Correction of heightmap is not really working
6.9k
    ICY_SNAKE @fcwilt
    @fcwilt Good morning frederick,
    back to my calibration problem.
    I run now the button on the display for leveling.
    head moves to all 4 corners and than to the middle and stays there.
    <G32
    Leadscrew adjustments made: 0.040 0.051 0.023 0.047, points used 4, (mean, deviation) before (0.039, 0.007) after (0.000, 0.000)>
    if i do g28 than
    i get the following error message:
    <G28
     Error: in file macro line 8: G30: Z probe 0 not found>
    If i hit the button HOME ALL
    <Error: in file macro line 7: G30: Z probe 0 not found
     Error: Homing failed
    my homeall.g
    <M280 P0 S60 I1
     G91                    			; relative positioning
     G1 H2 Z5 F200          			; lift Z relative to current position
    G1 H1 X-605 Y605 F3000 			; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y-5 F600      			; go back a few mm
    G1 H1 X-605 Y605 F600  			; move slowly to X and Y axis endstops once more (second pass)
    G90                    			; absolute positioning
    G30                    			; home Z by probing the bed>
    Dieter
    DO IT OR DON'T
    undefined 1 Reply Last reply 19 Feb 2022, 15:13 Reply Quote 0
      fcwilt @ICY_SNAKE
      @icy_snake
      Please post you current files:
      • config.g
      • config_probe.g
      • bed.g
      In your homeall.g file you are not moving to the center of the bed before doing the G30 to home. That is not the cause of the error messages but it should be added.
      undefined 1 Reply Last reply 19 Feb 2022, 15:25 Reply Quote 0
        ICY_SNAKE @fcwilt
        @fcwilt hello frederick,
        here are my files:
        config.g
        <; General preferences_________________________________________________________
        G90                                             			; send absolute coordinates...
        M83                                             			; ...but relative extruder moves
        M111 S0 													; Debug off
        M555 P2 													; Set output to look like Marlin
        M575 P0 B57600 S2               							; communication parameters for USB serial
        M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDue)
        ; Network_____________________________________________________________________
        M550 P"Big 60X V3.4 15.02.2022"                        		; set printer name
        ; History
        ; removed U  15.02.2022
        M552 S1                                        				; enable network
        M552 P192.168.10.169										; My IP Address
        M586 P0 S1                                      			; enable HTTP
        M586 P1 S0                                      			; disable FTP
        M586 P2 S0                                      			; disable Telnet
        ; add probe file
        ; global.g_probe_z_trigger
        ; global.g_probe_z_trigger = 2.915 ; default - set as appropriate for the Z probe
        M98 P"config_probe.g"
        M556 S50 X0 Y0 Z0		                               		; set orthogonal axis compensation parameters woher kommt der test wie wurde der Winkel bestimmt Unklar!
        M376 H10													; stop z-leveling after 10 layers
        ; Drives_________________________________________________________________________
        ;Main board______________________________________________________________________
        M569 P0 S1                                                     		; Physical drive 0 . X1
        M569 P1 S0                                                       	; Physical drive 1 . X2
        M569 P2 R-1                                                        	; Physical drive 2 . Canceled
        M569 P3 S1                                                       	; Physical drive 3 . Main Extruder
        M569 P4 S0                                                       	; Physical drive 4 . Secondary Extruder
        ;Duex5 board_____________________________________________________________________
        M569 P5 S0                                                       	; Physical drive 5 . Y
        M569 P6 S0                                                       	; Physical drive 6 . Z1 (0,1000)
        M569 P7 S0                                                       	; Physical drive 7 . Z2 (0,0)
        M569 P8 S0                                                       	; Physical drive 8 . Z3 (1000,0)
        M569 P9 S0                                          ; Physical drive 9 . Z4 (1000,1000)
        ;Settings_________________________________________________________
        M584 X0:1 Y5 Z6:7:8:9 E3:4 P3						; Driver mapping
        ; M671 X-189:-189:645:645 Y645:-64:-64:645 S10  		; Anticlockwise old
        ; M671 X-168:-168:655:655 Y655:-64:-64:655 S10  		; Anticlockwise
        M671 X-168:-168:645:645 Y645:-64:-64:645 S10 ; Anticlockwise
        ;___________________________________________________________________
