    Circuit, PCB analysis tools
    1.7k
    • JoergS5undefined
      JoergS5
      Now having a few days for learning something new, I would be interested in analysing circuits and learning electronics. Maybe buying a reflow oven and experimenting.
      Has anyone recommendations what to use to learn about behaviour of the hardware circuits, understanding why this resistor is needed here or this capacitor is needed there an a PCB? How design a stepper driver or to design a CAN based circuit to add a sensor to Duet 3? Freeware and open source tools would be preferred to be able to change it if necessary.
      rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
      • rjenkinsgbundefined
        rjenkinsgb
        For basic electronics - resistors and capacitors etc. - have a look at the US Navy "NEETS" series:
        https://archive.org/search.php?query=subject%3A"The+Navy+Electricity+and+Electronics+Training+Series"&sort=titleSorter
        Start at module 1:
        https://archive.org/details/NEETSModule01
        If you look below the "viewer" part there are download options for PDF, EPUB or whatever format you prefer.
        Actually designing a [good] stepper driver is a fairly advanced subject.
        You can get such as the SAMMY-C21 MCU board with CAN interface etc. to build your own add-ons for the Duet system.
        Again, to start totally from scratch and with no experience is a fairly serious undertaking and you will have to do a lot of studying and research.
        Learning electronics and programming is definitely worth doing, if you have the interest, though!
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        • JoergS5undefined
          JoergS5 @rjenkinsgb
          @rjenkinsgb Thank you for the NEETS, they look promising.
          Stepper driver was only an example, I am more interested in designing sensor solutions. I will probably buy the Atmel ICE to be able to program the Sammy, next time. My question is more to get a recommendation about software tools to analyze the circuits. I tried LTSpice, but I did not like the handling very much.
          rjenkinsgbundefined zaptaundefined 2 Replies Last reply Reply Quote 0
            rjenkinsgb @JoergS5
            @joergs5
            LTSpice is the best free simulation tool I know of.
            Though to be honest the only time I ever use it it to create example circuits for other users on one of the electronics forums I visit.
            For both work and hobby stuff, I design with pencil and paper [or just in my head] then build. Nothing beats a real circuit to test things on, or find out why it does not work as expected!
            And, as the saying goes:
            In theory, theory and practice are the same.
            In practice, they are not!
            Robert J.
            • JoergS5undefined
              JoergS5 @rjenkinsgb
              @rjenkinsgb I will try Kicad, as it has a spice simulator, visualization of element changes and is open source. If someone knows a better tool, please tell me.
              JuJuDeltaundefined 1 Reply Last reply Reply Quote 0
              • JuJuDeltaundefined
                JuJuDelta @JoergS5
                http://www.spectrum-soft.com/index.shtm
                This is now free as the owner has retired and is feeling benevolent.
                It used to cost a few thousand $ and is not trivial.
                Very powerful.
                Enjoy.
                T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                JoergS5undefined 1 Reply Last reply Reply Quote 2
                • JoergS5undefined
                  JoergS5 @JuJuDelta
                  @jujudelta said in Circuit, PCB analysis tools:
                  Thank you for your hint, I'll look at Micro-Cap 12!
                  A lot of analysis possibilities, this will be fun to use! And Mosfet and IGBT models, this will be very informative to learn about them.
                  • zaptaundefined
                    zapta @JoergS5
                    @joergs5 said in Circuit, PCB analysis tools:
                    This guy has a few episodes demonstrating MicroCap. Apparently it's also free now after the developer retired.
                    https://www.youtube.com/watch?v=bjn-252Oo7A
                    If you look for a user friendly program, you may want to try this https://www.circuitlab.com/
                    • JoergS5undefined
                      JoergS5 @zapta
                      @zapta thanks for the youtube link, the gallery of voltmeters signals some electronic experience 😉
                      Thanks for the CircuitLab hint, but I don't like online tools much*), I'll stick at Micro-Cap and for PCB design KiCad seems to be interesting also.
                      *) IP is not the reason, the reason is they want my private data sooner or later.
                      BTW thanks for your stepper motor analyzer, this inspired me to develop similar Duet extensions!
                      zaptaundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @JoergS5
                        I started this morning to learn microcap, following the user manual. So far it looks very thorough and reasonable UI.
