    seeing if i can get assistance with bed connectins
    1.5k
    • frnknstnundefined
      frnknstn @alankilian
      @alankilian ```
      M550 P"duet3" ; Set machine name
      M552 S1 ; Enable network
      ;*** Access point is configured manually via M587
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M575 P1 S1 B57600 ; Panel Due
      ; Printer geometry
      M669 K1 ; Select CoreXY mode
      M208 X0:330 Y0:285.75 Z0:350 ; Axis Limits
      M564 H0 ; allow unhomed movement
      ;------- drives from top---------------------------------------------------
      ; B -------+------ A
      ; | P.02 | P.03 |
      ; -------+------- Z-Drives
      ; | P0.1 | P0.4 |
      ; Front
      ; Drive Mappings
      M569 P0.0 S1 V0 ; Drive 0: E Axis
      M569 P0.1 S1 V0 ; Drive 1: Z-LeftFront Axis
      M569 P0.2 S0 V0 ; Drive 2: Z-LeftRear Axis
      M569 P0.3 S1 V0 ; Drive 3: Z-RightRear Axis
      M569 P0.4 S0 V0 ; Drive 4: Z-RightFront Axis
      M569 P1.0 S1 V0 ; Drive 5: Expansion: B motor (X-axis)
      M569 P1.1 S1 V0 ; Drive 6: Expansion: A motor (Y-axis)
      ; Motor remapping for dual Z and axis Limits
      M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0 ; Motor mapping
      M671 X-76.2:-76.2:406.4:406.4 Y0:374.65:374.65:0 S20 ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front
      ; Microstepping and Speed
      M350 X32 Y32 E16 Z16 I1 ; Configure microstepping with interpolation
      M92 X200.00 Y200.00 Z200.00 E400.00 ; Set steps per mm 1.8 motors
      ; Speeds, Acceleration and Jerk
      M566 X400.00 Y400.00 Z25.00 E600.00 P1 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; Set accelerations (mm/s^2)
      ; Motor currents
      M906 X1200.00 Y1200.00 Z1200.00 E700.00 I60 ; Set motor currents (mA) and motor idle factor in percent
      M84 S600 ; Set idle timeout
      ; Endstops for each Axis
      M574 X2 S1 P"io0.in" ; Set X endstop controlled by switch
      M574 Y2 S1 P"io1.in" ; Set Y endstop controlled by switch
      M558 P8 C"io3.in" H5 F120 T60000 ; set Z probe type to unmodulated and the dive height + speeds
      ; Stallgaurd Sensitivy (maybe use to pause print after crash)
      M915 X S2 F0 H200 R0 ; Set X axis Sensitivity 1.8 motors
      M915 Y S2 F0 H200 R0 ; Set y axis Sensitivity 1.8 motors
      ; Z Probe Offset (Probe behind Afterburner)
      G31 P500 X0 Y0 Z1.5
      M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 B0 R0.593 C389.7 D3.93 S1.00 V0 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M307 H1 B0 R1.680 C233.0:193.0 D6.75 S1.00 V23.7 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
      M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 T45 H1 ; set fan 1 value. Thermostatic control disabled
      ; Fans Electronic compartment & Exhaust
      ;M950 F1 C"out3" Q100 ; Creates Case Fan 1
      ;M106 P1 T40 S150 H0 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed
      ;M950 F2 C"out4" Q100 ; Creates Case Fan 2
      ;M106 P2 T40 S150 H0 ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed
      ;M950 F5 C"out7" Q100 ; Creates Case Fan 2
      ;M106 P5 T95 S50 H0 ; Exhaust fan
      ; Filament Runout sensor
      ;M950 J4 C"io5.in" ; Input 4 filament sensor
      ;M581 P4 T2 S1 R1 ; Filament Sensor P4 triggers inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1)
      ;M591 D0 P1 C"io5.in" S1 ; Filament Sensor
      ;M563 P0 D0 H1 F0 ; Define tool 0
      ;G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets
      ;G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
      frnknstnundefined 1 Reply Last reply Reply Quote 0
      • frnknstnundefined
        frnknstn @frnknstn
        @frnknstn as of right now i get a fault for the bed not heating up. Sorry im new at this and i am really trying to learn this stuff. I am also trying to figure out the tool show bed and bed heater. Where would i change my settings to add the nozzle to that. or do i even need them in the tools. thank you
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        • Gixxerfastundefined
          Gixxerfast @frnknstn
          @frnknstn The bed heater mat doesn't have polarity. It's just a big resistor.