        M350 X16 Y16 I1  		                           		; Configure microstepping with interpolation
        M350 Z16 E16:16 I0              		               	; Configure microstepping without interpolation
        M92 X100.00 Y100.00 Z1969.60 E416.21:416.21 	      	; Set steps per mm changed to fit my values 100mm messen und eintragen
        M566 X240 Y360 Z30.00 E120.00:120.00 P1          		; Set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z200.00 E1200.00:1200.00    		; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z120.00 E250.00:250.00             	; Set accelerations (mm/s^2)
        M204 P500                                      			; Set print and travel accelerations  (mm/s^2)
        M906 X1800 Y1800.00 E1000.00:1000.00 I40 				; Set motor currents (mA) and motor idle factor in per cent
        M906 Z1800.00 I50 										; Set motor currents (mA) and motor idle factor in per cent
        M84 S100 X Y E0 E1                                		; Set idle timeout - one minute
        M208 X0 Y0 Z-1 S1                               		; set axis minima
        M208 X600 Y600 Z630 S0                          		; my print area, changed to hight 630 do changes
        M574 X1 S1 P"xstop + e0stop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
        M574 Y2 S1 P"ystop"                            			; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
        		                					; Height (mm) over which to taper off the bed compensation 10, 30
        ; Heaters___________________________________________________________
        M140 H-1                                       			; disable heated bed (overrides default heater mapping)
        ;E0_________________________________________________________________
        M308 S0 P"spi.cs1" Y"rtd-max31865"
        M950 H0 C"e0heat" T0                            		; create nozzle heater output on e0heat and map it to sensor 0
        M307 H0 B0 R3.818 C129.1:116.6 D3.00 S1.00 V23.9		;New TAKOTO mit Wärmeleitpaste
        M143 H0 S300                                 			; set temperature limit for heater 0 to 300°
        ;E1_________________________________________________________________
        M308 S1 P"spi.cs2" Y"rtd-max31865"
        M950 H1 C"e1heat" T1                            		; create nozzle heater output on e1heat and map it to sensor 1
        M307 H1 B0 R3.746 C151.8:132.3 D3.63 S1.00 V23.9		; NEW TAKOTO
        M143 H1 S300         	                        		; set temperature limit for heater 1 to 300°
        ; Fans______________________________________________________________
        M950 F0 C"fan0" Q500                            		; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                  		; set fan 0 value. Thermostatic control is turned on
        M950 F1 C"fan1" Q500                            		; create fan 1 on pin fan1 and set its frequency
        M106 P1 S0 H-1                                  		; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"duex.fan7" Q500                            	; create LED on pin fan2 and set its frequency
        M106 P2 S0 H-1                               			; Disable fan channel for LED
        M950 F3 C"duex.fan5" Q500                       		; create fan 3 on pin fan1 and set its frequency
        M106 P3 S255 H0 T45                             		; set fan 3 value. Thermostatic control is turned on
        M950 F4 C"duex.fan6" Q500                       		; create fan 4 on pin fan1 and set its frequency
        M106 P4 S255 H1 T45                             		; set fan 4 value. Thermostatic control is turned on
        ; Tools______________________________________________________________
        ;T0_________________________________________________________________
        M563 P0 S"E0 Primary" D0 H0 F0                  		; define tool 0
        G10 P0 X0 Y0 Z0                                 		; set tool 0 axis offsets
        G10 P0 R0 S210                                  		; set initial tool 0 active and standby temperatures to 0C
        ;T1_________________________________________________________________
        M563 P1 S"E1 Secondary" D1 H1 F1                		; define tool 1
        G10 P1 X0 Y49 Z0                                		; set tool 1 axis offsets
        G10 P1 R0 S210                                    		; set initial tool 1 active and standby temperatures to 0C
        ; Automatic power saving____________________________________________
        M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"  ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
        ; Custom settings__________________________________________________
        M950 J0 C"exp.e2stop"  					  				; create Input Pin 0 on pin E2 to for M581 Command.
        M581 T1 P0 S0 R1										; Regular filament sensor for E0 As External Trigger
        M950 J1 C"exp.e3stop"  					  				; create Input Pin 1 on pin E3 to for M581 Command.