                          rjenkinsgb @JoergS5
                          For PCB design, I'd highly recommend EasyEDA, it is an exceptionally good, free, PCB program (having used quite a few different and often ludicrously expensive ones over some decades).
                          Robert J.
                          PCRundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                          • PCRundefined
                            PCR @rjenkinsgb
                            @rjenkinsgb yep. Or kicad 6.0
                            • zaptaundefined
                              zapta @rjenkinsgb
                              @rjenkinsgb, coincidently I started using EasyEDA yesterday after looking at it a few times over the years, and it improved greatly and has a more modern and intuitive UI than Kicad.
                              The OP seems to prefer local apps over web apps so may not be a good fit. Also, I am not sure how does it compare with Kicad for more complex projects, but it definitely a good choice for smaller projects and the integration with JLCPCB part library and footprints is great.
                              This is my first project, a work in progress. Most of the work is in aligning all the parts and EasyEDA makes it easier.
                              JoergS5undefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
                              • JoergS5undefined
                                JoergS5 @zapta
                                @zapta said in Circuit, PCB analysis tools:
                                this is only my personal taste, please everyone may go ahead talking about every software. Because this thread is meant to be a general discussion for all users, it may be interesting for others to use online tools, also. (And there are very good online tools like GeoGebra without registering, I use some of them).
                                I have the same problem with Micro-Cap, because it's not open source, I cannot modify it. But being so powerful, I'll proceed with it, looking at KiCad at the same time.
                                • zaptaundefined
                                  zapta @JoergS5
                                  @joergs5, it seems that EasyESA also support simulation with an easy to use GUI which is very nice https://www.youtube.com/watch?v=5eoOV1IxkIU
                                  @PCR, I see that Kicad 6 is out. Originally it was supposed to be released May 2021. 😉 I was waiting for it. Will see how difficult the transition is.
                                  BTW, all of Duet's board are designed with Kicad.
                                    rjenkinsgb @zapta
                                    There is a fully downloadable version of EasyEDA - I don't like using anything web-based for files I want to control!
                                    It can also import kicad files; I've used it to view Duet board files.
                                    I'm criticizing kicad in any sense, just being sure there are no misunderstandings re. easyeda.
                                    Robert J.
                                    • JoergS5undefined
                                      JoergS5
                                      I have a different question about which reflow oven to use, maybe someone can help me.
                                      I am thinking about buying a T-962A reflow oven and then modifying it (better temperature control, better heating). Is this a good idea or are there better options? I plan to develop small PCBs for interfaces, maybe 100x200 mm maximal, but two sides.
                                      zaptaundefined rjenkinsgbundefined dc42undefined 3 Replies Last reply Reply Quote 0
                                      • JoergS5undefined
                                        JoergS5 @rjenkinsgb
                                        @rjenkinsgb EasyEDA is a nice program. I appreciate that there are a lot of circuits of other users where I can learn from them. Micro-Cap and KiCad have their uses also.
                                        • zaptaundefined
                                          zapta @JoergS5
                                          T-962A reflow oven
                                          I used a similar over in the past, with stencils, paste, and manual vacuums component picker but gave it away. It was too much of a hassle for my use cases.
                                          Now I just solder the parts using tweezers and a fine solder iron, and with the Chinese stereo microscope I have, I can get down to 0402 components and 0.5mm pitch ICs.
                                          Another option I am using now is JLCPCB SMD service which is reasonably priced so I try to include as many components that are available at JLCPCB and then solder the rest by hand.
                                          I used to have a fancy Metcal soldering system but gave it away and now using this cheapo chineese that give me about the same results. They are so cheap that I have a few of them, each each a different tip and temperature setting. https://www.aliexpress.com/item/4000129151281.html
                                          For manual soldering, I recommend getting good flux paste such as AmTech (spelling?) and a cheap optical stereo microscope, you don't need high magnification, ~x5 works well for PCB worked. I am using this one https://www.amazon.com/gp/product/B00A15N1ZA there are many models, including ones with long boom base. The light ring is important.
                                          YMMV.
                                            rjenkinsgb @JoergS5
                                            We use normal (good) temperature controlled irons for general work, and I have a cheap ebay hot air tool that works fine for surface mount ICs, when needed.
                                            If you want complete boards, use JLCPCB - it's cheaper to have them also supply the parts and assemble the PCBs, than to buy the separate components!
                                            Robert J.
