Strange Behavior , after "Pause" 'Cancel ""print again"
Beta Firmware
1.9k
    moth4017
    Duet 3+mini5
    DWC RC2
    RRP RC2
    im get a Strange Behavior on bed leveling after "Pause" 'Cancel ""print again"
    When the bed tries to do the 3 Point leveling the Z motors seem to be in a low current mode and are skipping steps.
    M550 P"Valkyrie 3030 V001" ; set printer name
    M669 K1 ; core xy
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0.0 S1 ; physical drive 0 goes forwardsM569 P0.1 S1
    M569 P0.1 S1 ; physical drive 1 goes forwardsM569 P0.1 S1
    M569 P0.2 S1 ; physical drive 2 goes forwards ( blown needs replacing)
    M569 P0.3 S1 ; physical drive 3 goes forwards (extruder
    M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop
    M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards
    M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwards
    M584 X1 Y0 E3 Z0.4:0.5:0.6 ; set drive mapping FL,FR,RC
    M350 X16 Y16 I1 ; configure microstepping with interpolation
    M350 Z16 E16 I1
    M92 X80.00 Y80.00 Z320.00 E260.00 ; set steps per m
    M566 X500.00 Y500.00 Z800.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min)
    M203 X8000.00 Y8000.00 Z1000.00 E400.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z200.00 E250.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1400 I10 ; set motor currents (mA) and motor idle factor in per cent
    M84 S20 ; Set idle timeout
    M208 X0 Y0 Z0 S1 ; set axis minima "Travel Area"
    M208 X270 Y240 Z405 S0 ; set axis maxima "Travel area"
    M574 X1 S1 P"!io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
    M574 Y2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
    ;M574 Z2 S2 P"!io4.in" ; != invert signal
    M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
    M671 X-34.4:296:132.5 Y0:0:296 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584
    M558 P8 C"!io3.in" H5 F600 T18000 A30 S0.03 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 Z0.9 ; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
    G31 P500 X26 Y6 ; set x,y trigger value, offset and trigger height
    M557 X30:270 Y10:250 S40 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T°C" ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"out0" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 R0.140 K0.103:0.000 D43.19 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
    M308 S1 P"temp1" Y"thermistor" T100000 B4267 A"Extruder T°C" ; configure sensor 1 as thermistor on pin e0temp (104gt2)
    M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 R3.435 K0.348:0.274 D6.64 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit
    M950 F0 C"out4" Q500 ; create fan 0 on pin fan0 and set its frequency
    M950 F1 C"out3" Q500 ; create fan 1 on pin fan1 and set its frequency
    M98 P/macros/3zhome
    ;3zhome
    M400
    M569 P0.4:0.5:0.6 V10
    G4 P100
    M574 Z2 S4
    M906 Z300 ; set motor current
    G91 ; relative positioning
    G1 H2 Z0.2 F3000 ; power up motors to ensure they are not stalled
    G4 P100 ; wait 100ms
    M400 ; wait for current moves to finish
    G4 P200
    M915 P0.4:0.5:0.6 S0 H10 F0 R0 ; Configure Z-Axis Stall Detection
    G4 P200
    G1 F4000
    G1 H1 Z350 ; Home Z-Axis actuators independently
    M400 ; make sure everything has stopped before we make changes
    M906 Z600 ; Reset motor current
    G90 ; absolute positioning
    G92 Z301 ; set position
    G91 ; relative positoning
    M84 ; Motors off
    undefined undefined 2 Replies Last reply 6 Mar 2022, 08:04 Reply Quote 0
      OwenD @moth4017
      @moth4017
      It would help if you post the contents of pause.g, cancel.g, stop.g and your start gcode
      Use the </> button so that we can easily scroll through the contents.
      undefined 1 Reply Last reply 7 Mar 2022, 08:01 Reply Quote 1
        moth4017 @OwenD
        @owend
        ; pause.g
        ; called when a print from SD card is paused
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 11:07:38 GMT+1300 (New Zealand Daylight Time)
        M83 ; relative extruder moves
        G1 E-10 F3600 ; retract 10mm of filament
        G1 Z5 F360 ; lift Z by 5mm
        G1 X0 Y0 F6000 ; go to X=0 Y=0
        ; stop.g
        ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
        No Cancel.g
        Start script
        M104 S[first_layer_temperature] ; set extruder temp
        M109 S[first_layer_temperature] ; wait for extruder temp
        G28 ; home all
        undefined undefined 2 Replies Last reply 7 Mar 2022, 09:24 Reply Quote 0
          OwenD @moth4017
          @moth4017
          I don't see anything out of the ordinary in those files.