        M581 T1 P1 S0 R1										; Regular filament sensor for E1 As External Trigger
        M950 J2 C"exp.e4stop"  					  				; create Input Pin 2 on pin E4 to for M581 Command.>
        Here is my config_Probe.g
        <; probe_config.g
        ; config the probe and call the other files.g
        M950 S0 C"duex.pwm5"
        M558 P9 C"zprobe.in" H5 F120 T6000 A5 R0.7
        ; G31 P500 X-18 Y24 Z{global.g_probe_z_trigger} ; set Z probe trigger value, offset and trigger height (larger value is closer)
        ; change to zvalue global.g_probe_z_trigger did not work
        G31 P500 X-25 Y37 Z2.915 ; set Z probe trigger value, offset and trigger height (larger value is closer)
        Here is my bed.g
        <; bed.g
        M98 P"config_probe.g"        ; insure probe is using most recent configuration values
        G29 S2                       ; cancel mesh bed compensation
        M290 R0 S0                   ; cancel baby stepping
        G90                          ; absolute moves
        G1 Z5 F99999                 ; insure Z starting position is high enough to avoid probing errors
        ; M671: Define positions pf manual bed levelling screws or Z leadscrews
        ; Xnn:nn:nn... list of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed levelling screws
        ; Ynn:nn:nn... list of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed levelling screws
        ; Snn          maximum correction allowed for each leadscrew in mm (optional, default 1.0)
        ; Pnnn         pitch of the bed levelling screws (not used when bed levelling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed levelling screws
        ; Fnn          fudge factor, default 1.0
        ; --- level bed ---
        while true
          ; run leveling pass
          G30 P0 X10   Y40  Z-99999    ; Probe near a leadscrew
          G30 P1 X600 Y40  Z-99999    ; Probe near a leadscrew
          G30 P2 X600 Y620 Z-99999    ; Probe near a leadscrew
          G30 P3 X10   Y620 Z-99999 S4 ; Probe near a leadscrew
          if move.calibration.initial.deviation < 0.015
            break
          ; check pass limit - abort if pass limit reached
          if iterations = 5
            M291 P"Bed Leveling Aborted" R"Pass Limit Reached"
            abort "Bed Leveling Aborted - Pass Limit Reached"
        ; --- finish up ---
        ; --- set Z=0 datum which can be affected by leveling ---
        G1 X300 Y300 ; move probe to center of bed - set values aaa and bbb as appropriate
        G30          ; do single probe which sets Z to trigger height of Z probe
        G31 >
        thx dieter
        DO IT OR DON'T
        undefined 1 Reply Last reply 19 Feb 2022, 15:39 Reply Quote 0
          fcwilt @ICY_SNAKE
          @icy_snake
          Let's add the M98 P"config_probe.g" to your home all file right before the G30 and see if that makes a difference.
          It shouldn't since you are calling config_probe.g in your config.g but let's make the change and test it.
          undefined 1 Reply Last reply 19 Feb 2022, 16:17 Reply Quote 0
            ICY_SNAKE @fcwilt
            @fcwilt
            hello,
            works,
            1. we had a mismatch config_probe.g against probe_config.g
            2. with the variable Z{global.g_probe_z_trigger} it´s not working
            as soon as i add a value for z it works.
            DO IT OR DON'T
            undefined 1 Reply Last reply 19 Feb 2022, 16:55 Reply Quote 0
              fcwilt @ICY_SNAKE
              @icy_snake said in Correction of heightmap is not really working:
              @fcwilt
              hello,
              works,
              As @Phaedrux pointed out the Z trigger height should be the same regardless of which buildplate is in use.
              But using a variable doesn't hurt if you want to be able to easily change the Z trigger height without stopping to edit a file.
              I verified that using a variable works but it is required that the variable be created in config.g before any attempt to use it.
              I think I recall you initially declared it after the call to config_probe.g (the file name doesn't matter - if you prefer another name just check that you use the same name everywhere.
              undefined 1 Reply Last reply 20 Mar 2022, 16:14 Reply Quote 0
                Sculpt Fabricator @fcwilt
                @fcwilt This has been great, I am having the exact same problems as @ICY_SNAKE with the same machine. V3.3, I have followed and made all the same changes.
