    What its wrong....
    17
    667
    • gloomyandyundefined
      gloomyandy @peirof
      @peirof What happens if you run the following....
      M98 P"config.g"
      It looks to me like you have some problems with the order that you are doing things. So for instance you need to define the temperature sensors before you try and reference them (when creating heaters and thermostatically controlled fans). Similarly you need to create the heaters before you can set tuning parameters for them. Finally you need to define the heaters/fans etc. before you defines tools that use those heaters/fans.
      peirofundefined 1 Reply Last reply Reply Quote 1
      • peirofundefined
        peirof @gloomyandy
        @gloomyandy said in What its wrong....:
        M98 P"config.g"
        i have this response in console
        M98 P"config.g"
        Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset.
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Warning: Heater 1 predicted maximum temperature at full power is 655°C
        • fcwiltundefined
          fcwilt @peirof
          @peirof said in What its wrong....:
          M98 P"config.g"
          FTP is disabled
          TELNET is disabled
          When creating/loading the heightmap you need to first set the Z=0 Datum using a single G30 at the center of the bed.
          Something like:
          G1 Xaaa Ybbb ; where aaa and bbb move the probe to the center of your bed
          G30          ; set the Z=0 Datum
          The warning is just that - a warning. I make note of it but otherwise ignore it.
            droftarts administrators @peirof
            Under 'General preferences', you have:
            G29 S1 ; Set Units to Millimeters
            G29 S1 loads the bed mesh; G21 sets units to millimeters.
            peirofundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • peirofundefined
              peirof @droftarts
              @droftarts thx, catch
                Phaedrux Moderator @droftarts
                @droftarts said in What its wrong....:
                I've been seeing this in many configs lately. I wonder where it's coming from.
                @peirof Did you generate your config with the online config tool?
                peirofundefined 1 Reply Last reply Reply Quote 0
                • peirofundefined
                  peirof @Phaedrux
                  @phaedrux no.... Ratrig webpage.... there is a configuration for her machine... but has some fails
                    @peirof This page? https://v-core.ratrig.com/firmware/
                    Can you let me know any other issues with the page? I'll email them a list, as there doesn't seem to be a comments system on that page.
                    • peirofundefined
                      peirof @droftarts
                      @droftarts now I cant, later... I can remember 2 small things:
                      • In Duet 3 mini. Io0, its ocupes if you want install panel due without ribbon cable, you have to move it...
                      • in fan lines there is parameters, there are not necessary..
                        I seem to recall @oliof maybe being involved there somehow.
                        • oliofundefined
                          oliof @Phaedrux
                          @phaedrux @droftarts yes, I'm part of their beta team. I can forward any suggestions to improve the configurations.
