    Error Short to Ground reported by driver(s)
    57
    3.8k
    • davidewenundefined
      davidewen @Phaedrux
      @phaedrux
      I do. It is not setup yet, so it would be a from scratch project.
      I would want / need specific steps to do so in order to accomplish what you're thinking.
      Thanks,
      David
        Well if you setup the Pi as a desktop environment you could use the linux instructions from the getting connected guide to bypass the Mac/M1/WindowsARM/VM thing.
        Download the latest Raspberry PI OS with desktop
        https://downloads.raspberrypi.org/raspios_armhf/images/raspios_armhf-2021-11-08/2021-10-30-raspios-bullseye-armhf.zip
        Download Etcher
        https://www.balena.io/etcher/
        Burn the downloaded SD card image to an SD card with Etcher
        Setup the Pi with a mouse/keyboard/monitor and boot the burned SD card.
        Once you're up and running you can connect the Duet via USB and follow along with the getting connected guide to see if it is detected as a USB device and then hopefully connect to it via terminal.
        davidewenundefined 1 Reply Last reply Reply Quote 2
          davidewen @Phaedrux
          @phaedrux
          I finally got Windows using BootCamp to recognize the Duet on COM4.
          The name is: Duet 3 motion control electronics (COM4)
          Sorry, not ready to spend the time setting up a rPi
          I can seemingly connect to it via YAT and/or Pronterface, but neither app will actually communicate with it.
          YAT, sending M115 returns;
          "[Warning: 4 bytes not sent anymore.]
          Pronterface, attempting to connect returns;
          "Could not connect to COM4 at baud rate (tried 9600 & 11500): PermisionError(13, 'Access is denied.' None,5)
          janjohundefined 1 Reply Last reply Reply Quote 0
          • janjohundefined
            janjoh @davidewen
            @davidewen said in Error Short to Ground reported by driver(s):
            @phaedrux
            Error 13 is exactly what the message says. Your process does not have permission to access the port. Usually fixed by running whatever tool in administrative mode.
              Well if running as admin doesn't work setting up the pi isn't really too time consuming. Download and file copy take the most time. Other than that it's just plugging the hardware in.
              davidewenundefined 1 Reply Last reply Reply Quote 0
                davidewen @Phaedrux
                @phaedrux
                Ok. Running Pronterface as admin allowed me to connect. YAT still does not work even with admin privileges.
                I can not get Wi-Fi to work.
                Here's the output from Pronterface
                Connecting...
                Printer is now online.
                >>> M115
                SENDING:M115
                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-06-15 21:46:20
                >>> M552
                SENDING:M552
                WiFi module is disabled
                >>> M552 S0
                SENDING:M552 S0
                WiFi module started
                >>> M552
                SENDING:M552
                WiFi module is idle
                >>> M587 S"----" P"----"
                SENDING:M587 S"----" P"----"
                Error: M587: Failed to add SSID to remembered list: SPI timeout
                  Please try sending M997 S1 to reflash the wifi module firmware and then see what happens when you try to connect to a wifi network.
                    davidewen @Phaedrux
                    @phaedrux
                    That did the trick.
                    Thanks for your help.
                    • Phaedruxundefined Phaedrux has marked this topic as solved
                      Glad we got it going.
                        davidewen
                        I'm just reporting that after less than 30 days of use, this board no longer works. This is board #2 with defects. Board #1 had Driver 3 go bad. Board #2 just won't connect. So I partially disassembled my printer in order to connect a USB cable and attempt the above procedures. This time it is not recognized by either macOS or Windows as even being plugged in. It did not show up in System Info (macOS) or Device Manager (Windows).
                        I'm not going to spend anymore of my time on this forum attempting to trouble shoot Duet's poor quality issues.
                        The board was purchased through Filastruder. I'm expecting them and Duet to step up to the plate and provide quality service and take care of the issue.
                          Sorry to hear you've had some trouble with your replacement board. When you say it no longer works, what exactly works or doesn't work?
                            davidewen @Phaedrux
                            @phaedrux
                            Thanks for you concern.
                            It just won't connect in any way.
                            Wi-Fi doesn't connect nor via usb on Windows or Mac.
                            I've attempted multiple resets because eventually that is how I got it to connect via usb when I 1st got this board.
                            • dc42undefined dc42 has marked this topic as unsolved
                              Does the blue LED on the wifi module illuminate at all when powered on?
                              What LEDs are lit on the board itself?
                              Do any of the components get hot to the touch after being powered for a short time?
                              It's quite unusual for a board to go completely dead like that. Let alone have troubles two in a row. I understand that you've gone through some trouble getting it to work previously along with getting the replacement working, so I understand if you don't wish to go through any more hoops. So if you don't wish to go through any more trouble shooting and would prefer a warranty replacement that is an option, though it would still help to understand what has failed.
                                davidewen @Phaedrux
                                @phaedrux
                                I don't mind helping you understand what went wrong.
                                Here's the status of each LED (see photo)
                                NOTE: the STATUS LED is flashing red slowly.
                                This is connected via USB to my mac mini M1, but not recognized by macOS
                                I have also attempted to connect it to a MacBook Pro 2017 and on both machines via Parallels to a Windows 11 and Windows 10 virtual machine. Win11 on mac mini, Windows 10 on MB Pro.
                                There is no recognition of the board on any machine.
                                  The status light flashing indicates the firmware has been wiped.
                                  With the previous board I think you had gotten it to show up on the Mac with bootcamp? I suppose that isn't working this time?
                                  davidewenundefined Falkiaundefined 2 Replies Last reply Reply Quote 0
                                    davidewen @Phaedrux
                                    @phaedrux said in Error Short to Ground reported by driver(s):
                                    That is correct. Sorry, I said the MB Pro was via Parallels, it's actually BootCamp.
                                    I have attempted to "reset" the board multiple times. It eventually worked the first go-around, but it's not working this time.
                                    • Falkiaundefined
                                      Falkia @Phaedrux
                                      @phaedrux just one thought, could the communication be interfered by ground loop?
                                      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
                                        Phaedrux Moderator @Falkia
                                        @falkia only in some cases https://duet3d.dozuki.com/Wiki/USB_ground_loops
                                          Phaedrux Moderator @davidewen
                                          @davidewen as last time...
                                          Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                          Sorry for the inconvenience.
                                          For the new board it would be a good idea to test the usb terminal connection right away to establish that it works reliably with one of your computers.
                                            davidewen @Phaedrux
                                            Got board #3.
                                            Opened box, attached Wi-Fi antennae, attached supplied USB cable, powered up.
                                            Not recognized by macOS.
                                            Status of LEDs.
                                            STATUS = slow flashing red
                                            5v = solid red
                                            3.3v = solid green
                                            ESP = solid green
                                            Powered on & off multiple times. None of the attempts resulted in recognition by macOS.
                                            Moved from mac mini M1 computer to Mac Book Pro w/Intel.
                                            Same results as mac mini.
                                            Connected via Boot Camp
                                            Same results
                                            If I understand correctly, the slow flashing STATUS LED indicates no firmware?
                                            So, I attempted a 2x fast click of the RESET button.
                                            STATUS LED quickly flashes. ESP LED goes off.
                                            After 10 minutes, nothing happened so I 1x clicked the RESET button and board returned to status above.
