    Anybody wants a stepper motor analyzer?
    281
    34.1k
    • Dogma2kundefined
      Dogma2k @zapta
      @zapta
      Unfortunately only provisionally because I don't have my 5V transformer an Arduino Uno yet
      • Dogma2kundefined
        Dogma2k
        @zapta
        Can the analyzer be switched on and off during operation? Because you can / should only disconnect the motors without electrical voltage. Or does it matter here because the input and output always have continuity and the measurements are only picked up in parallel?
        • zaptaundefined
          zapta @Dogma2k
          @dogma2k, the electronics and the stepper circuit are isolated from each other so it's safe to turn 5V power on/off even when the printer is working. It will not damage the electronic and the print will continue with no interruption.
          • Dogma2kundefined
            Dogma2k
            The analyzer is finally running after I had to remove the display again because the soldering points of the connector had pushed through the metal frame of the display and always caused a short circuit
            Thanks for the nice toy 😉
            zaptaundefined 2 Replies Last reply Reply Quote 0
            • zaptaundefined
              zapta @Dogma2k
              @dogma2k said in Anybody wants a stepper motor analyzer?:
              Wow! Looks awesome. I am glad that this didn't cause a permanent damage. I maintain the insulation by
              1. Using an insulated 10mm width double tape on the back of the PCB, at the marked areas. E.g. https://www.amazon.com/Adhesive-10mmx25mx0-25mm-Thermally-Conductive-Computer/dp/B075FRPXQ5 . I also apply it between the PCB and the PICO, just in case.
              2. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
              BTW, it should be ok to connect multiple analyzers to the same servo since the sensors serial resistance is very low.
              Dogma2kundefined 1 Reply Last reply Reply Quote 0
              • zaptaundefined
                zapta @Dogma2k
                @dogma2k, the current readings seem have have offset. You may want to reset it in the Settings screen with the motor disconnected (that is, zero current).
                • Dogma2kundefined
                  Dogma2k @zapta
                  @zapta said in Anybody wants a stepper motor analyzer?:
                  I had double-sided tape in between. Wasn't enough
                  https://www.amazon.de/gp/product/B08YJK6L1T/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
                  It didn't matter, it went well, it was just fun to find the fault ...
                  1. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                  That would probably have been the best had I done that
                  Even more? I already need 4 pieces because I have 2x X steppers and 2x Y steppers.
                  The small OLED is also not yet in operation for the filament flow meter, because I haven't had time to get the Arduino UNO ready
                  I still have a problem that as soon as the motors are working, the display does not react at all or almost not at all.
                  If the motors are switched off with M84 then you can use the display properly.
                  How come that
                  Analyzer_standby.mp4
                  Analyzer_aktion.mp4
                  • zaptaundefined
                    zapta @Dogma2k
                    Can you explain what what you mean? Chan you change pages? Do you see any reading on the main page?
                    Per my previous post, it seems that your sensors need zero calibration. This is done in the Settings page (accessible from the main page) with the motor disconnected.
                    • Dogma2kundefined
                      Dogma2k @zapta
                      Would you have to recognize property in the two videos what I mean (if not, I'll make better ones)
                      If no stepper has been used, I can switch through the menus, as soon as the stepper has moved once, the displays can no longer be operated.
                      I'll do the zeroing with disconnected stepper afterwards when I'm back.
                      Th0mpyundefined 1 Reply Last reply Reply Quote 0
                      • Th0mpyundefined
                        Th0mpy @Dogma2k
                        @dogma2k I had this issue on my first analyzer I boiled it down to a couple things.
                        As @zapta mentions, if you don't cut the pins there may just enough bite into the back of the LCD which shorts things out. I pulled the connectors out, recut, and used some 3M VHB to secure the LCDs.
                        Finally, double check the castellated pins on the PICO and make sure they're solid. If you used a thicker adhesive behind the PICO it might prevent good connections.
                        Usually the team that scores the most points wins the game.
