    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.8k
    • jamaicarastaundefined
      jamaicarasta @jay_s_uk
      @jay_s_uk
      ok i will check that i took a config from the internet from the beginning and maybe the value there is wrong for my probe
        @jay_s_uk
        So the error is gone, now I have the next error. is that something in the config file?
        G32
        Error: This kinematics does not support auto-calibration
        Config:
        General preferences -------------------------------------------------------
        M550 P"Duet Voron" ; set printer name
        M669 K1 ; select CoreXY mode
        ; Network --------------------------------------------------------------------
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        ; Drives ---------------------------------------------------------------------
        ; ----+---- Z-Drives
        ; | 2 | 3 |
        ; | 1 | 4 |
        ; Front
        M584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
        M569 P0 S1 ; extruder motor direction
        M569 P1 S1 ; Z1 motor direction
        M569 P2 S0 ; Z2 motor direction
        M569 P3 S1 ; Z3 motor direction
        M569 P4 S0 ; Z4 motor direction
        M569 P5 S1 ; X motor direction
        M569 P6 S1 ; Y motor direction
        M350 X16 Y16 Z16 E16 I1 ; set microstepping
        M92 X80 Y80 Z400 E426 ; set microsteps per mm
        M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        ; thermal section ------------------------------------------------------------
        M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
        M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
        ; Axis Limits ----------------------------------------------------------------
        M208 X350 Y350 Z340 S0 ; set axis maxima
        ; Endstops -------------------------------------------------------------------
        M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
        M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
        M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in
        ; Z-Probe --------------------------------------------------------------------
        M558 K0 P8 A2 S0.05 C"^io1.in" H5 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
        G31 P500 X0 Y10 Z1.590 ; set Z probe trigger value, offset and trigger height
        M557 X15:335 Y15:335 S20 ; define mesh grid
        ; Heaters --------------------------------------------------------------------
        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
        M143 H1 S300 ; set temperature limit for heater 1 to 300C
        ; Fans -----------------------------------------------------------------------
        M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
        M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
        M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
        M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
        M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
        M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
        M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
        M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
        ; Tools ----------------------------------------------------------------------
        ; Custom settings are not defined --------------------------------------------
        M501
          jay_s_uk @jamaicarasta
          @jamaicarasta You need an M671 to set the pivot points of the gantry.
          I would probably go with the point where it the belts attach
          jamaicarastaundefined 1 Reply Last reply Reply Quote 1
            @jay_s_uk
            ok m671… 😤 i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there?
              @jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
              jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                @jay_s_uk
                Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
                You are my hero 🙏
                I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand.
                  @jay_s_uk
                  I measured and found the values. Should I measure the values ​​from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him.
                    @jamaicarasta the locations are in relation to X0 Y0
                    jamaicarastaundefined 1 Reply Last reply Reply Quote 0
                      @jay_s_uk
                      Ok perfect 👍
                      it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape...
                      • jumpedwithbothfeetundefined
                        jumpedwithbothfeet @jamaicarasta
                        @jamaicarasta you had the X listed twice in each line instead of one X and one Y
                        6 G30 P1 X15 X5 z-99999
                        however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning 🙂
                        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                        jamaicarastaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                          jamaicarasta @jumpedwithbothfeet
                          @jumpedwithbothfeet
                          Sorry that was a old file 😅
                          I don’t saw this. Now is not x and x in one line 👊🏻
                            jay_s_uk @jumpedwithbothfeet
                            @jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
                            we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well
                              @jay_s_uk
                              Thanks for the tip bro.
                              Now I will make my mesh.g file.
                              with an error: Push(): stack overflow
                              ; mesh.g
                              ; called to perform automatic bedmesh via G29
                              M561 ; clear any bed...
                              G29 ; bed mesh
                              G1 X175 Y175 Z50 F20000 ; go to bed middle
                              ; bed.g
                              G30 P0 X15 Y20 Z-99999 ; Probe links vorne
                              G30 P1 X15 Y315 Z-99999 ; Probe links hinten
                              G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
                              G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
                              G1 X175 Y175 Z5 F20000
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
                              G91 ; relative positioning
                              G1 H1 X355 F6000 ; home X axis
                              G1 X-5 F6000 ; go back a few mm
                              G1 H1 X355 F360 ; move slowly to X axis endstop
                              G1 H1 Y355 F6000 ; home y axis
                              G1 Y-5 F6000 ; go back a few mm
                              G1 H1 Y355 F360 ; move slowly to Y axis endstop
                              G90 ; absolute positioning
                              G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
                              M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                              G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
                              M557 X15:335 Y35:315 S10 ; define mesh grid
                              jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                @jamaicarasta not sure why you would receive a stack overflow. can you post an output of m122?
