    Anybody wants a stepper motor analyzer?
    281
    31.6k
    • Th0mpyundefined
      Th0mpy @zapta
      @zapta It seems that either 3.3v or 5v work just fine. The limits are just a little different.
      Usually the team that scores the most points wins the game.
      • zaptaundefined
        zapta @Th0mpy
        @th0mpy said in Anybody wants a stepper motor analyzer?:
        Good to know. Thanks. Yes, 3.3 will cause saturation for +/-5.75A @400mv/A but we don't need that full range, and it is specified for 3.3V for the other ranges.
        • Dogma2kundefined
          Dogma2k
          So that the prototype housing of the AWD Stepper Motor Analyzer fits quite well, just adjust a few small things.
          zaptaundefined 1 Reply Last reply Reply Quote 1
          • zaptaundefined
            zapta @Dogma2k
            @dogma2k said in Anybody wants a stepper motor analyzer?:
            Wow! That's a nice design.
            • Th0mpyundefined
              Th0mpy
              Hey everyone, I have a new batch of sensors being delivered early next week. If you're interested hit me up via chat.
              • Dogma2kundefined
                Dogma2k
                The final case is finally ready. I also installed a FlowMeter. Everything fits in and the lid even closes.
                If you like, you can download the STEP file
                https://a360.co/3sl2Kge
                • zaptaundefined
                  zapta @Dogma2k
                  @dogma2k , looks very impressive. If you can, please post here a picture with all screen on, it will be even more cool. 😉
                  Dogma2kundefined 1 Reply Last reply Reply Quote 0
                  • Dogma2kundefined
                    Dogma2k @zapta
                    @zapta
                    Unfortunately only provisionally because I don't have my 5V transformer an Arduino Uno yet
                    • Dogma2kundefined
                      Dogma2k
                      @zapta
                      Can the analyzer be switched on and off during operation? Because you can / should only disconnect the motors without electrical voltage. Or does it matter here because the input and output always have continuity and the measurements are only picked up in parallel?
                      • zaptaundefined
                        zapta @Dogma2k
                        @dogma2k, the electronics and the stepper circuit are isolated from each other so it's safe to turn 5V power on/off even when the printer is working. It will not damage the electronic and the print will continue with no interruption.
                        • Dogma2kundefined
                          Dogma2k
                          The analyzer is finally running after I had to remove the display again because the soldering points of the connector had pushed through the metal frame of the display and always caused a short circuit
                          Thanks for the nice toy 😉
                          zaptaundefined 2 Replies Last reply Reply Quote 0
                          • zaptaundefined
                            zapta @Dogma2k
                            Wow! Looks awesome. I am glad that this didn't cause a permanent damage. I maintain the insulation by
                            1. Using an insulated 10mm width double tape on the back of the PCB, at the marked areas. E.g. https://www.amazon.com/Adhesive-10mmx25mx0-25mm-Thermally-Conductive-Computer/dp/B075FRPXQ5 . I also apply it between the PCB and the PICO, just in case.
                            2. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                            BTW, it should be ok to connect multiple analyzers to the same servo since the sensors serial resistance is very low.
                            • zaptaundefined
                              zapta @Dogma2k
                              @dogma2k, the current readings seem have have offset. You may want to reset it in the Settings screen with the motor disconnected (that is, zero current).
                              • Dogma2kundefined
                                Dogma2k @zapta
                                @zapta said in Anybody wants a stepper motor analyzer?:
                                I had double-sided tape in between. Wasn't enough
                                https://www.amazon.de/gp/product/B08YJK6L1T/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
                                It didn't matter, it went well, it was just fun to find the fault ...
                                1. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                                That would probably have been the best had I done that
                                Even more? I already need 4 pieces because I have 2x X steppers and 2x Y steppers.
                                The small OLED is also not yet in operation for the filament flow meter, because I haven't had time to get the Arduino UNO ready
                                I still have a problem that as soon as the motors are working, the display does not react at all or almost not at all.
                                If the motors are switched off with M84 then you can use the display properly.
                                How come that
                                Analyzer_standby.mp4
                                Analyzer_aktion.mp4
                                • zaptaundefined
                                  zapta @Dogma2k
                                  Can you explain what what you mean? Chan you change pages? Do you see any reading on the main page?
                                  Per my previous post, it seems that your sensors need zero calibration. This is done in the Settings page (accessible from the main page) with the motor disconnected.
                                  • Dogma2kundefined
                                    Dogma2k @zapta
                                    Would you have to recognize property in the two videos what I mean (if not, I'll make better ones)
                                    If no stepper has been used, I can switch through the menus, as soon as the stepper has moved once, the displays can no longer be operated.
                                    I'll do the zeroing with disconnected stepper afterwards when I'm back.
                                    Th0mpyundefined 1 Reply Last reply Reply Quote 0
                                    • Th0mpyundefined
                                      Th0mpy @Dogma2k
                                      @dogma2k I had this issue on my first analyzer I boiled it down to a couple things.
                                      As @zapta mentions, if you don't cut the pins there may just enough bite into the back of the LCD which shorts things out. I pulled the connectors out, recut, and used some 3M VHB to secure the LCDs.
                                      Finally, double check the castellated pins on the PICO and make sure they're solid. If you used a thicker adhesive behind the PICO it might prevent good connections.
                                      • Dogma2kundefined
                                        Dogma2k @Th0mpy
                                        How can you reduce the choice, I really don't have a clue about it yet.
                                        I took the APPLICATION.uf2 file from the temp directory on github, was it wrong?
                                        Now the analyzers just don't run properly when the steppers are moving.
                                        So it is more as if the Pico does not have enough power to process the incoming data quickly enough
                                        • zaptaundefined
                                          zapta @Dogma2k
                                          @dogma2k ,
                                          1. Do you have the same problem on all four analyzer or just a few?
                                          2. If you power the analyzers from a power supply on your printer, I suggest, as an experiment, to power one of them from a regular USB 5V charger and see if the problem persists.
                                            A Former User
                                            Hey
                                            Is it possible to indicate layer shifts with this analyser?
                                            Richard