          Your M569 V parameter seems very low compared to the documentation, but I've never used that so I don't know enough to comment.
            gloomyandy @moth4017
            @moth4017 What current are you expecting the steppers to be set to? Your home z seems to leave it set to 600mA (which is significantly lower than the 1000mA initially set in config.g). You might want to try running M906 from the console before your initial print and then after you have hit pause and again after cancel to see what current is set at the various stages.
            Not totally sure if it will help but you might also want to reconfigure the stall threshold to be higher after you have completed your homing just in case that is causing problems.
            I notice that you also have M84 at the end of your zhome code, this is unusual. What are you expecting it to do?
            undefined 1 Reply Last reply 7 Mar 2022, 10:12 Reply Quote 0
              moth4017 @gloomyandy
              @gloomyandy
              Hi i have also tried setting current to 1000ma still the same issue.
              Ill try the M906 later
              M84 is at the end of the home Z as i send the bed to Max Z and then turn off the motors ,
                I think what's happening is that you're moving the Z axis to the max position and reducing the current. When it tries to move again it's stalling or maybe binding.
                Return your motor current to normal before trying to move the axis again and see if it's able to move.
                undefined 1 Reply Last reply 8 Mar 2022, 04:02 Reply Quote 0
                  moth4017 @Phaedrux
                  @phaedrux
                  Hi when i do "pause print" "cancel" "print again" the bed has remained at the top position so it has not done the sensorless homing at Z max
                    Phaedrux Moderator @moth4017
                    @moth4017 said in Strange Behavior , after "Pause" 'Cancel ""print again":
                    No Cancel.g
                    Can you create a cancel.g file? Either put in some commands you want to happen when the print is canceled, or leave it blank for it to do nothing. The default cancel behaviour may be your problem.
                    https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m0-stop-or-unconditional-stop
                    undefined 2 Replies Last reply 9 Mar 2022, 06:22 Reply Quote 0
                      moth4017 @Phaedrux
                      @phaedrux
                      i should have done this before sorry
                      in the console when i press "print again"
                      i get these error messages
                      Error: Homing failed
                      Error: Driver 0.4 error: over temperature shutdown
                      Error: Driver 0.5 error: over temperature shutdown
                      Warning: Driver 0.4 warning: over temperature warning
                      undefined 1 Reply Last reply 9 Mar 2022, 08:31 Reply Quote 0
                        @moth4017 Did you try running M906 so that you can see what current setting the drivers are using when they generate errors?
                        undefined 1 Reply Last reply 9 Mar 2022, 08:49 Reply Quote 0
                          @gloomyandy
                          M906 pre test X,y,Z 1000ma
                          after Cancel print
                          M906Motor current (mA) - X:1000, Y:1000, Z:1000, E:1400, idle factor 10%
                          undefined 1 Reply Last reply 9 Mar 2022, 09:03 Reply Quote 0
                            @moth4017 Very odd? Do you always get those driver temperature errors when you have this problem?
                            undefined 1 Reply Last reply 9 Mar 2022, 09:15 Reply Quote 0
                              @gloomyandy
                              Hi Yes , but i can print ok if i send new G code , it only hppend after the above sequency
                                moth4017 @Phaedrux
                                @phaedrux
                                If i add the cancel.g file when pressing "cancel" button the cancel.g file does not run, cancel.g file in system directory
                                ;cancel.g
                                M98 P/macros/home_max_Z
                                ; home_max_Z
                                ;G91 ; relative positioning
                                ;;M915 P0.4:0.5:0.6 S3 F0 R0 ; Configure Z-Axis Stall Detection
                                ;M913 Z80 ; Lower motor current by 50%
                                ;M574 Z2 S4 ; Configure Z-Axis stall detection homing
                                M98 P/macros/sensorless_Z
                                G1 F3000 ;
                                M913 Z100 ; Reset motor current
                                G92 Z290
                                ;sensorless_z
                                M906 Z300 ; Lower motor current by 50%
                                M906 Z1000 ; Reset motor current
                                M400
                                undefined 1 Reply Last reply 15 Mar 2022, 19:23 Reply Quote 0
                                  Can you share the results of sending M122 and M98 P"config.g" ?
