    E3d Toolchanger to a Leapfrog frame
    My Duet controlled machine
    1.4k
      Phaedrux Moderator @Pertti
      @pertti said in E3d Toolchanger to a Leapfrog frame:
      what function has the microswitch below the x-carriage?
      It homes the Z axis. When a tool is selected. The offset for that tool is loaded.
      stepper stall, do I have to have some extra sensors to cope with that?
      Stall detection homing is a feature built into the stepper driver. It detects the back EMF of the stepper when it stalls. It must be tuned and configured for best results.
      Perttiundefined 1 Reply Last reply Reply Quote 0
      • Perttiundefined
        Pertti @Phaedrux
        @phaedrux
        Ok, the Z-homing happens without any tool connected? And every tool has its own z offset.
        Finally I found out that the pulley gears were changed to smaller ones... that´s why the movements were shorter.
        Pertti
        “A winner is just a loser who tried one more time.”
        George M. Moore, Jr.
          On the E3D tool changer, yes, that's how it works. The offset must be measured for each tool.
          • Perttiundefined
            Pertti
            Now I received Duet Wifi and Duex5.😀 Some things I have to ask😓 :
            • Should the C7 axis (toolchanger connecor shaft) have some kind of physical endstop? Mine is runnig free...
              I found a screw in the middle of the shaft, is it doing the thing? I have not the original x-carriage but my own.
            • Can´t find the configuration file and the command where you can adjust the positioning of the tool docks. My bed is 300 x 300. Dimensions are certainly different than in the original TC.
            • so far so good, looking forward to see all working !
            Pertti
            martinkundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
            • martinkundefined
              martink @Pertti
              There is no endstop for the C axis. It uses stall detection for homing.
              (Note that there is a mod on thingiverse that lets you use physical endstops for X and Y on the E3D toolchanger. But C always uses stall detection.)
              Have you read through this yet? https://e3d-online.zendesk.com/hc/en-us/article_attachments/4402646531729/08_-_ToolChanger_Toolhead_Installation.pdf to better understand which part goes where?
              If you follow the github link above, compare tpre0.g/tfree0.g to tpre1.g/tfree1.g. The numbers that differ between those files are the coordinates for docking tool 0/tool 1.
              Be aware that in the linked config files, the bed center is at x=0/y=0. In E3D's default config, the center of the bed is at x=150/y=100 (just in case you run into someone else's config files).
              • rjenkinsgbundefined
                rjenkinsgb @Pertti
                Mine is also home made.
                The screw in the middle of the clamp shaft is the endstop; it stalls against the protrusion inside the casting to reference it.
                Looking from the tool side, the shaft should rotate clockwise until it hits that end of the travel; the motor current is reduced during the home sequence so stalling does no harm.
                this is my "homec.g" file:
                ; homec.g
                ; called to home the C axis (coupler)
                ;G91
                M400
                G92 C499
                M400
                M913 C60		; MOTOR TO 60% CURRENT
                G1 H1 C0 F2000
                M400
                G92 C0
                ;G90
                M913 C100			; MOTOR TO 100% CURRENT
                G1 C0 F10000
                ;Open Coupler
                M98 P"/macros/Coupler - Unlock"
                As martink says, you create or edit the movement sequences in the tpre and tpost files, to pick up or return each tool.
                After referencing, move to each tool position manually, making sure the head is dead centre with the tool, and note the X & Y positions when it's just touching.
                Also note how far away from the other tools you need to be (on Y) to be able to move across safely on X without the possibility of collisions.
