    Integrate polish translation
    PanelDue
    1.3k
    • Chri55undefined
      Chri55 @mfs12
      @mfs12 I checked and it works fine (on 5.0i panel, unfortunately 7.0 is unavailable at the moment, I think it will be ok if it works well on 5.0).
      I corrected a few mistakes and too long words. I also left some words in English, they make more sense for people who use printers than polish translations.
      polish translation.txt
      Chri55undefined 1 Reply Last reply Reply Quote 0
      • Chri55undefined
        Chri55 @Chri55
        @chri55 If it will not be a big problem could you compile a polish to older version because on a printer with electronics in V2 version it doesn't work.
        Below is the translation for 1.24 paneldue release.
        polish for electronics v2.txt
        • mfs12undefined
          mfs12
          Hey @Chri55, i sent you just a version for PD 7.0i. When this will be released more hardware will be supported. This is just a test build.
          Visit me on github at https://github.com/mfs12/
          • Chri55undefined
            Chri55 @mfs12
            @mfs12 ok, thanks for information 🙂
            • mfs12undefined
              mfs12
              @Chri55 thanks for your translations, with my very little polish i tried to integrate things as good as possible. While reviewing i found those translations either misaligned or missing. It would be very helpful if you can help me out here.
              • orig->screensaverAfter: 'Screensaver ', 'Wygaszacz '
              • orig->touchTheSpot: 'Touch the spot', 'Touch the spot'
              • orig->statusValues[j]: 'Idle', 'Idle'
              • orig->statusValues[j]: 'Off', 'Standby'
              • orig->statusValues[j]: 'Cancelling', 'Inicjowanie'
              Here you can double check how things were integrated. If you find something, please leave comment. By clicking on left column you can comment directly on the code.
              https://github.com/Duet3D/PanelDueFirmware/pull/175/files
              mfs12 opened this pull request in Duet3D/PanelDueFirmware
              closed Integrate polish translation #175
              • mfs12undefined
                mfs12
                @Chri55 i found another problem...
                "Wygaszaj gdy bezczynny" is too long. it may have only half the length.
                If you could provide the missing translations, see comment above then i can merge it. Otherwise probably won't make it into the next release.
                • mfs12undefined
                  mfs12
                  @Chri55 how are you doing? Are you available to finish polish translation?
                  Rafal_llundefined 1 Reply Last reply Reply Quote 0
                  • Rafal_llundefined
                    Rafal_ll @mfs12
                    Cześć Chri55
                    Możesz dokończyć tłumaczenie... Było by fajnie zobaczyć nasz język w menu
                    Jeśli mogę Ci jakoś pomóc to chętnie.
                    Pozdrawiam
                    Hi Chri55
                    You can finish the translation ... It would be nice to see our language on the menu
                    If I can help you somehow, I will be happy to.
                    greetings
                    • Rafal_llundefined
                      Rafal_ll @Rafal_ll
                      Dokończyłem twój plik. Jeśli chcesz to sprawdź.
                      Proponuję go umieścić w następnej wersji firmware
                      I have finished your file. If you want to check it out.
                      I propose to include it in the next firmware version
                      polish-translation-0.3.txt
                      • mfs12undefined
                        mfs12
                        @Rafal_ll thanks a lot for you help!!!
                        now only two strings are missing... if you make it on time, they get into the next release.
                        Status Values:
                        - 'Off', 'Off'
                        - 'Cancelling', 'Cancelling'
                        • mfs12undefined
                          mfs12
                          https://github.com/Duet3D/PanelDueFirmware/issues/171
                          mfs12 created this issue in Duet3D/PanelDueFirmware
                          closed integrate polish translation #171
                          • mfs12undefined mfs12 has marked this topic as solved
                          • Rafal_llundefined
                            Rafal_ll
                            I'm sorry I was unavailable ...
                            These two words are
                            Status Values:
                            • 'Off', 'Wyłącz'
                            • 'Canceling', 'Anuluj'
                              T3P3Tony administrators @Rafal_ll
                              @rafal_ll
                              Please see.
                              https://forum.duet3d.com/topic/29312/paneldue-firmware-3-4-1-pre3-released
                              • droftartsundefined droftarts referenced this topic