                But I am having a Errror: in file macro line 6 column 43: G31 : unknown
                variable 'g_probe_z_trigger"
                I don't understand what that is ?
                undefined 1 Reply Last reply 20 Mar 2022, 17:48 Reply Quote 0
                  fcwilt @Sculpt Fabricator
                  @sculpt-fabricator said in Correction of heightmap is not really working:
                  Did you create the variable in your config.g file as I specified in my example?
                  undefined 2 Replies Last reply 20 Mar 2022, 20:50 Reply Quote 0
                    @fcwilt
                    Here is my Config.g
                    G21 														; dimentions in mm
                    G90                                             			; for X,Y,Z     use absolute coordinate values
                    M83                                             			; for E0,E1,etc use relative coordinate values
                    M111 S0 													; Debug off
                    M550 P"Big 60"                         						; set printer name
                    M552 S1                                        				; enable (S1) networking (WiFi)
                    M586 S1 P1 ;T0                 								; enable (S1) FTP    (P1) Disable TLS (T0)
                    M586 S1 P2 ;T0                								; enable (S1) Telnet (P2) Disable TLS (T0)
                    ;;M586 P0 S1                                      			; enable HTTP
                    ;;M586 P1 S0                                      			; disable FTP
                    ;;M586 P2 S0                                      			; disable Telnet
                    ; mode control variables _____________________________________________________
                    global g_z_home            = 5                  ; can be used to always move Z to known height
                    global g_z_datum_set       = false              ; can be used to prevent unneeded setting of Z=0 datum
                    global g_map_mode          = "300 point"        ; determines which kind of height map is created/loaded
                    global g_probe_mode        = "two consecutive"  ; determines if z proving used consecutive or averaging
                    global g_level_mode        = "4 point"          ; determines if 3 or 4 points are used for leveling
                    global g_print_beg_prime   = 10                 ; default - set desired in filament config.g
                    global g_print_beg_retract = 0                  ; default - set desired in filament config.g
                    global g_print_end_retract = 0                  ; default - set desired in filament config.g
                    global g_print_end_mode    = "heat off"         ; determines if heaters are turned off when print is done
                    M569 P0 S0                                                          ; Physical drive 0 . X1
                    M569 P1 S1                                                          ; Physical drive 1 . X2
                    M569 P6 S0                                                       	; Physical drive 6 . Z1 (0,0)
                    M569 P7 S0                                                       	; Physical drive 7 . Z2 (600,0)
                    M569 P8 S0                                                       	; Physical drive 8 . Z3 (600,600)
                    M569 P9 S0                                                       	; Physical drive 9 . Z4 (0,600)
                    M584 X0:1 Y5 Z6:7:8:9  E3:4 P3								   	    ; Driver mapping                                                  U1
                    ;;M671 X-190:-190:641:641 Y-63:643:643:-63 S10    	                ; Anticlockwise
                    M350 X16 Y16 I1  		                            				; Configure microstepping with interpolation                      U16
                    M92 X100.00 Y100.00 Z2000.00 E686:700       				        ; Set steps per mm                                                U100.00
                    M566 X300 Y500 Z100.00 E120.00:120.00  P1               		    ; Set maximum instantaneous speed changes (mm/min)                U240
                    M203 X18000.00 Y18000.00 Z300.00 E1200.00:1200.00           		; Set maximum speeds (mm/min)                                     U9000.00
                    M201 X1000 Y1000 Z120.00 E250.00:250.00                  			; Set accelerations (mm/s^2)                                      U1000
                    ;M566 X240 Y360 Z30.00 E120.00:120.00 U240 P1               	    ; Set maximum instantaneous speed changes (mm/min)
                    ;M203 X9000.00 Y9000.00 Z200.00 E1200.00:1200.00 U9000.00    		; Set maximum speeds (mm/min)
                    ;M201 X1000 Y1000 Z120.00 E250.00:250.00 U1000             			; Set accelerations (mm/s^2)
                    M906 X1800 Y1800.00 E1270:1270  I40 					        	; Set motor currents (mA) and motor idle factor in per cent (E1270 per dyze)   U1800
                    M84 S100                                          					; Set idle timeout - 100 seconds
                    M208 X590 Y580 Z630 S0                          					; set axis maxima
                    ;;M574 X1 S1 P"xstop"                            			; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    ;;M574 U1 S1 P"e0stop"                            			; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    ; add probe file
                    ; global.g_probe_z_trigger = 1.9                         ; default - set as appropriate for the Z probe
