Is filament chnage required?
1.1k
    fcwilt @ICY_SNAKE
    @icy_snake said in Is filament chnage required?:
    If i click on filaments
    there is nothing listed.
    At the right bottom i get an orange box with the following mesages:
    <Failed to get filelist
    directory 0:/filaments not found>
    Dieter
    OK that is what I wanted to know. But it means that message about requiring a filament change is coming from somewhere else.
    In your System folder do you have any files like these?
    undefined 1 Reply Last reply 18 Feb 2022, 13:01 Reply Quote 0
      ICY_SNAKE @fcwilt
      @fcwilt yes have them
      tfree0.g empty
      tfree1.g empty
      tpost0.g M116 P0
      tpost1.g M116 P1
      tprep0.g empty
      tprep1.g empty
      DO IT OR DON'T
      undefined 1 Reply Last reply 18 Feb 2022, 13:13 Reply Quote 0
        fcwilt @ICY_SNAKE
        tfree0.g empty
        tfree1.g empty
        tpost0.g M116 P0
        tpost1.g M116 P1
        tprep0.g empty
        tprep1.g empty
        I don't think having an empty file would lead to that message. And the M116 is just waiting for the tool heater to reach temp.
        Maybe that code is in your slicer. You are using IdeaMaker?
        undefined 1 Reply Last reply 18 Feb 2022, 13:14 Reply Quote 0
          ICY_SNAKE @fcwilt
          @fcwilt yes i am using ideamaker
          DO IT OR DON'T
          undefined 2 Replies Last reply 18 Feb 2022, 13:21 Reply Quote 0
            fcwilt @ICY_SNAKE
            I don't use that but I have it. I will take a look at its code generation and see if it could be the source of that message.
              fcwilt @ICY_SNAKE
              @icy_snake
              In IdeaMaker under Filament Settings there is this place for Custom GCode. Do you have anything there?
              undefined 1 Reply Last reply 19 Feb 2022, 09:24 Reply Quote 1
                This sounds like a modix macro. When and where do you see this message?
                  ICY_SNAKE @fcwilt
                  @fcwilt Good morning, no i have nothing there
                  DO IT OR DON'T
                  undefined 1 Reply Last reply 20 Feb 2022, 14:25 Reply Quote 0
                    ICY_SNAKE @Phaedrux
                    @phaedrux I pretty sure there is no macro.
                    I see the message during printing.
                    DO IT OR DON'T
                      Can you zip up your full config file set and share it here?
                      That message is coming from somewhere. Possibly a filament sensor?
                      Is it coming continuously when printing?
                      undefined 2 Replies Last reply 20 Feb 2022, 10:35 Reply Quote 0
                        ICY_SNAKE @Phaedrux
                        @phaedrux yes it is coming always.
                        DO IT OR DON'T
                          ICY_SNAKE @Phaedrux
                          @phaedrux I cannot upload a zip or rar file??
                          DO IT OR DON'T
                          undefined 1 Reply Last reply 20 Feb 2022, 20:09 Reply Quote 0
                            fcwilt @ICY_SNAKE
                            Morning.
                            IdeaMaker uses what they call Templates. Templates have several places where code can be entered.
                            For whatever template is being used when you get the filament message check all of the possible code places shown below:
                            undefined 1 Reply Last reply 20 Feb 2022, 16:01 Reply Quote 0
                              ICY_SNAKE @fcwilt
                              @fcwilt said in Is filament chnage required?:
                              All tabs are empty, already checked.
                              DO IT OR DON'T
                              undefined 1 Reply Last reply 20 Feb 2022, 16:55 Reply Quote 0
                                fcwilt @ICY_SNAKE
                                Well this is curious. I'm running out of ideas.
                                Do you have a start.g file?
                                  Phaedrux Moderator @ICY_SNAKE
                                  you can change the extension to .txt and upload it or use a file sharing cloud service.
                                  undefined 1 Reply Last reply 21 Feb 2022, 09:56 Reply Quote 0
                                    ICY_SNAKE @Phaedrux
                                    @phaedrux
                                    ok here as a txt
                                    icy_modix60_setup .txt
                                    Hey it worked.
                                    DO IT OR DON'T
                                    undefined 1 Reply Last reply 21 Feb 2022, 11:35 Reply Quote 0
                                      fcwilt @ICY_SNAKE
                                      @icy_snake
                                      Check the contents of pause.g.
                                      undefined 1 Reply Last reply 22 Feb 2022, 07:01 Reply Quote 1
                                        ICY_SNAKE @fcwilt
                                        @fcwilt Here is my
                                        pause.g
                                        <; pause.g
                                        ; called when a print from SD card is paused
                                        M300 S1111 P222
                                        M117"Is filament change required? Navigate to the macros tab and press on Filament Change"
                                        M564 H1 S1 ;
                                        M116
                                        M83 ; relative extruder moves
                                        G1 E-10 F800 ; retract 10mm of filament
                                        G91 ; relative positioning
                                        G1 Z20 F360 ; lift Z by 20mm
                                        G90
                                        G1 Y0 F6000 ; go to the front
                                        G1 X0 F6000 ; go to the left
                                        M300 S1111 P333
                                        M291 R"Attention !" P"It is recommended to turn off the heaters if the pause is expected to last a long time" T46>
                                        DO IT OR DON'T
                                        undefined 1 Reply Last reply 22 Feb 2022, 07:05 Reply Quote 0
                                          fcwilt @ICY_SNAKE
                                          @fcwilt Here is my
                                          pause.g
                                          <; pause.g
                                          M300 S1111 P222
                                          M564 H1 S1 ;
                                          M116
                                          G90
                                          M300 S1111 P333
                                          I meant you should look at it as it is the source of the filament change message you mentioned in an earlier post.
                                          undefined 1 Reply Last reply 22 Feb 2022, 07:11 Reply Quote 0
                                          13 out of 28