                        • Dogma2kundefined
                          Dogma2k @Th0mpy
                          @th0mpy said in Anybody wants a stepper motor analyzer?:
                          How can you reduce the choice, I really don't have a clue about it yet.
                          I took the APPLICATION.uf2 file from the temp directory on github, was it wrong?
                          Now the analyzers just don't run properly when the steppers are moving.
                          So it is more as if the Pico does not have enough power to process the incoming data quickly enough
                          • zaptaundefined
                            zapta @Dogma2k
                            @dogma2k ,
                            1. Do you have the same problem on all four analyzer or just a few?
                            2. If you power the analyzers from a power supply on your printer, I suggest, as an experiment, to power one of them from a regular USB 5V charger and see if the problem persists.
                              A Former User
                              Hey
                              Is it possible to indicate layer shifts with this analyser?
                              Richard
                              • zaptaundefined
                                zapta @A Former User
                                @gruna-studio, that a good question. I guess it depends on the cause. E.g.
                                Intermittent wiring connection - It detects idling and electrical stepping error events so will probably detect.
                                Low current/torque due to an high speed - it will probably diagnose it in the current vs speed histogram page.
                                Mechanical binding - I am not sure about that. May need to research how that condition is reflected on the electrical signals. Also, the analyzer measures only current, monitoring also the stepper voltage may help here.
                                • Dogma2kundefined
                                  Dogma2k @zapta
                                  @dogma2k ,
                                  Yes all four analyzer have the same problem.
                                  1. If you power the analyzers from a power supply on your printer, I suggest, as an experiment, to power one of them from a regular USB 5V charger and see if the problem persists.
                                  I'll try, but don't have much hope because I've already built a 24V / DC to 5V / DC power supply into the case
                                  Or could it be because of the APPLICATION.uf2 file I used from the temp folder in github?
                                  • Dogma2kundefined
                                    Dogma2k
                                    @zapta and everyone else who has an idea 😉
                                    Today I had some time to deal with the problem a little more intensively.
                                    The result is that it doesn't matter how I supply the analyzer with voltage
                                    1 analyzer -> everything OK (if stepper on or off)
                                    2 Analyzer -> everything OK (if stepper on or off)
                                    3 Analyzer -> if the stepper is off then everything is OK, if the stepper is on it does not immediately become sluggish but after approx. 10 seconds all of them are no longer really operable
                                    4 Analyzer -> if the stepper is off then everything is OK, when the stepper is on it is immediately sluggish and inoperable
                                    The combination of which analyzers are used together does not matter, it always gets the above result
                                    When I use two different voltage sources, the above result counts.
                                    Are there any influences that can arise if more than 2 are switched on at the same time. Diodes on each of the + 5V / DC wires of the Pico may
                                    zaptaundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    • zaptaundefined
                                      zapta @Dogma2k
                                      @dogma2k, that sounds bad. Everything should work.
                                      1. Did you make any hardware changes to the board?
                                      2. Are you the exact same components in the original schema?
                                      3. What TFT module are you using?
                                      4. What version of the firmware UF2 file do you use?
                                      The original schema is here
                                      https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/kicad/stepper_analyzer.pdf
                                      The original firmware is here
                                      https://github.com/zapta/simple_stepper_motor_analyzer/releases/download/F1.0.4/APPLICATION.uf2
                                      If you want, you can send me one analyzer (to the US) and I will look at it and send you back.
                                        dc42 administrators @Dogma2k
                                        @dogma2k is your PSU powerful enough to supply current to all 4 Picos and LCD screens? Colour TFT screens draw quite a lot of current.
                                        • Dogma2kundefined
                                          Dogma2k @dc42
                                          I hope so. Both PSU have 5V/DC 5A
                                          • Dogma2kundefined
                                            Dogma2k
                                            Anyone have an idea? Something like soldering a diode?
                                            It would be a shame if I had to take it all apart again because it doesn't work 😞
                                            PS it may be that an analyzer is defective (or the engine). Yes, I know I didn't zero it 😉
                                            rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
