    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.8k
      jay_s_uk @jamaicarasta
      @jamaicarasta You need an M671 to set the pivot points of the gantry.
      I would probably go with the point where it the belts attach
      jamaicarastaundefined 1 Reply Last reply Reply Quote 1
      • jamaicarastaundefined
        jamaicarasta @jay_s_uk
        @jay_s_uk
        ok m671… 😤 i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there?
          @jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
          jamaicarastaundefined 2 Replies Last reply Reply Quote 0
            @jay_s_uk
            Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
            You are my hero 🙏
            I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand.
              @jay_s_uk
              I measured and found the values. Should I measure the values ​​from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him.
                @jamaicarasta the locations are in relation to X0 Y0
                jamaicarastaundefined 1 Reply Last reply Reply Quote 0
                  @jay_s_uk
                  Ok perfect 👍
                  it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape...
                  • jumpedwithbothfeetundefined
                    jumpedwithbothfeet @jamaicarasta
                    @jamaicarasta you had the X listed twice in each line instead of one X and one Y
                    6 G30 P1 X15 X5 z-99999
                    however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning 🙂
                    6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                    jamaicarastaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                      jamaicarasta @jumpedwithbothfeet
                      @jumpedwithbothfeet
                      Sorry that was a old file 😅
                      I don’t saw this. Now is not x and x in one line 👊🏻
                        jay_s_uk @jumpedwithbothfeet
                        @jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
                        we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well
                          @jay_s_uk
                          Thanks for the tip bro.
                          Now I will make my mesh.g file.
                          with an error: Push(): stack overflow
                          ; mesh.g
                          ; called to perform automatic bedmesh via G29
                          M561 ; clear any bed...
                          G29 ; bed mesh
                          G1 X175 Y175 Z50 F20000 ; go to bed middle
                          ; bed.g
                          G30 P0 X15 Y20 Z-99999 ; Probe links vorne
                          G30 P1 X15 Y315 Z-99999 ; Probe links hinten
                          G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
                          G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
                          G1 X175 Y175 Z5 F20000
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
                          G91 ; relative positioning
                          G1 H1 X355 F6000 ; home X axis
                          G1 X-5 F6000 ; go back a few mm
                          G1 H1 X355 F360 ; move slowly to X axis endstop
                          G1 H1 Y355 F6000 ; home y axis
                          G1 Y-5 F6000 ; go back a few mm
                          G1 H1 Y355 F360 ; move slowly to Y axis endstop
                          G90 ; absolute positioning
                          G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
                          ; Z-Probe --------------------------------------------------------------------
                          M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                          G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
                          M557 X15:335 Y35:315 S10 ; define mesh grid
                          jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            @jamaicarasta not sure why you would receive a stack overflow. can you post an output of m122?
                              @jay_s_uk What do you mean?
                                @jamaicarasta send M122 on the console tab ans post here whats spat out
                                  @jay_s_uk Ok 1 min
                                    @jay_s_uk M122
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Board ID: YHJ3Q-U296U-D65J0-40KMS-0K03Z-ZGYPZ
                                    Used output buffers: 3 of 40 (13 max)
                                    Static ram: 102724
                                    Dynamic ram: 107620 of which 28 recycled
                                    Never used RAM 33332, free system stack 130 words
                                    Tasks: NETWORK(ready,16.0%,216) HEAT(notifyWait,0.0%,348) Move(notifyWait,0.1%,283) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,357) CanClock(delaying,0.0%,338) TMC(delaying,1.2%,115) MAIN(running,81.9%,412) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 00:42:50 ago, cause: software
                                    Last software reset at 2022-02-16 16:05, reason: User, GCodes spinning, available RAM 33764, slot 1
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 2570411, completed 2570409, timed out 0, errs 0
                                    Step timer max interval 1463
                                    MCU temperature: min 25.4, current 25.8, max 27.6
                                    Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: position 28000, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 159, reads 37031, writes 9, timeouts 0, DMA errors 0
                                    Driver 1: position 0, standstill, SG min/max 0/486, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Driver 2: position 1436, standstill, SG min/max 0/470, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Driver 3: position 0, standstill, SG min/max 0/468, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Driver 4: position 0, standstill, SG min/max 0/502, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Driver 5: position 0, standstill, SG min/max 0/508, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Driver 6: position 0, standstill, SG min/max 0/502, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                    Date/time: 2022-02-16 16:47:53
                                    Slowest loop: 23.40ms; fastest: 0.11ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 3.9ms, write time 6.2ms, max retries 0
                                    DMs created 83, maxWait 850021ms, bed compensation in use: none, comp offset 0.000
                                    === MainDDARing ===
                                    Scheduled moves 151, completed moves 151, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                                    === AuxDDARing ===
                                    Bed heaters = 0 -1, chamberHeaters = -1 -1
                                    Segments left: 0
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    SBC is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Aux2 is idle in state(s) 0
                                    Code queue is empty.
