliability, but it is possible. You could also set it to cancel and kick a job out if the time runs out before the print is done xD I haven't used bill receptors because they're expensive, but I did put a coin selector in a claw machine I built 😄 It was just some generic thing from ebay and it works quite well surprisingly.
                                  dc42 administrators @o_lampe
                                  @o_lampe said in Music skipping beats after firmware update (3.4.0beta6):
                                  @gtaman
                                  @gtaman
                                  If you already have a daemon.g file that is coded as a while loop so that it never terminates under normal conditions, and it spends most of its time in G4 delay calls, then you may not have the original problem anyway. The reason that not having a daemon.g file causes interruptions to timed tasks such as playing tunes is that every 10 seconds RRF will try to open daemon.g if it is not already open; and trying to open a non-existent file on the SD card requires the whole directory to be searched, which may require several sector transfers.
                                  Of course you could also choose to have daemon.g play the tune, triggered when it sees a global variable change state.
                                  Baenwortundefined 1 Reply Last reply Reply Quote 0
                                  • Baenwortundefined
                                    Baenwort @dc42
                                    @dc42 said in Music skipping beats after firmware update (3.4.0beta6):
                                    @gtaman
                                    @gtaman
                                    Is it enough to have a blank daemon.g or does it need contents?
                                    o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    • o_lampeundefined
                                      o_lampe @Baenwort
                                      @baenwort said in Music skipping beats after firmware update (3.4.0beta6):
                                      You could add something like the below lines in your Daemon.g (empty or not) to have a controlable looptime.
                                      Set a low value when you need faster processing or higher, when you don't.
                                      while  true
                                              //do other things
                                              G4 S{global.DaemonLoopSpeed}
                                        dc42 administrators @Baenwort
                                        It need to have a loop with a delay call in the body.
                                        I have it in mind to add a new GCode command to start/stop daemon.g.
                                        DonStaufferundefined 1 Reply Last reply Reply Quote 1
                                        • nikschaundefined
                                          nikscha @gtaman
                                          @gtaman would you mind sharing your gcode music collection?
                                          Stay in school
                                          gtamanundefined 1 Reply Last reply Reply Quote 0
                                          • gtamanundefined
                                            gtaman @nikscha
                                            @nikscha
                                            Here is my favourite in the code text below. I just found it, and i've been imagining it for weeks I tell you, WEEKS! Its the commodore 64 tribute from GTA Vice city. I think I'm going to use this for my main sound. Also, this thread had a bunch I shared earlier:
                                            https://forum.duet3d.com/topic/26269/sound-for-duet?_=1639741054776
                                            Also Don't be scared to make your own:
                                            https://alexyu132.github.io/midi-m300/ -tool
                                            https://www.vgmusic.com -midi music
                                            https://bitmidi.com/ -midi music
                                            There are Mp3 to midi converters too, but i havent found a good one
                                            code_text
                                            M300 P161 S370
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P161 S370
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P161 S370
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P163 S330
                                            G4 P163
                                            M300 P163 S370
                                            G4 P163
                                            M300 P163 S440
                                            G4 P163
                                            M300 P161 S370
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P163 S330
                                            G4 P163
                                            M300 P487 S370
                                            G4 P487
                                            M300 P166 S0
                                            G4 P166
                                            M300 P161 S294
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P161 S294
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P163 S294
                                            G4 P163
                                            M300 P161 S277
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P161 S277
                                            G4 P161
                                            M300 P166 S0
                                            G4 P166
                                            M300 P163 S277
                                            G4 P163
                                            M300 P327 S330
                                            G4 P327
                                            M300 P327 S349
                                            G4 P327
                                            M300 P1000 S370
                                            G4 P654
