    How corexy belts tension?
    9.0k
    • peirofundefined
      peirof
      I'm in the assembly of a corexy... And I have reached a delicate moment, that of placing the belts and giving them the right tensión.
      The problem I find myself is not that of not finding information, it is the opposite... In a search in San Google there are many results, too much, because each one uses a different system ... And I don't know which one to follow..
      It was to ask you, that you will have more experience in assembling and adjusting a corexy, the method you used to give the correct tension to the belts. One of the ideas that is repeated in the guides, is to use an application for the mobile, and sound the belts and tension them until they sound at about 60 hz
      How can do it? What method do you use?
      fcwiltundefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @peirof
        @peirof
        Look for a phone app that will display the spectrum of an audio signal. It is easier to match two belts using that type of display.
        • mrehorstdmdundefined
          mrehorstdmd
          When you adjust corexy belt tension, getting the X and Y axes square is the goal, not matching the tensions to each other.
          When you tighten the second belt, the first one gets tighter, too, so set the first belt tension a bit lower than you think it should be and then tighten the second belt until the X and Y axes are square. Then you can check the tension using a phone app, if you have sufficient data from the belt manufacturer to know the target resonant frequency. If you're using no-spec Chinese belts, set the tension tight, but not too tight (very subjective, I know) and be done with it. It will work fine. The absolute value of belt tension isn't critical. Getting the axes square is critical.
          https://drmrehorst.blogspot.com/2018/08/corexy-mechanism-layout-and-belt.html
          • zaptaundefined
            zapta @peirof
            @peirof said in How corexy belts tension?:
            I use the recommended voron 2 method. For 6mm x/y belts, tensioning for 110Hz over a 150mm span. Some apps work better than others, I have had good success with an an app called Pano Tuner. I use it at night, when it's quiet, with the printer off. I have a gcode macro that brings brings the head to a point that I have 150mm span on both belts.
            Another method I used on a previous printer is deflection using this scale https://www.amazon.com/gp/product/B00EPQGQIA , deflecting on ~400 mm for a few mm (I had a printed part that indicates that calibrated deflection distance) with a force of 400gr. All those numbers need to be calibrated to your printer, but it's an easy to perform method once you have the numbers.
            • mikeabuilderundefined
              mikeabuilder
              This is a little off-topic because it relates to belt design (and I want to show off one of my designs) - but on my CoreXY printer designs, I design the belt attachment so that the belts are connected in a continuous loop. This means that the belt tension must be equal on the "two" belts. The design is a little more complex (I say elegant), but I don't bring music into the thing. Except where my first printer uses a guitar tuning machine to tension the belt.
              On this design, the upper and lower belt ends are each fixed to a sliding bracket and those brackets are connected to each other by a wire (not shown) around the grooved pulley. This connects the the upper an lower belts and makes the "one belt". The other end of the lower belt is fixed to the lower bracket under the tuning machine and the upper belt end goes around the gear on the tuning machine. Complicated, but it works. My newer design (no picture yet) does not try to do the tensioning on the carriage.
              rjenkinsgbundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
              • rjenkinsgbundefined
                rjenkinsgb @mikeabuilder
                @mikeabuilder
                Very nice!
                Just be aware though, that some types of belt can have the rubber body separate from the tensioning fibre or wire and stretch away, if held in a straight clamp with no fold, bend or wrap etc. to take the strain first.
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                peirofundefined 1 Reply Last reply Reply Quote 0
                • peirofundefined
                  peirof @rjenkinsgb
                  @rjenkinsgb its possible view in action?
                  rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                    rjenkinsgb @peirof
                    @peirof
                    The bad clamp idea? Some info:
                    https://reprap.org/forum/read.php?1,840947
                    For tensioning on my CoreXY machine, I just set the "twang" pitch to what seems reasonable and try to get both belts the same.
                    Robert J.
                      mrehorstdmd @mikeabuilder
                      @mikeabuilder Is that on the extruder carriage? It's very elaborate (that's good in a sort of steam-punk way), but seems like a lot of extra weight to carry around for the purpose of tightening the belt, which you'll probably do only one time. I prefer to tension belts on a fixed part of the printer, with simple screws holding them in place. Specifically, sliding motor mounts with screws in slots to allow positioning of the motors along the Y axis. The ends of the belts clamp at the extruder carriage. The motor mounts had to be screwed down anyway, so simply cutting slots for those screws solves the belt tensioning problem. Adjustments can be made without affecting the parallel relationship of the belt and the Y axis guide rail.
                      The linked post was my failed clamp design. It might have worked OK for glass/aramid core belts, but it sure didn't work for steel core. This is what I use to anchor the belts at the extruder carriage- it's all a little bigger than I'd like, but it's working and I have other projects to work on and limited time.
                      I could reduce the weight and probably improve reliability if I just cut a couple slots in the aluminum body of the extruder carriage, fold the belts over steel pins and back through the slots, and secure the ends with zip ties. Maybe someday.