                                    === CAN ===
                                    Messages queued 23194, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 12852/0/0
                                    Tx timeouts 0,61,12851,0,0,10279 last cancelled message type 30 dest 127
                                    === Network ===
                                    Slowest loop: 76.53ms; fastest: 0.00ms
                                    HTTP sessions: 1 of 8
                                    • WiFi -
                                      Network state is active
                                      WiFi firmware version 1.26
                                      WiFi MAC address d8:bf:c0:14:e8:2c
                                      WiFi Vcc 3.30, reset reason Power up
                                      WiFi flash size 2097152, free heap 25040
                                      WiFi IP address 192.168.178.28
                                      WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
                                      Clock register 00002002
                                      @jamaicarasta can you post your full config, full bed file and full mesh.g file
                                        @jay_s_uk
                                        ; bed.g
                                        ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                                        ; General preferences -------------------------------------------------------
                                        M550 P"Duet Voron" ; set printer name
                                        M669 K1 ; select CoreXY mode
                                        ; Network --------------------------------------------------------------------
                                        M552 S1 ; enable network
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        ; Drives ---------------------------------------------------------------------
                                        ; ----+---- Z-Drives
                                        ; | 2 | 3 |
                                        ; | 1 | 4 |
                                        ; Front
                                        M584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
                                        M671 X-55:-55:405:405 Y-25:390:390:-25 S2 ; belt position
                                        M569 P0 S1 ; extruder motor direction
                                        M569 P1 S1 ; Z1 motor direction
                                        M569 P2 S0 ; Z2 motor direction
                                        M569 P3 S1 ; Z3 motor direction
                                        M569 P4 S0 ; Z4 motor direction
                                        M569 P5 S1 ; X motor direction
                                        M569 P6 S1 ; Y motor direction
                                        M350 X16 Y16 Z16 E16 I1 ; set microstepping
                                        M92 X80 Y80 Z400 E426 ; set microsteps per mm
                                        M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                                        M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
                                        M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        ; thermal section ------------------------------------------------------------
                                        M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
                                        M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
                                        ; Axis Limits ----------------------------------------------------------------
                                        M208 X350 Y350 Z340 S0 ; set axis maxima
                                        ; Endstops -------------------------------------------------------------------
                                        M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
                                        M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
                                        M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in
                                        ; Heaters --------------------------------------------------------------------
                                        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                                        M143 H1 S300 ; set temperature limit for heater 1 to 300C
                                        ; Fans -----------------------------------------------------------------------
                                        M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                                        M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
                                        M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
                                        M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                                        M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
                                        M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                        M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
                                        M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
                                        ; Tools ----------------------------------------------------------------------
                                        ; Custom settings are not defined --------------------------------------------
                                        M501
                                        ; bed.g
                                          @jamaicarasta i cant see anything that would cause a stack overflow.
                                          Not sure if anyone else would like to comment
                                          jamaicarastaundefined 3 Replies Last reply Reply Quote 0
                                            @jay_s_uk
                                            As I said, I'm completely new to RRF. I need a bit more until I understand everything.
