    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.2k
    • Barracuda72undefined
      Barracuda72
      after watching our vid our prob are the short rods...but makeing the effector mount wider just makes it softer..more bending while probing. Other problen, that i had on my Delta with faulty sensivity..heatbreak came loose...so it looses lots of sensivity.
      About your Rods...when i designed my delta some years ago there where plently of sites to calculate things like Rod lenght...max angles of rods. Maybe DC42 still have some links to such a calculator. It would be much better to have longer rods..if its ok to loose some build height. Your construction is prone to effector tilts that affects the stability while probing
      tecnoundefined 1 Reply Last reply Reply Quote 1
      • tecnoundefined
        tecno @Barracuda72
        @barracuda72 said in Smart Effector issue:
        The rods and the adapter are original Dreammaker OverLord PRO, going back to a larger/wider effector (original adapter) made the situation better. Only trying to get this old Delta printer functional with a bit more modern parts.
        I am in a process of building a large Delta of 1.4m height and ~550mm print diameter, Rods 610mm long directly to Smart Effector via magnets.
        tecnoundefined Barracuda72undefined rjenkinsgbundefined 3 Replies Last reply Reply Quote 0
        • tecnoundefined
          tecno @tecno
          Can somebody show me how mesh.g is written? To be run with G29
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
          • Stephen6309undefined
            Stephen6309 @tecno
            @tecno This is what I use.
            ; mesh.g
            ; called to load/make heightmap.csv
            M98 P"/macros/ResetBabystepping"
            M561       ; clear any bed transform
            while iterations < #move.axes & move.axes[iterations].visible
              if !move.axes[iterations].homed
                 G28
                 break
            G29 S1        ; load heightmap.csv
            if result > 1 ; make if it doesn't exist
            	G29 S0
            That {1} isn't in it.
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @Stephen6309
              @stephen6309 said in Smart Effector issue:
              ; mesh.g
                   G28
                   break
              	G29 S0
              Not what I was looking for, below a mesh of small circles I want to probe But do not how to write that mesh.g file.
                Barracuda72 @tecno
                @tecno take a look at https://reprap.org/wiki/Delta_geometry and theres a minimum angle of the arms..and in your vid the angles looks smaller if you probe the outermost ppoints...and then you loose all the stability..for m it looks if the arms are too short or the build diameter is too big. make a small test and just probe with a smaller build plate diameter. Use http://www.escher3d.com/pages/wizards/wizardbed.php to get a bed.g and do the probing again...and look how stable the effector might be without probing in the air
                • tecnoundefined
                  tecno @Barracuda72
                  With 80mm probe radius I have just under 30° angle on rods. So the angle is well over recommended 20° minimum.
                  Barracuda72undefined 1 Reply Last reply Reply Quote 0
                    Barracuda72 @tecno
                    @tecno in the vid..when you probe the oauter points the whol effector tilts..and dont trigger...i had the same...2 towers forces the effector on the buildplate and the 3rd tower cant stabilize it...mybe its a prob because we only have mag arms...im sure you need more than 20° if you use mag arms..
                    its easy to try a smaller bed diameter in the bed.g and make a test...
                    Its just the same probe that i had on my 300mm Delta
                    • tecnoundefined
                      tecno @Barracuda72
                      Medicine is M558 P8 R0.45 C"probe+servo0" H5 F3500 T2500
                      • tecnoundefined
                        tecno @tecno
                        @tecno said in Smart Effector issue:
                        ; mesh.g
                             G28
                             break
                        	G29 S0
                        G29 Run file sys/mesh.g, or if that file isn't found then do G29 S0
                        How is that file written?
                        • achrnundefined
                          achrn
                          I don't think it works like that.
                          For mesh bed compensation you can't probe at arbitrary positions, you probe on the regular grid defined in M557.
                          Mesh.g is not for defining the probe points. As I understand it, it's for use if you have a sequence of commands you need to run to do bed probing (e.g. activate or pick up a probe).
                          I think you may be conflating or confusing mesh bed compensation with delta automatic calibration which uses a bed.g that does contain points to probe. Which is it that you are attempting?
                          • tecnoundefined
                            tecno @achrn
                            @achrn said in Smart Effector issue:
                            G32 is no problems (bed.g)
                            G29 can not reach all points
                            • tecnoundefined
                              tecno @tecno
                              a82797e0-5867-465d-ade4-6a5c86c43e66-image.png @tecno
                              Manual is clear as MUD
                              Not one word what can be in that file to be found!
                              A Former User? achrnundefined 2 Replies Last reply Reply Quote 0
                                A Former User @tecno
                                This post is deleted!
                                • achrnundefined
                                  achrn @tecno
                                  @tecno "can not reach all the points" seems to be a different complaint from probe sensitivity. Is that now the problem you are now trying to resolve? If it is the location of the points, what matters is your M557 - what M557 command do you have?
                                  • tecnoundefined
                                    tecno @A Former User
                                    @arnold_r_clark said in Smart Effector issue:
                                    Im afraid that is not true.
                                    There 100% IS an example of what can be in a mesh.g file, it is shown in the docs which can be found HERE
                                    If you scroll down to the G29 command it lists what each "switch" for the command does and it also shows an example of what said mesh.g file can contain.
                                    OK
                                    Then I have to excuse me not understanding English that well.
                                    Anywho my problem still exist with can not reach
                                    • tecnoundefined
                                      tecno @achrn
                                      M665 R95 L206 B80 H262
                                      M557 R80 S15
                                        • tecnoundefined
                                          M557 R80 S15
                                          Have you carried out a step by set system setup and auto calibration ? it seems like your M665 command is missing switches. The M665 command in My delta looks like this :
                                          M665 R181.428 L490 B135 H300.182 X0.093 Y0.252 Z.000
                                          I have a smart effector too. i might be wrong as its been a while since i set mine up but I think what i did was reduced the radius and spacing in the M557 command until it actually worked and I then incrementally went upwards until it failed
                                          M665 L206.000:206.000:206.000 R97.665 H257.594 B70.0 X-3.669 Y-2.101 Z0.000 OVERRIDE
                                          • achrnundefined
                                            achrn
                                            Your mesh grid is right to the limits of the bed. I'd try M557 set inwards slightly - say M557 R75 S15.
                                            If that doesn't work, how does it fail to reach a point? What fails? Does it not move far enough? Does it generate an error? Does it generate horrible grinding noises and a smell of burning? What actually happens when it cannot reach?
                                            Also, can it reach teh point it seems to be failing if you just put those coordinates in a G1?
