    Looking for ABL ideas
    973
    • oliofundefined
      oliof
      Alternately try underbed piezo sensors and probe with the nozzle.
      • terbospaghettiundefined
        terbospaghetti
        I think I'm gonna be a chicken about the piezos/FSRs. They seem cool, but ultimately I'm looking for the simplest solution.
        I guess that means switching my heatsink fan out for a 5V and sharing power for that with a BLtouch. That's the only way I can come up with to make enough wires in the 15 pins I've got.
        At present, they are:
        1-4: Extruder step/dir
        5/6: Heater
        7/8: Thermistor
        9/10: Heatsink fan
        11-13: 3 wires currently run to DC42 IR probe
        14/15: Part cooling fan I haven't installed yet.
        Current plan is to get the BLtouch, install it using the three leads from the IR probe, along with the two as-yet unused cooling fan leads to get up and running for speed tuning. I'll order some cheap 5v fans to replace the heatsink fan, and once they arrive I'll piggyback them off of the BLtouch's 5v leads.
        That should still leave me with the two pins I need to run a cooling fan.
        I tried a couple of beds, but I'm pretty much married to glass at this point. Just can't beat the peel-off with TPU lol.
        Ok thanks for listening if you're still here
        Alex.crundefined 1 Reply Last reply Reply Quote 0
        • zaptaundefined
          zapta @Phaedrux
          @phaedrux said in Looking for ABL ideas:
          I've never found a good explanation for why there are two. Eventually they both go back to ground so... I dunno.
          I would think that they are separated for the same reason that people pass separate +VIN wires to their heatsink and material cooling fans. Logically they represent two independent functions, a servo and an open collector switch.
          • oliofundefined
            oliof
            TAP Nozzle Contact sensor also looks nice (requires some custom manufacturing, but nothing too fancy).
            • Alex.crundefined
              Alex.cr @terbospaghetti
              @terbospaghetti
              If you can find a way to implement the klicky probe I am a huge fan.
              Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
              terbospaghettiundefined 1 Reply Last reply Reply Quote 0
                terbospaghetti @Alex.cr
                @alex-cr said in Looking for ABL ideas:
                klicky probe
                Klicky probe is a cool concept, but won't work for anyone who has a printer in a real shop unless you painstakingly clean the magnets of every metal fiber they've been near before each leveling.
                Neat, but impractical in the real world.
                PCRundefined 1 Reply Last reply Reply Quote 0
                • PCRundefined
                  PCR @terbospaghetti
                  @terbospaghetti hmm open 3d printers at a shop with metal chips flying around it's not good... Enclose the printer at least.
                    terbospaghetti @PCR
                    @pcr "metal chips flying around" isn't accurate at all, but thanks for the tip.
                    I've got 5+ years of printing in the environs in question with absolutely no problems at all, but I'll go ahead and pay several hundred dollars to enclose them so I can maybe make a cool magnet idea work....
                    Doesn't pass the smell test, sorry dude.
                    • zaptaundefined
                      zapta
                      @terbospaghetti said in Looking for ABL ideas:
                      It's one of the most popular probes on Voron printers. People like it because it works well also in higher chamber temperatures (compared to inductive and bltouch), mechanically senses the top surface (compared to inductive and IR), not sensitive to dirt on the nozzle tip (compared to piezo), provides a simple two wires dry contact (compared to more complex interfaces such as bltouch), doesn't take much real estate on the moving head, easy to customize, and inexpensive.
                      That's a clear winner.
                        terbospaghetti @zapta
                        @zapta all of that is true, but it could also be a description of a BLtouch. And you left out the part about how there's magnets to grab anything light and ferrous, which will cause the same problem as the dirt on your nozzle with a piezo.
                        Glad it's working for some people, but in my case it's very clearly the wrong move. I've got magnets on my bulletin board right now with tiny shavings on them that came from god-knows-where. To assume that magnets attached to a 3d printer would not have that same issue would be pretty foolish of me.
                        And let's not pretend there's anything simple about that setup, what happens when you heat cycle those magnets so many times their field characteristics change? Maybe not a big concern for most, but I often heat my bed to 110°c or more. Can't be doing wonders for a magnet.
                        • zaptaundefined
                          zapta @terbospaghetti
                          @terbospaghetti, I understand that Klicky may not be a good choice for your use case but the 'Doesn't pass the smell test' sounds as a very board statement.
                          As for BlTouch, it doesn't do well in heated chambers.
                          As for the magnets loosing their power, first there are magnets that stand 100C+ (e.g. https://mandalaroseworks.com/products/voron0-magbed) and second, the Klicky's measurement doesn't not depend on the strength of the magnetic field as is. the with BlTouch.