          The fault you're getting. Is it the normal one where it's not heating up fast enough? If so, you just have to do a pid calibrate for the bed heater: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
          Ender 3 Pro with BTT SKR-2 + RRF
          • frnknstnundefined
            frnknstn @Gixxerfast
            @gixxerfast yes sir. it says its taking to long. Heating up at .02.
            ill look into this thank you
            • frnknstnundefined
              frnknstn @frnknstn
              @frnknstn i had to stop the tunes. My fans are not coming on
              • zaptaundefined
                zapta @frnknstn
                @frnknstn, do you know the power specifications (in watts or amps) of your bed heater and 24V power supply? You need to make sure the power supply can provide power to the bed, motors, nozzle, fans, electronics, etc.
                https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
                • alankilianundefined
                  alankilian @zapta
                  Your config shows bed on OUT0 and extruder on OUT1
                  But you say:
                  i ran the bed to out1 and ran 24 volts to the out1 in
                  Can you describe your connections using the names in the Duet3 wiring diagram image here so we know what you mean by out1 in?
                  Maybe also post an image of the board and wiring so we can see the jumper settings.
                  • frnknstnundefined
                    @alankilian ```
                    M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                    M950 H0 C"out_0" T0 ; create bed heater output on out0 and map it to sensor 0
                    M307 H1 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode
                    M308 S1 P"temp_1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                    M950 H1 C"out_1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                    • frnknstnundefined
                      frnknstn @frnknstn
                      @frnknstn so i have my heat straightened out almost.. i started tuning but i cant get the fans to go. ill send a pic of my board
                        alankilian @frnknstn
                        @frnknstn
                        Shouldn't that M307 be H0?
                        • frnknstnundefined
                          @alankilian i will see. the bed heats up and the extruder heats up. i will see what happens
                          • frnknstnundefined
                            frnknstn @frnknstn
                            ![alt text](5c5a624c-dc72-419c-9680-1fa78142d786-Screenshot (2).png image url)
                            I changed it and it actually seperated the bed and extruder into 2 seperate tools
                            • frnknstnundefined
                              frnknstn @frnknstn
                              @frnknstn now im just trying to get these fans going
                                Looks pretty much like mine:
                                • frnknstnundefined
                                  @alankilian i still have to do z probe and fans. then bed leveling. paused on probe was getting frustrated. So i have been messing with heaters. Now im trying to figure out fans on extruder and parts cooler
                                  • frnknstnundefined
                                    frnknstn @frnknstn
                                    @frnknstn so on my extruder fan, should i just run that always on by the power strip, i am running 24v fans throughout
                                      @frnknstn Not all 24V fans can be PWM:ed Do you have more than two wire fans? Can you show how you connected them ?
                                      Have you set the jumper to V_fused for 24V ?
                                      • frnknstnundefined
                                        @gixxerfast these are all 2 wire, i switched the jumper from 12v to VIN, both fans are coming out of out7 and out8. if i need to get different fans i can
                                        frnknstnundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                                        • frnknstnundefined
                                          frnknstn @frnknstn
                                          @frnknstn said in seeing if i can get assistance with bed connectins:
                                          ill see if i can get a pic
                                            @frnknstn
                                            No, they should work fine. At out7 (hotend fan) should start when T1 reaches 45C. YOu should be able to manually control out8 (part cooling) in the DWC dashboard. Have you tried?
                                            They are both two pin connectors so as long as you haven't rotated the wires you can't go wrong there
