    Is filament chnage required?
    1.1k
    • ICY_SNAKEundefined
      ICY_SNAKE
      Hello to all,
      I always get the following message:
      <Is filament change reuqired? navigate to the macros tab and press filament Change.>
      Where are the values defined?
      How can we disable that.
      How can I reset the values to zero and define when the message comes??
      etc..
      I´m using 5kg filament.
      Thx
      for your help
      DO IT OR DON'T
      • fcwiltundefined
        fcwilt @ICY_SNAKE
        @icy_snake
        What do you see if you click the Filament item in the DWC?
        ICY_SNAKEundefined 1 Reply Last reply Reply Quote 0
          ICY_SNAKE @fcwilt
          @fcwilt
          If i click on filaments
          there is nothing listed.
          At the right bottom i get an orange box with the following mesages:
          <Failed to get filelist
           directory 0:/filaments not found>
          Dieter
          DO IT OR DON'T
          • fcwiltundefined
            fcwilt @ICY_SNAKE
            @icy_snake said in Is filament chnage required?:
            Dieter
            OK that is what I wanted to know. But it means that message about requiring a filament change is coming from somewhere else.
            In your System folder do you have any files like these?
              ICY_SNAKE @fcwilt
              @fcwilt yes have them
              tfree0.g empty
              tfree1.g empty
              tpost0.g M116 P0
              tpost1.g M116 P1
              tprep0.g empty
              tprep1.g empty
              DO IT OR DON'T
              • fcwiltundefined
                fcwilt @ICY_SNAKE
                tfree0.g empty
                tfree1.g empty
                tpost0.g M116 P0
                tpost1.g M116 P1
                tprep0.g empty
                tprep1.g empty
                I don't think having an empty file would lead to that message. And the M116 is just waiting for the tool heater to reach temp.
                Maybe that code is in your slicer. You are using IdeaMaker?
                  ICY_SNAKE @fcwilt
                  @fcwilt yes i am using ideamaker
                  DO IT OR DON'T
                  fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @ICY_SNAKE
                    I don't use that but I have it. I will take a look at its code generation and see if it could be the source of that message.
                    • fcwiltundefined
                      fcwilt @ICY_SNAKE
                      @icy_snake
                      In IdeaMaker under Filament Settings there is this place for Custom GCode. Do you have anything there?
                      ICY_SNAKEundefined 1 Reply Last reply Reply Quote 1
                        This sounds like a modix macro. When and where do you see this message?
                          ICY_SNAKE @fcwilt
                          @fcwilt Good morning, no i have nothing there
                          DO IT OR DON'T
                            ICY_SNAKE @Phaedrux
                            @phaedrux I pretty sure there is no macro.
                            I see the message during printing.
                            DO IT OR DON'T
                              Can you zip up your full config file set and share it here?
                              That message is coming from somewhere. Possibly a filament sensor?
                              Is it coming continuously when printing?
                              ICY_SNAKEundefined 2 Replies Last reply Reply Quote 0
                                ICY_SNAKE @Phaedrux
                                @phaedrux yes it is coming always.
                                DO IT OR DON'T
                                  ICY_SNAKE @Phaedrux
                                  @phaedrux I cannot upload a zip or rar file??
                                  DO IT OR DON'T
                                  • fcwiltundefined
                                    fcwilt @ICY_SNAKE
                                    Morning.
                                    IdeaMaker uses what they call Templates. Templates have several places where code can be entered.
                                    For whatever template is being used when you get the filament message check all of the possible code places shown below:
                                      ICY_SNAKE @fcwilt
                                      @fcwilt said in Is filament chnage required?:
                                      All tabs are empty, already checked.
                                      DO IT OR DON'T
                                      • fcwiltundefined
                                        fcwilt @ICY_SNAKE
                                        Well this is curious. I'm running out of ideas.
                                        Do you have a start.g file?
                                          Phaedrux Moderator @ICY_SNAKE
                                          you can change the extension to .txt and upload it or use a file sharing cloud service.
                                            ICY_SNAKE @Phaedrux
                                            @phaedrux
                                            ok here as a txt
                                            icy_modix60_setup .txt
                                            Hey it worked.
                                            DO IT OR DON'T
