LE TORRI NEL GRAFICO
![@alankilian grazie amico ma non capisco come hai fatto ad impostare il bed rotondo ?
guarda il mio grafico delle altezze da cosa può dipendere ho seguito m665 . la costruzione , mi sfugge ,e come ci fosse un buco nella torre z . cosa ne pensi -
You must follow the instructions for Delta calibration as described ON THIS PAGE step-by-step exactly.
If you did the steps one at a time and got good results for each step you should get a good height map.
I do not know what's wrong with your machine.
What version of hardware do you have?
- Duet version
- Z-brobe version
- 3D printer version
What version of firmware are you running?
@alankilian ho fatto una prova il punto in alto del grafico x60 y80 Z 2,4 ,HO DATO LE CORDINATE x60 y80 Z 0 , MA Z RISULTA PIU ALTO FORSE PROPRIO 2 MM
@alankilian Duet Web Control 3.2.2, BLTouch, DELTA KOSSEL
@luca-massimiliano said in LE TORRI NEL GRAFICO:
grazie alan ti chiedo mi puoi dire la posizioni delle 3 torri sul asse x y del grafico ? grazie
I built a Kossel recently and went through all this setup.
To work out the towers, jog the machine in X.
That will move left<>right when you are at the "front" of whatever arrangement you presently have.Y will move towards<>away from the "rear" tower.
Re-arrange the motor cables (and limit switch cables) to get the actual front at the position it should be.
Then, X+ should move to the right and X- to the left; if it moves the opposite way, swap the two front motor cables.
That should put all the motors/towers in the correct position so the heightmap is as seen from the front of the machine.
@luca-massimiliano SCUSA UNA DOMANDA MA QUESTA MACCHINA HA SEMPRE STAMPATO , MA SEMPRE CON IQUESTO GRAFICO . DETTO QUESTO POSSONO ESSERRE SEMPRE I FILI INVERTI DEI MOTORI? OPPURE NO?
@rjenkinsgb ECCO LE CORDINATE E LE TORRI SULLA STAMPANTE
, ORA TRASLANDO LE X E Y SUL GRAFICO CONCIDONO LE TORRI , IL PSITIVO E NEGATIVO CHIEDO A TE SE E' GIUSTO . A ME SEMBRA CORRETO
That matches my machine.
Did you follow the instructions in calibrating a Delta I sent earlier exactly?
Can you post the results of M665, M666 and M558?Here are mine:
m666 Endstop adjustments X0.20 Y-0.65 Z0.44, tilt X0.00% Y0.00% m665 Diagonals 291.060:291.060:291.060, delta radius 144.000, homed height 400.186, bed radius 132.5, X -0.223°, Y -0.216°, Z 0.000° m558 Z Probe 0: type 1, input pin zprobe.in, output pin nil, dive height 10.0mm, probe speeds 3000,3000mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
@alankilian said in LE TORRI NEL GRAFICO:
m558
TIENI CONTO CHE ENDSTO Z L HO SPOSTATO PEGGIORANDO LA SITUAZIONE (IL MIO PROSSIMO PASSO SARA' LA SISTEMAZIONE DEGLI END STOP , ANCHE SE NON RIESCO VISTO LA DISTANZA DEL LETTO A FARE MISURAZIONI PRECISE )
It looks like I have my endstops adjusted a little better than yours as well as the angle of the rails.
Maybe you could spend some time getting those adjusted better and see if it makes your bed probing produce a flatter heightmap.
Ok, the "front" is -Y, between XT and YT.
XT is the corner of the graph with the red-green-blue axis indicators.As alankillian says, try to get the mechanical setup as accurate as possible first.
Create a bed.g with settings 10-6-6 and as large a radius as you can, without the probe missing the bed:
http://www.escher3d.com/pages/wizards/wizardbed.phpThen run G32 several times! Each should improve the compensation values in the M665 and M666 lines.
Then use M500 to save the final ones, and add M501 at the end of your config to load the config-override file, if you do not already have it.
Hopefully that will give a better heightmap result!
@alankilian GRAZIE , CON LAIUTO TUO E DI TUTTI ,SONO RIUSCITO AD OTTENERE NOTEVOLI MIGLIORAMENTI DEL GRAFICO, QUESTO MI HA FATTO CAPIRE IL POSSIBILE PROBLEMA , LA DEFORMAZIONE NEL TEMPO NON HA PIU' UNA CORRETA GEOMETRIA NELLA PARTE SOPRA , PROVVEDERO' A SISTEMARLA.
@alankilian DOVE SI MODIFICA LA RAPPRESENTAZIOE GRAFICA DA QUADRATA A CIRCOLARE ?
What software are you using to make that image?
@alankilian Elettronica
Diagnostica
Scheda: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware per Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
Duet WiFi Server Versione: 1.23 -
@luca-massimiliano ciao ora ho ottenuto un risultato accettabile ,inserendo modificando co i vari comandi M665 R LB130 H ,M303 per heater , eccetera , salvai con m500 quindi la stampante si accende bene con tutti i dati , ma nel config .g non vengono riportati questi nuovi dati, e' possibile trasferire i dati nella memoria della scheda di Duet . in un file ? grazie cordiali saluti
hello now I have obtained an acceptable result, inserting by modifying with the various commands M665 R LB130 H, M303 for heater, etc., I saved with m500 then the printer turns on well with all the data, but in the config .g they are not given these new data, it is possible to transfer the data to the memory of the Duet card. in a file? thank you
M500 saves the data to config-override.g. You must then add M501 to the end of config.g to load the values at startup.
@phaedrux said in LE TORRI NEL GRAFICO:
M500
grazie. ora ho stampato ma il pezzo e' fuori scala , ho modificato M665 L306.17 e ho con un nuovo valore calcolato, ora stampa in scala , ma se do il comando G0 Y-130,X0,Z0, non parte proprio se do G0 Y-125,X0,Z0, ci va (le braccia Z della torre sono al Limite non vanno oltre . ma se riporto M665 L306.17 il comando G0 Y-130,X0,Z0 funziona . come posso risolvere ? -
thank you. now I have printed but the piece is out of scale, I have modified M665 L306.17 and I have with a new calculated value, now it prints to scale, but if I give the command G0 Y-130, X0, Z0, it does not start just if I give G0 Y-125, X0, Z0, it goes there (the Z arms of the tower are at the Limit they do not go beyond. But if I carry M665 L306.17 the command G0 Y-130, X0, Z0 works. How can I solve?
I think you need to redo your calibration.
https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
@phaedrux RIFORMULO LA DOMANDA LE MIE ASTE MISURATE SONO M665 L 335 , MA L OGGETTO STAMPATO E' PIU PICCOLO DEL REALE. COME POSSO RISOLVERE?
