    Integrate polish translation
    PanelDue
    1.3k
    • mfs12undefined
      mfs12
      Hey @Chri55, i sent you just a version for PD 7.0i. When this will be released more hardware will be supported. This is just a test build.
      Visit me on github at https://github.com/mfs12/
      Chri55undefined 1 Reply Last reply Reply Quote 0
      • Chri55undefined
        Chri55 @mfs12
        @mfs12 ok, thanks for information 🙂
        • mfs12undefined
          mfs12
          @Chri55 thanks for your translations, with my very little polish i tried to integrate things as good as possible. While reviewing i found those translations either misaligned or missing. It would be very helpful if you can help me out here.
          • orig->screensaverAfter: 'Screensaver ', 'Wygaszacz '
          • orig->touchTheSpot: 'Touch the spot', 'Touch the spot'
          • orig->statusValues[j]: 'Idle', 'Idle'
          • orig->statusValues[j]: 'Off', 'Standby'
          • orig->statusValues[j]: 'Cancelling', 'Inicjowanie'
          Here you can double check how things were integrated. If you find something, please leave comment. By clicking on left column you can comment directly on the code.
          https://github.com/Duet3D/PanelDueFirmware/pull/175/files
          mfs12 opened this pull request in Duet3D/PanelDueFirmware
          closed Integrate polish translation #175
          • mfs12undefined
            mfs12
            @Chri55 i found another problem...
            "Wygaszaj gdy bezczynny" is too long. it may have only half the length.
            If you could provide the missing translations, see comment above then i can merge it. Otherwise probably won't make it into the next release.
            • mfs12undefined
              mfs12
              @Chri55 how are you doing? Are you available to finish polish translation?
              Rafal_llundefined 1 Reply Last reply Reply Quote 0
              • Rafal_llundefined
                Rafal_ll @mfs12
                Cześć Chri55
                Możesz dokończyć tłumaczenie... Było by fajnie zobaczyć nasz język w menu
                Jeśli mogę Ci jakoś pomóc to chętnie.
                Pozdrawiam
                Hi Chri55
                You can finish the translation ... It would be nice to see our language on the menu
                If I can help you somehow, I will be happy to.
                greetings
                • Rafal_llundefined
                  Rafal_ll @Rafal_ll
                  Dokończyłem twój plik. Jeśli chcesz to sprawdź.
                  Proponuję go umieścić w następnej wersji firmware
                  I have finished your file. If you want to check it out.
                  I propose to include it in the next firmware version
                  polish-translation-0.3.txt
                  • mfs12undefined
                    mfs12
                    @Rafal_ll thanks a lot for you help!!!
                    now only two strings are missing... if you make it on time, they get into the next release.
                    Status Values:
                    - 'Off', 'Off'
                    - 'Cancelling', 'Cancelling'
                    • mfs12undefined
                      mfs12
                      https://github.com/Duet3D/PanelDueFirmware/issues/171
                      mfs12 created this issue in Duet3D/PanelDueFirmware
                      closed integrate polish translation #171
                      • mfs12undefined mfs12 has marked this topic as solved
                      • Rafal_llundefined
                        Rafal_ll
                        I'm sorry I was unavailable ...
                        These two words are
                        Status Values:
                        • 'Off', 'Wyłącz'
                        • 'Canceling', 'Anuluj'
                          T3P3Tony administrators @Rafal_ll
                          @rafal_ll
                          Please see.
                          https://forum.duet3d.com/topic/29312/paneldue-firmware-3-4-1-pre3-released
                          • droftartsundefined droftarts referenced this topic