                                  undefined 2 Replies Last reply 10 Mar 2022, 22:01 Reply Quote 0
                                    moth4017 @Phaedrux
                                    @phaedrux ```
                                    3/11/2022, 11:01:06 AM M122
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc2 (2022-02-22 17:07:31) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
                                    Used output buffers: 3 of 40 (15 max)
                                    Static ram: 103652
                                    Dynamic ram: 110396 of which 0 recycled
                                    Never used RAM 27592, free system stack 132 words
                                    Tasks: NETWORK(ready,49.2%,228) HEAT(notifyWait,0.1%,356) Move(notifyWait,0.0%,292) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,3.6%,114) MAIN(running,44.5%,428) IDLE(ready,0.0%,29) AIN(delaying,2.5%,264), total 100.0%
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 02:17:44 ago, cause: power up
                                    Last software reset at 2022-03-09 19:21, reason: User, GCodes spinning, available RAM 24040, slot 2
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                    Error status: 0x00
                                    MCU revision 3, ADC conversions started 8264987, completed 8264987, timed out 0, errs 0
                                    Step timer max interval 754
                                    MCU temperature: min 28.5, current 30.2, max 32.7
                                    Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    Events: 0 queued, 0 completed
                                    Driver 0: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 30414, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 30414, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: pos 96320, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 30414, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: pos 0, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 30413, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: pos 0, standstill, SG min 174, read errors 0, write errors 0, ifcnt 16, reads 30407, writes 16, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 5: pos 0, standstill, SG min 16, read errors 0, write errors 0, ifcnt 16, reads 30407, writes 16, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 6: pos 0, standstill, SG min 26, read errors 0, write errors 0, ifcnt 16, reads 30407, writes 16, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2022-03-11 11:01:05
                                    Slowest loop: 5.52ms; fastest: 0.13ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 14.1ms, write time 0.0ms, max retries 0
                                    DMs created 83, segments created 3, maxWait 624ms, bed compensation in use: none, comp offset 0.000
                                    === MainDDARing ===
                                    Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    === AuxDDARing ===
                                    Segments left: 0
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    SBC is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Aux2 is idle in state(s) 0
                                    Code queue is empty
                                    === CAN ===
                                    Messages queued 74382, received 0, lost 0, boc 0
                                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 41325/0/0
                                    Tx timeouts 0,0,41324,0,0,33056 last cancelled message type 30 dest 127
                                    === Network ===
                                    Slowest loop: 16.87ms; fastest: 0.00ms
                                    HTTP sessions: 1 of 8
                                    • WiFi -
                                      Network state is active
                                      WiFi firmware version 1.25
                                      WiFi MAC address f0:08:d1:02:a1:0b
                                      WiFi Vcc 3.34, reset reason Power up
                                      WiFi flash size 2097152, free heap 25512
                                      WiFi IP address 192.168.0.19
                                      WiFi signal strength -49dBm, mode 802.11n, reconnections 0, sleep mode modem
                                      Clock register 00002002
                                    HTTP is enabled on port 80
                                    FTP is disabled
                                    TELNET is disabled
                                      moth4017 @Phaedrux
                                      @phaedrux
                                      hi any thourghts?
                                        @phaedrux
                                        ;cancel.g
                                        ; home_max_Z
                                        G1 F3000 ;
                                        G92 Z290
                                        ;sensorless_z
                                        M400
                                        Can you try a simplified cancel.g? Maybe just a G28 XY
                                        undefined 1 Reply Last reply 16 Mar 2022, 06:58 Reply Quote 0
                                          moth4017 @Phaedrux
                                          @phaedrux
                                          ;cancel.g
                                          G28 X Y
                                          The console displayed this after cancel print:-
                                          M0
                                          Printing paused at X128.9 Y78.9 Z0.3
                                          Cancelled printing file 0:/gcodes/shark-v2-0-a_0.35mm_PLA__2h32m.gcode, print time was 0h 5m
                                          the Cancel.g file didnt run, so i put "G28 X Y" in the command line , this ran perfectly , but then i got this error in the console , only happens when i do the "Cancel"
                                          3/16/2022, 7:56:33 PM Error: Driver 0.4 error: over temperature shutdown
                                          3/16/2022, 7:56:33 PM Emergency stop, attemping to reconnect...
                                          3/16/2022, 7:56:31 PM Error: Driver 0.6 error: over temperature shutdown
                                          3/16/2022, 7:56:31 PM Error: Driver 0.5 error: over temperature shutdown
                                          3/16/2022, 7:56:30 PM Error: Driver 0.4 error: over temperature shutdown
                                          5 out of 47