                                  @jay_s_uk What do you mean?
                                    @jamaicarasta send M122 on the console tab ans post here whats spat out
                                      @jay_s_uk Ok 1 min
                                        @jay_s_uk M122
                                        RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                                        Board ID: YHJ3Q-U296U-D65J0-40KMS-0K03Z-ZGYPZ
                                        Used output buffers: 3 of 40 (13 max)
                                        Static ram: 102724
                                        Dynamic ram: 107620 of which 28 recycled
                                        Never used RAM 33332, free system stack 130 words
                                        Tasks: NETWORK(ready,16.0%,216) HEAT(notifyWait,0.0%,348) Move(notifyWait,0.1%,283) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,357) CanClock(delaying,0.0%,338) TMC(delaying,1.2%,115) MAIN(running,81.9%,412) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
                                        Owned mutexes: WiFi(NETWORK)
                                        Last reset 00:42:50 ago, cause: software
                                        Last software reset at 2022-02-16 16:05, reason: User, GCodes spinning, available RAM 33764, slot 1
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 2570411, completed 2570409, timed out 0, errs 0
                                        Step timer max interval 1463
                                        MCU temperature: min 25.4, current 25.8, max 27.6
                                        Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                        Driver 0: position 28000, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 159, reads 37031, writes 9, timeouts 0, DMA errors 0
                                        Driver 1: position 0, standstill, SG min/max 0/486, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Driver 2: position 1436, standstill, SG min/max 0/470, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Driver 3: position 0, standstill, SG min/max 0/468, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Driver 4: position 0, standstill, SG min/max 0/502, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Driver 5: position 0, standstill, SG min/max 0/508, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Driver 6: position 0, standstill, SG min/max 0/502, read errors 0, write errors 1, ifcnt 203, reads 37020, writes 20, timeouts 0, DMA errors 0
                                        Date/time: 2022-02-16 16:47:53
                                        Slowest loop: 23.40ms; fastest: 0.11ms
                                        === Storage ===
                                        Free file entries: 10
                                        SD card longest read time 3.9ms, write time 6.2ms, max retries 0
                                        DMs created 83, maxWait 850021ms, bed compensation in use: none, comp offset 0.000
                                        === MainDDARing ===
                                        Scheduled moves 151, completed moves 151, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                                        === AuxDDARing ===
                                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                                        Segments left: 0
                                        Movement lock held by null
                                        HTTP is idle in state(s) 0
                                        Telnet is idle in state(s) 0
                                        File is idle in state(s) 0
                                        USB is idle in state(s) 0
                                        Aux is idle in state(s) 0
                                        Trigger is idle in state(s) 0
                                        Queue is idle in state(s) 0
                                        LCD is idle in state(s) 0
                                        SBC is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        Code queue is empty.
                                        === CAN ===
                                        Messages queued 23194, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 12852/0/0
                                        Tx timeouts 0,61,12851,0,0,10279 last cancelled message type 30 dest 127
                                        === Network ===
                                        Slowest loop: 76.53ms; fastest: 0.00ms
                                        HTTP sessions: 1 of 8
                                        • WiFi -
                                          Network state is active
                                          WiFi firmware version 1.26
                                          WiFi MAC address d8:bf:c0:14:e8:2c
                                          WiFi Vcc 3.30, reset reason Power up
                                          WiFi flash size 2097152, free heap 25040
                                          WiFi IP address 192.168.178.28
                                          WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
                                          Clock register 00002002
                                          @jamaicarasta can you post your full config, full bed file and full mesh.g file
                                            @jay_s_uk
                                            ; bed.g
                                            ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                                            ; General preferences -------------------------------------------------------
                                            ; | 2 | 3 |
                                            ; | 1 | 4 |
                                            ; Front
                                            M671 X-55:-55:405:405 Y-25:390:390:-25 S2 ; belt position
                                            M501
                                            ; bed.g