                        mikeabuilder
                        @mrehorstdmd, yes all that stuff is on the extruder carriage. I'll take the steampunk comment as a compliment. And it did add a lot of mass (the guitar tuner is fitted to a small bronze casting) but we're using NEMA23 motors and hope all will be well - testing at the makerspace is delayed by omicron. Meanwhile my second design is progressing in my home workshop and it's much more compact, including getting the tensioners off the carriage.
                        In my new design, I've done a lot of work to get the belts really close to each other at the carriage, both in Z (7mm overlap) and Y (3mm spacing). The fixed ends are clamped first to the carriage using a stack of 1mm aluminum plates and a 3mm clamp. 9df91bc8-9c2a-4c58-8e53-4f7e363d0870-image.png
                        The floating ends of the belt are connected to a 3mm plate that can slide side to side, this is required to make the "one belt". 899f4dad-bdc3-41f5-8af4-9605c21eaf87-image.png
                        The other ends of the belt are then clamped to this floating plate.469dd12c-eb93-4418-87fc-14c100f38ac3-image.png
                        After the "one belt" is tensioned, the sliding motion is lockedby 4 cap screws (only two shown). 3bc0b02c-6c53-407c-87f0-f476d4341857-image.png
                        Ofcourse, if the belt teeth get ripped off the belts, as @rjenkinsgb points out, I'll be back to the drawing board.
                        I'm tensioning the belts where the front pulley plates lock into my 2040 extrusions. I even added a lever in case I want to get crazy.
                        I also pack an extruder, mosquito hot end, part cooling fan, and BLtouch probe onto the carriage.4e85facf-dc82-41f8-8939-daf82f63166b-image.png d4d14714-9573-4a05-849a-3ab3a56ab847-image.png
                        Ten pounds of shit in a 5 pound bag.
                          @mikeabuilder Interesting. I'm trying to figure out what the corner pulleys look like with a 7mm overlap of the belts.
                            rjenkinsgb
                            Mine uses a rather different anchor system:
                            The first two photos are of some prototype parts:
                            The belts run through curved channels which take them across the back of the clamping pockets. There are short offcuts of belt glued in the back to add friction and elasticity to the clamp force.
                            The clamp blocks are serrated and the final ones have stepped sides to reduce the twist in the pockets, caused by the belt tension.
                            The third photo is the final head assembly on the working machine; the belts are cut short at the far end but left with tails at this end to allow enough to grip for easier pre-tensioning.
                            Robert J.
                              mikeabuilder
                              @mrehorstdmd, another one of my possibly stupid ideas with this printer is the use of a twisted belt configuration at the belt crossing. Here's the prototype I made to test the belt twist. It worked well except that the laser cut mdf bridge could not keep the pulley axles straight. I'm just getting ready to buy aluminum parts d0e7bcaa-477b-4f90-b87b-afdf0b8d6209-image.png
                              I don't have a good photo, but the CAD model shows the two motor gear and rear corner idler. f1b813e1-206b-4230-9056-1a8099c9dae9-image.png
                              To make it work, I'm using a pair of flanged bearings as the idler and they have a bigger diameter than the drive gear on the NEMA23 motor. To make the twisted belts pass without hitting each other, the idler and gear axes need to be aligned. And you can see that without the two diameters, I'd need another idler to get the belt past the drive gear. 6188a49b-1784-4a06-ab76-9d5f56edda2a-image.png
                                @mikeabuilder Your motors are only engaging the belt at a 90 degree wrap. That's potentially going to let the belt slip, and is liable to be pretty noisy as the belt teeth meet the pulley. OTOH, the corners on the right wrap around the pulleys at 180 degrees. That would be a better place for the motors.
                                It looks like there are twists in both belts at the motor mount, and one of them is going to be in the variable length segment between the drive pulley and the X axis pulley block. That means as the X axis gets closer to the drive pulley (Y max or Ymin) the belt is going to have to twist over a shorter and shorter distance which is going to cause problems tracking on the pulleys and probably wearing the belt out quickly, among other potential problems. Belt manufacturers usually have some minimum distance spec for a 90 or 180 degree twist.
                                The corner pulley on the left in the belt diagram doesn't have to be in line with the drive pulley. If you move it downward in the drawing it will have plenty of clearance.
                                This is mine:
                                Notice the larger pulley on the bottom of the corner pulley block on the left. That provides extra clearance for the belt as the X axis approaches the corner pulley block. There are no twists in the belts- the pulleys (F608 bearings) are large enough (22 mm dia) that 9 teeth of the belt contact the surface even where the wrap is only 90 degrees (I saw this recommendation in some Gates whitepaper on GT2 belts).