                The sequence is something like
                Move Z slightly in G91
                Move Y to the safe position
                Move X in line with the appropriate tool
                Move in more slowly to the tool pickup/release position
                Clamp or unclamp, depending if its a pickup or return
                Move back to the Y safe position
                Example - my tpre0.g
                ; tpre0.g
                ; called before tool 0 is selected
                ; Verify X & Y are referenced before any tool action
                if !move.axes[0].homed || !move.axes[1].homed
                	M98 P"homey.g"
                	M98 P"homex.g"
                	M98 P"homec.g"
                G91
                G1 Z5 F15000
                G90
                ;Unlock Coupler
                ;Move to clearance position
                G1 Y200 F25000
                ;Align
                G1 X300.0 Y220 F25000
                ;Pick up position
                G1 X300.0 Y298.0 F2500
                ;Close Coupler
                M98 P"/macros/Coupler - Lock"
                ;Move Out
                G1 X300.0 Y220 F4000
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                • Perttiundefined
                  Pertti @rjenkinsgb
                  @rjenkinsgb Thanks. It takes a while to discover the geometry. Yes, now I managed to set up the docks. Next thing is to prepare the stall brake.
                  Pertti
                  • o_lampeundefined
                    o_lampe
                    @Pertti
                    The belts around the stepper pulleys wrap only 90°. This isn't enough fo my liking.
                    How much does the X-axis sag with the unsupported linear rail? I have the same on my IDEX, but that beam is only 300mm.
                    • Perttiundefined
                      Pertti @o_lampe
                      @o_lampe said in E3d Toolchanger to a Leapfrog frame:
                      I tried to measure it, by pressing by 337 grams it was about 0.3 mm. I think it is not good but I can fix it later if necessary. Good that You asked, thanks.
                      Pertti
                      • Perttiundefined
                        Pertti
                        First test runs are done😳 . The tool0 works ok. 🐸 Next leap is the slicer. I´m familiar with Cura. Any opinions or examples? Or do I have to use some other slicer?
                        My new 230v bed heat is a surprise, the temperature rises really fast. It looks like the machine first heats the bed and when it´s done then it starts with the tool. Is it possible to start both the bed and the tool heating at the same time?
                        Pertti
                        • Perttiundefined
                          Pertti
                          My first attempt with two tools failed. 😕 The toolchanger did not catch the tools. Should there be start and end codes for both printer and tools in the slicer (Cura)? T0 and T1 drop and pick do their job properly when tested manually.
                          Thanks for help in advance!👨‍🎨
                          Pertti
                            dc42 administrators @Pertti
                            @pertti you should not need to set up any tool change scripts in Cura, assuming you have done everything necessary within the tool change files. Are you certain that your tool change files (tfree#.g, tpre#.g and tpost#.g) work regardless of where on the bed the pickup head is when you change tools?
                            Perttiundefined 2 Replies Last reply Reply Quote 0
                            • Perttiundefined
                              Pertti @dc42
                              @dc42 Maybe the distance between T0 and T1 is too short, 70 mm? It looks like the x-carriage approaches the tool diagonally and possibly touches the neighbouring tool. I think that the final approach should be like the airplane landing circuit:👮 the final is parallel with the runway. Can this be achieved by adjusting the tpre#.g ? Or should I spread the distance between tools? Then I loose one tool.😠
                              Pertti
                                jay_s_uk @Pertti
                                @pertti adjust tpre.
                                for example, move to the X coordinate first and then move in Y. Means you're taking a straight run up
                                • Perttiundefined
                                  Pertti @jay_s_uk
                                  @jay_s_uk That´s a square advise! thnks.
                                  Pertti
                                  • Perttiundefined
                                    Pertti @Pertti
                                    @pertti BUT. Tool1 works ok, somehow T0 does not. The toolpick 0 macro works fine, When I start printing the Tool 0 is selected and moved backwards but then it loosens the screw and does not print. After that the screw is tightened and "printing" ends. Also Z-homing becomes "insufficient". This happens after the printer tries all by itself to home all.
                                    I have completely no idea to fix this.
                                    Pertti
                                    • Perttiundefined
                                      Pertti @dc42
                                      @dc42 Now I removed all scripts from Cura and that was the answer to my problem.
                                      Pertti
