    seeing if i can get assistance with bed connectins
    1.5k
    • frnknstnundefined
      frnknstn @Gixxerfast
      @gixxerfast yes sir. it says its taking to long. Heating up at .02.
      ill look into this thank you
      frnknstnundefined 1 Reply Last reply Reply Quote 0
      • frnknstnundefined
        frnknstn @frnknstn
        @frnknstn i had to stop the tunes. My fans are not coming on
        • zaptaundefined
          zapta @frnknstn
          @frnknstn, do you know the power specifications (in watts or amps) of your bed heater and 24V power supply? You need to make sure the power supply can provide power to the bed, motors, nozzle, fans, electronics, etc.
          https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
          • alankilianundefined
            alankilian @zapta
            Your config shows bed on OUT0 and extruder on OUT1
            But you say:
            i ran the bed to out1 and ran 24 volts to the out1 in
            Can you describe your connections using the names in the Duet3 wiring diagram image here so we know what you mean by out1 in?
            Maybe also post an image of the board and wiring so we can see the jumper settings.
            • frnknstnundefined
              frnknstn @alankilian
              @alankilian ```
              M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out_0" T0 ; create bed heater output on out0 and map it to sensor 0
              M307 H1 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode
              M308 S1 P"temp_1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out_1" T1 ; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B0 R1.680 C233.0:193.0 D6.75 S1.00 V23.7 ; disable bang-bang mode for heater and set PWM limit
              • frnknstnundefined
                frnknstn @frnknstn
                @frnknstn so i have my heat straightened out almost.. i started tuning but i cant get the fans to go. ill send a pic of my board
                  alankilian @frnknstn
                  @frnknstn
                  Shouldn't that M307 be H0?
                  • frnknstnundefined
                    @alankilian i will see. the bed heats up and the extruder heats up. i will see what happens
                    • frnknstnundefined
                      frnknstn @frnknstn
                      ![alt text](5c5a624c-dc72-419c-9680-1fa78142d786-Screenshot (2).png image url)
                      I changed it and it actually seperated the bed and extruder into 2 seperate tools
                      • frnknstnundefined
                        frnknstn @frnknstn
                        @frnknstn now im just trying to get these fans going
                          Looks pretty much like mine:
                          • frnknstnundefined
                            @alankilian i still have to do z probe and fans. then bed leveling. paused on probe was getting frustrated. So i have been messing with heaters. Now im trying to figure out fans on extruder and parts cooler
                            • frnknstnundefined
                              frnknstn @frnknstn
                              @frnknstn so on my extruder fan, should i just run that always on by the power strip, i am running 24v fans throughout
                              Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                              • Gixxerfastundefined
                                Gixxerfast @frnknstn
                                @frnknstn Not all 24V fans can be PWM:ed Do you have more than two wire fans? Can you show how you connected them ?
                                Have you set the jumper to V_fused for 24V ?
                                Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                                Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                                Ender 3 Pro with BTT SKR-2 + RRF
                                • frnknstnundefined
                                  @gixxerfast these are all 2 wire, i switched the jumper from 12v to VIN, both fans are coming out of out7 and out8. if i need to get different fans i can
                                  frnknstnundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                                  • frnknstnundefined
                                    frnknstn @frnknstn
                                    @frnknstn said in seeing if i can get assistance with bed connectins:
                                    ill see if i can get a pic
                                      @frnknstn
                                      No, they should work fine. At out7 (hotend fan) should start when T1 reaches 45C. YOu should be able to manually control out8 (part cooling) in the DWC dashboard. Have you tried?
                                      They are both two pin connectors so as long as you haven't rotated the wires you can't go wrong there
                                      • frnknstnundefined
                                        @gixxerfast i have no fans under fan selection. thats where i assumed they would show up
                                        • frnknstnundefined
                                          frnknstn @frnknstn
                                          @frnknstn ill double check and make sure i have the wires correct
                                            @frnknstn That is strange, not even the tool fan? ... Is your config still as listed above ?
                                            Try a M98 P"0:/sys/config.g" and check the console