                                This is the belt diagram of my printer:
                                Putting at least 9 belt teeth into contact with a smooth pulley avoids print defects, but anytime you have belt teeth contacting pulleys (smooth or toothed), it's going to make "zippy" noises at high speeds (~200 mm/sec and up). If you are concerned about noise, put a single twist in each belt in the outermost segments (J and K in my diagram). After that only the smooth side of the belts will contact the pulleys (except the drive pulley, of course). The two drive pulleys will still make noise, but that's quieter than ten pulleys making zippy noises. If you aren't too concerned about noise and you want to avoid print defects, use larger pulleys made from stacked bearings. Larger bearings, generally, will last longer than smaller bearings, and belts will probably last longer bending around larger pulleys, too. Avoid the little 3D printer pulleys like a case of COVID if you want to get reliable long-term operation. If you want quiet operation and long life, use large bearings for the pulleys and twist the belts as described above.
                                NEMA-23 motors are usually noisier than NEMA-17 motors, so if you can get a NEMA-17 motor that has sufficient speed/torque, use it.
                                Avoid adding extra pulleys in the belt paths. Each pulley you bend the belt over increases the load on the motors. That will ultimately limit speed/acceleration because stepper torque drops as speed increases. If you have a corexy printer you can feel the effect- just manually move the X axis back and forth in Y. Only the drive pulleys and corner pulleys see the belt moving. Now move the extruder carriage in X. All the pulleys now see moving belts and it's a lot harder to push the carriage in X.
                                  mikeabuilder
                                  @mrehorstdmd, great points, particularly about the motor wrap. I'm counting on extra belt tension to ensure the 90 wrap is acceptable or I'll need to add a pulley, or move the motors as you mention. I'm counting on metal mounting plates and very short axles to keep the axles vertical under the added tension. My printer will run where the added noise is not a factor to me. And I think you misinterpreted where my belts twist. I twist them on the M segment in your diagram above. You can see it on the left side of my prototype picture above.
                                  I like your use of tubular sections in your design to support both ends of the pulley axles. It's a wise use of standard materials and provides a means of keeping the axles aligned.
                                  Every design is a compromise between competing layout options, manufacturing options, and designer whims. For my design, I'm trying to stick with laser cuttable flat plates. I have a small milling machine, but I hate waiting hours for it to get anything done. This led me to cantilevered pulley axles and the need to keep them short brought me to the twisted belt (it's also a whim of mine to see how well the twisted belt will work). And with overlapping belts, I can't stack their pulleys. I also want to keep the distance between belts F and D (in your picture above) as small as possible. With stacked belts it's possible to reduce the distance to 0, but I've opted for 3mm (to match a plate thickness), just to keep things compact.
                                  Another whim I have is to face the teeth on the F and D (and C and E) segment towards each other, interlock the teeth and fix the belt ends as a single unit. It required the belts to be overlapped but eliminates the "one belt" concept that equalizes tension. Maybe on another iteration of the design...
                                  Bottom line as I see it is that anyone that designs their own printer is doing it at least partly for the joy of the design task. It certainly isn't cheaper than knocking out a copy of an existing design.
                                    deckingman
                                    While we are sharing pics of our belts, here is how I do mine.
                                    This the Y carriage.
                                    Rather than putting the pulleys on a single "axle" I use two. This enables me to have both belts closer to the centre line of the X carriage and makes it much less sensitive to twisting forces which might be imparted by unequal belt tension.
                                    This is the X carriage.
                                    The belts simply pass through slots, fold at 90 degrees and a clamping plate holds them in place. It's a simple method and one which has served me well despite having a very heavy 6 input hot end.
                                    This the motor mount which is also the tensioning mechanism.
                                    The mount is clamped to the extrusion with the 3 bolts on the side. The front plate is threaded and the thumb screw "pushes" against the frame. Tensioning is done by slacking the clamp bolts and lock nut, then turning the thumb screw clockwise which pushes the mount backwards.
                                      mrehorstdmd @deckingman
                                      @deckingman Interesting- I did a similar design for the Y carriage in my sand table- except the belts are spaced apart laterally (in Y) to allow the X axis guide tube to fit between them. Printed in two parts, it uses a spring loaded PTFE block sliding in the t-slot (a sand table is low resolution, so it works fine) for Y axis guidance. There are twists in the J and K belt segments to minimize noise (I run the table at 1500 - 2000 mm/sec for some drawings) :
                                      I like the motor mount!
                                        deckingman @mrehorstdmd
                                        @mrehorstdmd said in How corexy belts tension?:
                                        Thanks. The original ones were printed in PET-G but despite me fitting heat sinks and fans to the motors, they still distorted with 30-40 hr+ prints. Making them out of aluminium cures the distorting issue but it also acts like a giant heat sink by transferring heat from the motors through the mount and into the frame. So the motors now run cool - barely above ambient to the touch, and I have removed the heat sinks and fans. It also offers a good grounding path for any static charge that might build up on the belts (not that I ever noticed any such problem personally).
                                        I like your sand table. Making one has been on my to-do list since I saw the original Sisyphus at Questacon in Canberra, Australia https://www.taomc.com/sisyphus
