    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.8k
    • jamaicarastaundefined
      jamaicarasta @jumpedwithbothfeet
      @jumpedwithbothfeet
      where do i have 2 times x? don't quite understand. I gave correct points 4 times in my opinion.
      Thanks
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
        jamaicarasta @jay_s_uk
        @jay_s_uk
        and one more question if i may. it does not go to my specified coordinates exactly. X15 stays at X40 on rehearsal. but if I drive normally with g1 then it drives exactly to x15. only at g32 is it off by 25.
          jay_s_uk @jamaicarasta
          @jamaicarasta it applies the G31 offsets to that, so if your probe is -25 in X, the nozzle has to be at 40 for the probe to be at 15
          jamaicarastaundefined 1 Reply Last reply Reply Quote 0
            @jay_s_uk
            ok i will check that i took a config from the internet from the beginning and maybe the value there is wrong for my probe
              @jay_s_uk
              So the error is gone, now I have the next error. is that something in the config file?
              G32
              Error: This kinematics does not support auto-calibration
              Config:
              General preferences -------------------------------------------------------
              M550 P"Duet Voron" ; set printer name
              M669 K1 ; select CoreXY mode
              ; Network --------------------------------------------------------------------
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              ; Drives ---------------------------------------------------------------------
              ; ----+---- Z-Drives
              ; | 2 | 3 |
              ; | 1 | 4 |
              ; Front
              M584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
              M569 P0 S1 ; extruder motor direction
              M569 P1 S1 ; Z1 motor direction
              M569 P2 S0 ; Z2 motor direction
              M569 P3 S1 ; Z3 motor direction
              M569 P4 S0 ; Z4 motor direction
              M569 P5 S1 ; X motor direction
              M569 P6 S1 ; Y motor direction
              M350 X16 Y16 Z16 E16 I1 ; set microstepping
              M92 X80 Y80 Z400 E426 ; set microsteps per mm
              M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ; thermal section ------------------------------------------------------------
              M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
              M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
              ; Axis Limits ----------------------------------------------------------------
              M208 X350 Y350 Z340 S0 ; set axis maxima
              ; Endstops -------------------------------------------------------------------
              M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
              M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
              M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in
              ; Z-Probe --------------------------------------------------------------------
              M558 K0 P8 A2 S0.05 C"^io1.in" H5 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
              G31 P500 X0 Y10 Z1.590 ; set Z probe trigger value, offset and trigger height
              M557 X15:335 Y15:335 S20 ; define mesh grid
              ; Heaters --------------------------------------------------------------------
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M143 H1 S300 ; set temperature limit for heater 1 to 300C
              ; Fans -----------------------------------------------------------------------
              M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
              M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
              M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
              M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
              M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
              ; Tools ----------------------------------------------------------------------
              ; Custom settings are not defined --------------------------------------------
              M501
                @jamaicarasta You need an M671 to set the pivot points of the gantry.
                I would probably go with the point where it the belts attach
                jamaicarastaundefined 1 Reply Last reply Reply Quote 1
                  @jay_s_uk
                  ok m671… 😤 i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there?
                    @jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
                    jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                      @jay_s_uk
                      Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
                      You are my hero 🙏
                      I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand.
                        @jay_s_uk
                        I measured and found the values. Should I measure the values ​​from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him.
                          @jamaicarasta the locations are in relation to X0 Y0
                            @jay_s_uk
                            Ok perfect 👍
                            it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape...
                            • jumpedwithbothfeetundefined
                              jumpedwithbothfeet @jamaicarasta
                              @jamaicarasta you had the X listed twice in each line instead of one X and one Y
                              6 G30 P1 X15 X5 z-99999
                              however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning 🙂
                              6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                              jamaicarastaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                @jumpedwithbothfeet
                                Sorry that was a old file 😅
                                I don’t saw this. Now is not x and x in one line 👊🏻
                                  jay_s_uk @jumpedwithbothfeet
                                  @jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
                                  we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well
                                    @jay_s_uk
                                    Thanks for the tip bro.
                                    Now I will make my mesh.g file.
                                    with an error: Push(): stack overflow
                                    ; mesh.g
                                    ; called to perform automatic bedmesh via G29
                                    M561 ; clear any bed...
                                    G29 ; bed mesh
                                    G1 X175 Y175 Z50 F20000 ; go to bed middle
                                    ; bed.g
                                    G30 P0 X15 Y20 Z-99999 ; Probe links vorne
                                    G30 P1 X15 Y315 Z-99999 ; Probe links hinten
                                    G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
                                    G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
                                    G1 X175 Y175 Z5 F20000
                                    ; homeall.g
                                    ; called to home all axes
                                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
                                    G91 ; relative positioning
                                    G1 H1 X355 F6000 ; home X axis
                                    G1 X-5 F6000 ; go back a few mm
                                    G1 H1 X355 F360 ; move slowly to X axis endstop
                                    G1 H1 Y355 F6000 ; home y axis
                                    G1 Y-5 F6000 ; go back a few mm
                                    G1 H1 Y355 F360 ; move slowly to Y axis endstop
                                    G90 ; absolute positioning
                                    G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
                                    M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                                    G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
                                    M557 X15:335 Y35:315 S10 ; define mesh grid
                                    jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      @jamaicarasta not sure why you would receive a stack overflow. can you post an output of m122?
                                        @jay_s_uk What do you mean?
                                          @jamaicarasta send M122 on the console tab ans post here whats spat out
                                            @jay_s_uk Ok 1 min
