    Is filament chnage required?
    1.1k
    • ICY_SNAKEundefined
      ICY_SNAKE @fcwilt
      @fcwilt yes i am using ideamaker
      DO IT OR DON'T
      fcwiltundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @ICY_SNAKE
        @icy_snake said in Is filament chnage required?:
        I don't use that but I have it. I will take a look at its code generation and see if it could be the source of that message.
        • fcwiltundefined
          fcwilt @ICY_SNAKE
          @icy_snake
          In IdeaMaker under Filament Settings there is this place for Custom GCode. Do you have anything there?
          ICY_SNAKEundefined 1 Reply Last reply Reply Quote 1
            This sounds like a modix macro. When and where do you see this message?
              ICY_SNAKE @fcwilt
              @fcwilt Good morning, no i have nothing there
              DO IT OR DON'T
                ICY_SNAKE @Phaedrux
                @phaedrux I pretty sure there is no macro.
                I see the message during printing.
                DO IT OR DON'T
                  Can you zip up your full config file set and share it here?
                  That message is coming from somewhere. Possibly a filament sensor?
                  Is it coming continuously when printing?
                  ICY_SNAKEundefined 2 Replies Last reply Reply Quote 0
                    ICY_SNAKE @Phaedrux
                    @phaedrux yes it is coming always.
                    DO IT OR DON'T
                      ICY_SNAKE @Phaedrux
                      @phaedrux I cannot upload a zip or rar file??
                      DO IT OR DON'T
                      • fcwiltundefined
                        fcwilt @ICY_SNAKE
                        Morning.
                        IdeaMaker uses what they call Templates. Templates have several places where code can be entered.
                        For whatever template is being used when you get the filament message check all of the possible code places shown below:
                        ICY_SNAKEundefined 1 Reply Last reply Reply Quote 0
                          ICY_SNAKE @fcwilt
                          @fcwilt said in Is filament chnage required?:
                          All tabs are empty, already checked.
                          DO IT OR DON'T
                          • fcwiltundefined
                            fcwilt @ICY_SNAKE
                            Well this is curious. I'm running out of ideas.
                            Do you have a start.g file?
                              Phaedrux Moderator @ICY_SNAKE
                              you can change the extension to .txt and upload it or use a file sharing cloud service.
                                ICY_SNAKE @Phaedrux
                                @phaedrux
                                ok here as a txt
                                icy_modix60_setup .txt
                                Hey it worked.
                                DO IT OR DON'T
                                • fcwiltundefined
                                  fcwilt @ICY_SNAKE
                                  @icy_snake
                                  Check the contents of pause.g.
                                    ICY_SNAKE @fcwilt
                                    @fcwilt Here is my
                                    pause.g
                                    <; pause.g
                                    ; called when a print from SD card is paused
                                    M300 S1111 P222
                                    M117"Is filament change required? Navigate to the macros tab and press on Filament Change"
                                    M564 H1 S1 		;
                                    M116
                                    M83            		; relative extruder moves
                                    G1 E-10 F800  		; retract 10mm of filament
                                    G91            		; relative positioning
                                    G1 Z20 F360     	; lift Z by 20mm
                                    G90
                                    G1 Y0 F6000 		; go to the front
                                    G1 X0 F6000 		; go to the left
                                    M300 S1111 P333
                                    M291 R"Attention !" P"It is recommended to turn off the heaters if the pause is expected to last a long time" T46>
                                    DO IT OR DON'T
                                    • fcwiltundefined
                                      fcwilt @ICY_SNAKE
                                      @fcwilt Here is my
                                      pause.g
                                      <; pause.g
                                      M300 S1111 P222
                                      M564 H1 S1 		;
                                      M116
                                      G90
                                      M300 S1111 P333
                                      I meant you should look at it as it is the source of the filament change message you mentioned in an earlier post.
                                        ICY_SNAKE @fcwilt
                                        yes we have the macro which gives the message but not sure why it comes up during printing.
                                        As i wrote in an other post that there are problems with statics voltage, do bad design of the printer.
                                        I added ground to all metall pieces, had to get ride of paint etc.
                                        Now i can touch the dispaly or printer without any failures or messages on the display.
                                        my feeling is the reason was the missing grounding.
                                        I´m printig now a big part, total progress 540h . already 96h done.
                                        Thx for your help
                                        Dieter
                                        DO IT OR DON'T
                                        • fcwiltundefined
                                          fcwilt @ICY_SNAKE
                                          Thx for your help
                                          Dieter
                                          In the config.g file, down in custom settings, there are two triggers configured which, when activated, will run pause.g. The comments say they are connected to filament sensors, one for E0 and one for E1.
                                          Something must be happening to cause the filament sensors to activate the triggers.
                                            Phaedrux Moderator @fcwilt
                                            I think it's as simple as filament not being loaded in the second tool.'
                                            One way around this is to move the filament sensor activation into the tool change files so that the sensor is only checking for filament when it's the selected tool.
