    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.2k
      dc42 administrators @tecno
      @tecno have you tried the following to eliminate the false triggering:
      • increase the R parameter in the M558 command, in case it is the previous XY move causing the spurious triggering;
      • reduce the probing acceleration, because it may be the Z acceleration at the start of the probing move that causes the spurious triggering.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @dc42
        @dc42 said in Smart Effector issue:
        Tried R0.8 still the issue +++ Will not go down to bed on all points !!!
          Phaedrux Moderator @tecno
          @tecno said in Smart Effector issue:
          From where does this X=40.0, Y=60.0 coordinate originate?
          Assuming you're doing a G29 there, the grid spacing is determined by M557 in your config.g
          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
          • tecnoundefined
            tecno @Phaedrux
            @phaedrux said in Smart Effector issue:
            Thanks, now it gets a bit clearer.
            • Barracuda72undefined
              Barracuda72
              after watching our vid our prob are the short rods...but makeing the effector mount wider just makes it softer..more bending while probing. Other problen, that i had on my Delta with faulty sensivity..heatbreak came loose...so it looses lots of sensivity.
              About your Rods...when i designed my delta some years ago there where plently of sites to calculate things like Rod lenght...max angles of rods. Maybe DC42 still have some links to such a calculator. It would be much better to have longer rods..if its ok to loose some build height. Your construction is prone to effector tilts that affects the stability while probing
              tecnoundefined 1 Reply Last reply Reply Quote 1
              • tecnoundefined
                tecno @Barracuda72
                @barracuda72 said in Smart Effector issue:
                The rods and the adapter are original Dreammaker OverLord PRO, going back to a larger/wider effector (original adapter) made the situation better. Only trying to get this old Delta printer functional with a bit more modern parts.
                I am in a process of building a large Delta of 1.4m height and ~550mm print diameter, Rods 610mm long directly to Smart Effector via magnets.
                tecnoundefined Barracuda72undefined rjenkinsgbundefined 3 Replies Last reply Reply Quote 0
                • tecnoundefined
                  tecno @tecno
                  Can somebody show me how mesh.g is written? To be run with G29
                  Stephen6309undefined 1 Reply Last reply Reply Quote 0
                  • Stephen6309undefined
                    Stephen6309 @tecno
                    @tecno This is what I use.
                    ; mesh.g
                    ; called to load/make heightmap.csv
                    M98 P"/macros/ResetBabystepping"
                    M561       ; clear any bed transform
                    while iterations < #move.axes & move.axes[iterations].visible
                      if !move.axes[iterations].homed
                         G28
                         break
                    G29 S1        ; load heightmap.csv
                    if result > 1 ; make if it doesn't exist
                    	G29 S0
                    That {1} isn't in it.
                    • tecnoundefined
                      tecno @Stephen6309
                      @stephen6309 said in Smart Effector issue:
                      ; mesh.g
                           G28
                           break
                      	G29 S0
                      Not what I was looking for, below a mesh of small circles I want to probe But do not how to write that mesh.g file.
                        Barracuda72 @tecno
                        @tecno take a look at https://reprap.org/wiki/Delta_geometry and theres a minimum angle of the arms..and in your vid the angles looks smaller if you probe the outermost ppoints...and then you loose all the stability..for m it looks if the arms are too short or the build diameter is too big. make a small test and just probe with a smaller build plate diameter. Use http://www.escher3d.com/pages/wizards/wizardbed.php to get a bed.g and do the probing again...and look how stable the effector might be without probing in the air
                        • tecnoundefined
                          tecno @Barracuda72
                          With 80mm probe radius I have just under 30° angle on rods. So the angle is well over recommended 20° minimum.
                          Barracuda72undefined 1 Reply Last reply Reply Quote 0
                            Barracuda72 @tecno
                            @tecno in the vid..when you probe the oauter points the whol effector tilts..and dont trigger...i had the same...2 towers forces the effector on the buildplate and the 3rd tower cant stabilize it...mybe its a prob because we only have mag arms...im sure you need more than 20° if you use mag arms..
                            its easy to try a smaller bed diameter in the bed.g and make a test...
                            Its just the same probe that i had on my 300mm Delta
                            • tecnoundefined
                              tecno @Barracuda72
                              Medicine is M558 P8 R0.45 C"probe+servo0" H5 F3500 T2500
                              • tecnoundefined
                                tecno @tecno
                                ; mesh.g
                                     G28
                                     break
                                	G29 S0
                                G29 Run file sys/mesh.g, or if that file isn't found then do G29 S0
                                How is that file written?
                                • achrnundefined
                                  achrn
                                  I don't think it works like that.
                                  For mesh bed compensation you can't probe at arbitrary positions, you probe on the regular grid defined in M557.
                                  Mesh.g is not for defining the probe points. As I understand it, it's for use if you have a sequence of commands you need to run to do bed probing (e.g. activate or pick up a probe).
                                  I think you may be conflating or confusing mesh bed compensation with delta automatic calibration which uses a bed.g that does contain points to probe. Which is it that you are attempting?
                                  • tecnoundefined
                                    tecno @achrn
                                    @achrn said in Smart Effector issue:
                                    G32 is no problems (bed.g)
                                    G29 can not reach all points
                                    • tecnoundefined
                                      tecno @tecno
                                      a82797e0-5867-465d-ade4-6a5c86c43e66-image.png @tecno
                                      Manual is clear as MUD
                                      Not one word what can be in that file to be found!
                                      A Former User? achrnundefined 2 Replies Last reply Reply Quote 0
                                        A Former User @tecno
                                        This post is deleted!
                                        • achrnundefined
                                          achrn @tecno
                                          @tecno "can not reach all the points" seems to be a different complaint from probe sensitivity. Is that now the problem you are now trying to resolve? If it is the location of the points, what matters is your M557 - what M557 command do you have?
                                          • tecnoundefined
                                            tecno @A Former User
                                            @arnold_r_clark said in Smart Effector issue:
                                            Im afraid that is not true.
                                            There 100% IS an example of what can be in a mesh.g file, it is shown in the docs which can be found HERE
                                            If you scroll down to the G29 command it lists what each "switch" for the command does and it also shows an example of what said mesh.g file can contain.
                                            OK
                                            Then I have to excuse me not understanding English that well.
                                            Anywho my problem still exist with can not reach
