Circuit, PCB analysis tools
For basic electronics - resistors and capacitors etc. - have a look at the US Navy "NEETS" series:
https://archive.org/search.php?query=subject%3A"The+Navy+Electricity+and+Electronics+Training+Series"&sort=titleSorterStart at module 1:
https://archive.org/details/NEETSModule01If you look below the "viewer" part there are download options for PDF, EPUB or whatever format you prefer.
Actually designing a [good] stepper driver is a fairly advanced subject.
You can get such as the SAMMY-C21 MCU board with CAN interface etc. to build your own add-ons for the Duet system.
Again, to start totally from scratch and with no experience is a fairly serious undertaking and you will have to do a lot of studying and research.
Learning electronics and programming is definitely worth doing, if you have the interest, though!
@rjenkinsgb Thank you for the NEETS, they look promising.
Stepper driver was only an example, I am more interested in designing sensor solutions. I will probably buy the Atmel ICE to be able to program the Sammy, next time. My question is more to get a recommendation about software tools to analyze the circuits. I tried LTSpice, but I did not like the handling very much.
@joergs5
LTSpice is the best free simulation tool I know of.Though to be honest the only time I ever use it it to create example circuits for other users on one of the electronics forums I visit.
For both work and hobby stuff, I design with pencil and paper [or just in my head] then build. Nothing beats a real circuit to test things on, or find out why it does not work as expected!
And, as the saying goes:
In theory, theory and practice are the same.
In practice, they are not! -
@rjenkinsgb I will try Kicad, as it has a spice simulator, visualization of element changes and is open source. If someone knows a better tool, please tell me.
http://www.spectrum-soft.com/index.shtm
This is now free as the owner has retired and is feeling benevolent.
It used to cost a few thousand $ and is not trivial.
Very powerful.Enjoy.
@jujudelta said in Circuit, PCB analysis tools:
Thank you for your hint, I'll look at Micro-Cap 12!
A lot of analysis possibilities, this will be fun to use! And Mosfet and IGBT models, this will be very informative to learn about them.
@joergs5 said in Circuit, PCB analysis tools:
This guy has a few episodes demonstrating MicroCap. Apparently it's also free now after the developer retired.
https://www.youtube.com/watch?v=bjn-252Oo7A
If you look for a user friendly program, you may want to try this https://www.circuitlab.com/
@zapta thanks for the youtube link, the gallery of voltmeters signals some electronic experience
Thanks for the CircuitLab hint, but I don't like online tools much*), I'll stick at Micro-Cap and for PCB design KiCad seems to be interesting also.
*) IP is not the reason, the reason is they want my private data sooner or later.
BTW thanks for your stepper motor analyzer, this inspired me to develop similar Duet extensions!
I started this morning to learn microcap, following the user manual. So far it looks very thorough and reasonable UI.
For PCB design, I'd highly recommend EasyEDA, it is an exceptionally good, free, PCB program (having used quite a few different and often ludicrously expensive ones over some decades).
@rjenkinsgb yep. Or kicad 6.0
@rjenkinsgb, coincidently I started using EasyEDA yesterday after looking at it a few times over the years, and it improved greatly and has a more modern and intuitive UI than Kicad.
The OP seems to prefer local apps over web apps so may not be a good fit. Also, I am not sure how does it compare with Kicad for more complex projects, but it definitely a good choice for smaller projects and the integration with JLCPCB part library and footprints is great.
This is my first project, a work in progress. Most of the work is in aligning all the parts and EasyEDA makes it easier.
@zapta said in Circuit, PCB analysis tools:
this is only my personal taste, please everyone may go ahead talking about every software. Because this thread is meant to be a general discussion for all users, it may be interesting for others to use online tools, also. (And there are very good online tools like GeoGebra without registering, I use some of them).
I have the same problem with Micro-Cap, because it's not open source, I cannot modify it. But being so powerful, I'll proceed with it, looking at KiCad at the same time.
@joergs5, it seems that EasyESA also support simulation with an easy to use GUI which is very nice https://www.youtube.com/watch?v=5eoOV1IxkIU
@PCR, I see that Kicad 6 is out. Originally it was supposed to be released May 2021.
I was waiting for it. Will see how difficult the transition is.
BTW, all of Duet's board are designed with Kicad.
There is a fully downloadable version of EasyEDA - I don't like using anything web-based for files I want to control!
It can also import kicad files; I've used it to view Duet board files.
I'm criticizing kicad in any sense, just being sure there are no misunderstandings re. easyeda.
I have a different question about which reflow oven to use, maybe someone can help me.
I am thinking about buying a T-962A reflow oven and then modifying it (better temperature control, better heating). Is this a good idea or are there better options? I plan to develop small PCBs for interfaces, maybe 100x200 mm maximal, but two sides.
@rjenkinsgb EasyEDA is a nice program. I appreciate that there are a lot of circuits of other users where I can learn from them. Micro-Cap and KiCad have their uses also.
T-962A reflow oven
I used a similar over in the past, with stencils, paste, and manual vacuums component picker but gave it away. It was too much of a hassle for my use cases.
Now I just solder the parts using tweezers and a fine solder iron, and with the Chinese stereo microscope I have, I can get down to 0402 components and 0.5mm pitch ICs.
Another option I am using now is JLCPCB SMD service which is reasonably priced so I try to include as many components that are available at JLCPCB and then solder the rest by hand.
I used to have a fancy Metcal soldering system but gave it away and now using this cheapo chineese that give me about the same results. They are so cheap that I have a few of them, each each a different tip and temperature setting. https://www.aliexpress.com/item/4000129151281.html
For manual soldering, I recommend getting good flux paste such as AmTech (spelling?) and a cheap optical stereo microscope, you don't need high magnification, ~x5 works well for PCB worked. I am using this one https://www.amazon.com/gp/product/B00A15N1ZA there are many models, including ones with long boom base. The light ring is important.
YMMV.
We use normal (good) temperature controlled irons for general work, and I have a cheap ebay hot air tool that works fine for surface mount ICs, when needed.
If you want complete boards, use JLCPCB - it's cheaper to have them also supply the parts and assemble the PCBs, than to buy the separate components!
@JoergS5 I use a domestic electric hotplate for reflow soldering small prototype boards. No need for a reflow oven unless you are going into production.
