    after print part orientation change
    911
    • patelundefined
      patel
      This post is deleted!
      • patelundefined
        patel @HebigT
        @hebigt
        I try before changing S0 to S1 but nothing change
        When I move X and y axis moving right direction
        But printing times I don’t know why changing
        • oliofundefined
          oliof
          Looks like you are using Simplify3D which has "Flip Build Table Axis" enabled by default for Y:
          Try disabling that maybe?
          patelundefined 1 Reply Last reply Reply Quote 2
          • patelundefined
            patel @oliof
            @oliof
            thank you for suggestion. i try right know. is the same . did not change
            • oliofundefined
              oliof
              if you conduct moves via Duet Web Control, do the axes move in the right direction?
              patelundefined 1 Reply Last reply Reply Quote 0
              • patelundefined
                patel @oliof
                @oliof x axis i set g92 x250 and y axis i set g92 y280. when i try to move Duet Web control i need you - side
                example i need to move x20 than i need to press x-230 then i reach x20.
                  Phaedrux Moderator @patel
                  @patel said in after print part orientation change:
                  M208 X0 Y0 Z0.0 S0 ; Set axis minima
                  M208 X260 Y280 Z215.80 S1 ; Set axis maxima
                  Your M208 S values are reversed.
                  S0 = set axis maximum, 1 = set axis minimum
                  • patelundefined
                    patel @Phaedrux
                    @phaedrux Thank you for reply
                    I made corrections but still results is the same
                    • rjenkinsgbundefined
                      rjenkinsgb
                      I believe it is a setting within the slicer:
                      From the initial images, the parts are mirrored within themselves - but the part positions are not exchanged along the same axis, which they would be if it were in any way related to printer movement.
                      I cannot see how it can be anything but some form of mirror setting within the slicer - possibly done during an early setup, trying to compensate a reversed axis in the printer??
                      Robert J.
                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                        Phaedrux Moderator @rjenkinsgb
                        @rjenkinsgb said in after print part orientation change:
                        Maybe. I don't think the photo shows the parts on the build surface though. Perhaps they were exchanged?
                          Can you post your homing files as well please?
                          Can you confirm for me a few details?
                          Where are your endstops located? Photo?
                          When looking at the printer from the front, the 0,0 position should be located at the front left corner.
                          -X should move to the left, +X should move to the right, -Y should move to the front, +Y should move the back.
                          patelundefined 2 Replies Last reply Reply Quote 0
                          • patelundefined
                            patel @Phaedrux
                            @phaedrux
                            I send all data tomorrow. We have power outage today
                            Sorry for delay
                            • FrankVundefined
                              FrankV
                              As earlier mentioned, I think you have to rule out some things:
                              Is your x motor your x motor. (sending gcode)
                              Is your y motor your y motor. (sending gcode)
                              Does they rotate in the correct way. (sending gcode)
                              Does x home before y?
                              Read your gcode in another slicer (or gcode viewer) and see the result.
                              From there you can troubleshoot. Looks to me you changed x and y.
                              • patelundefined
                                patel @Phaedrux
                                ; Configuration file for Duet WiFi (firmware version 3.3)
                                ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Dec 12 2021 20:23:27 GMT-0600 (Central Standard Time)
                                G21
                                M669 K0
                                M550 P"My Printer" ; Set machine name
                                M552 S1 ; Enable network
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Disable FTP
                                M586 P2 S0 ; Disable Telnet
                                M584 X0 Y2 Z1 E3 ; set drive mapping
                                M92 X87.50 Y87.50 Z1052.20 E476.50 ; set steps per mm
                                M84 S30 ; Set idle timeout
                                M208 X260 Y280 Z215.8 S0 ; set axis maxima
                                M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
                                ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                                M308 S1 P"e0temp" Y"pt1000" ; sensor 1
                                M950 H1 C"e0heat" T1 ; create heater and map sensor 1
                                M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
                                HOME FILE
                                ; homex.g
                                ; called to home the X axis
                                ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Dec 15 2021 15:04:17 GMT-0600 (Central Standard Time)
                                G91 ; relative positioning
                                G1 H1 X-265 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                G1 H2 X5 F6000 ; go back a few mm
                                G1 H1 X-265 F360 ; move slowly to X axis endstop once more (second pass)
                                G1 H2 Z-5 F6000 ; lower Z again
                                G90 ; absolute positioning
                                ; homey.g
                                ; called to home the Y axis
                                G1 H1 Y-285 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                G1 H2 Y5 F6000 ; go back a few mm
                                G1 H1 Y-285 F360 ; move slowly to Y axis endstop once more (second pass)
                                ; homez.g
                                ; called to home the Z axis
                                G1 H1 Z-220.8 F1800 ; move Z down until the endstop is triggered
                                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                ;G91 ; relative positioning
                                ;G90 ; absolute positioning
                                ; homeall.g
                                ; called to home all axes
                                G1 H1 X-265 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 H2 X5 Y5 F6000 ; go back a few mm
                                G1 H1 X-265 Y-285 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                G1 H1 Z-220.8 F360 ; move Z down stopping at the endstop
                                • patelundefined
                                  patel @patel
                                  @patel
                                  M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                  M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                  M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                    @patel
                                    Which is it?
                                    Is the red dot the endstop location for both X and Y?
                                    @phaedrux said in after print part orientation change:
                                    Does it move like this?
                                    • patelundefined
                                      patel @Phaedrux
                                      @phaedrux
                                      Yes red dot end stop switch
                                      • patelundefined
                                        patel @Phaedrux
                                        @phaedrux
                                        thank you very much you fix my printer .
                                        1 week i am looking problem . lot of search google, lot of change file but what you say When looking at the printer from the front, the 0,0 position should be located at the front left corner.
                                          @phaedrux
                                          If that's the case, then then endstop definition should be X at low end (M574 X1) Y at high end (M574 Y2) and the homing moves should change to have X move negative to the left and Y move positive to the back.
                                          If those movement directions are no correct, then the motor rotation may need to change in M569. https://duet3d.dozuki.com/Wiki/M569
                                          • patelundefined
                                            patel @Phaedrux
                                            @phaedrux
                                            Know ok
                                            Thank you again for helping me
                                            • Phaedruxundefined Phaedrux has marked this topic as solved