                    M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1  					; set Z probe type to bltouch and the dive height + speeds
                    M950 S0 C"duex.pwm5"										; set probe pin
                    ;M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1  					; set Z probe type to bltouch and the dive height + speeds
                    ;M950 S0 C"duex.pwm5"										; set probe pin
                    ;M98 P"config_probe.g"										; configure probe after a reboot or reset
                    ;global g_probe_z_trigger   = 1.8                            ; default - set as appropriate for the Z probe
                    ;;G31 P500 X-30 Y0 Z2.64                 			  		; set Z probe trigger value, offset and trigger height    **** Z height change + 0.29 ****
                    ;;M556 S50 X0 Y0 Z0                               			; set orthogonal axis compensation parameters
                    ;;M557 X0:560 Y0:580 S90:108.75              			   	; define mesh grid and probe points, fine S30:36.25
                    ;;M376 H10			                						; Height (mm) over which to taper off the bed compensation
                    ;M308 S0  P"bedtemp" Y"thermistor" A"Bed Heat"  T100000 B3950 ; define bed temperature sensor
                    ;M950 H0  C"bedheat" T0 Q10                                      ;heater 0 uses the bed_heat pin, sensor 0, PWM 10hz
                    M308 S0 P"spi.cs1" Y"rtd-max31865" A"Main Extruder"         ; create sensor number 1 as a PT100 sensor in first position daughterboard
                    M307 H0 B0 R2.004 C403.6:385.3 D14.93 S1.00 V23.8          ; PID calibration
                    M143 H0 S450                                    			; set temperature limit for heater 0 to 450C
                    M308 S1 P"spi.cs2" Y"rtd-max31865" A"Support Extruder"    	; create sensor number 2 as a PT100 sensor in sec position daughterboard
                    ;M950 H1 C"e1heat" T1                            			; create nozzle heater output on e1heat and map it to sensor 1				TEMP OFF
                    ;M307 H1 B0 S1.00                               			; PID calibration															TEMP OFF
                    ;M143 H1 S450                                   			; set temperature limit for heater 1 to 450C								TEMP OFF
                    ;E4_________________________________________________________________
                    M308 S1 P"duex.e4temp" Y"thermistor" T100000 B4267   			; configure sensor 1 as thermistor on pin e1temp
                    M950 H5 C"duex.e4heat" T1                            			; create nozzle heater output on e4heat and map it to sensor 4
                    ;M307 H5 B0 S1.00                               			     ; PID calibration
                    M143 H5 S120                                  			    ; set temperature limit for heater 1 to 120C
                    ; Fans & LED___________________________________________________________
                    M950 F2 C"fan2" Q500                            			; create air filter fan on fan 2 on pin fan2 and set its frequency
                    M106 P2 S0 H-1                                  			; set fan 2 value. Thermostatic control is turned on
                    M950 F7 C"!duex.fan7" Q500                            		; create LED on pin fan7 and set its frequency
                    M106 P7 S0 H-1                               				; Disable fan channel for LED
                    M106 P7 S255							                    ; remove ";" to set the LED to full brightness by default
                    M950 F3 C"duex.fan3" Q500                       			; create fan 3 on pin fan3 and set its frequency
                    M106 P3 S1 H-1                           			; set fan 3 value. Thermostatic control is turned on Bed relay to on
                    M563 P0 S"E0 Main" D0 H0 F0                  			; define tool 0
                    G10 P0 R0 S265                                  			; set initial tool 0 active and standby temperatures to 0C
                    M563 P1 S"E1 Support" D1 H1 F1                			; define tool 1
                    G10 P1 X0 Y65 Z0                                			; set tool 1 axis offsets  Y-2 moves filament 2mm to back of machine     X-1 moves filament 1mm to the right
                    G10 P1 R0 S265                                    			; set initial tool 1 active and standby temperatures to 0C
                    ;T2____________________________________________________________________
                    ;M563 P2 S"BED TEMP" H-1																												;Temp off
                    ;G10 P2 																																;Temp off
                    ;T3___________________________________________________________________
                    M563 P3 S"CHAMBER TEMP" H5
                    G10 P3 R0 S40
                    M591 D0 P1 C"duex.e2stop" S1							; Regular filament sensor for E0
                    M591 D1 P1 C"duex.e3stop" S1							; Regular filament sensor for E1
                    ;M950 P2 C"fan2" Q500
                    M42 P2 S255 											; Start up air filter
                    undefined 1 Reply Last reply 20 Mar 2022, 21:09 Reply Quote 0
                      @fcwilt
                      I am just not picking up this coding. I have spent 5 days straight on this.
                      Question - So when a Error pops up it is there to tell you there is a problem and to point you in the direction of the problem to fix the issue, I assume ?
                      So, when I get a -
                      Error: in file macro line 44 column 10: meta command: 'break' was not inside a loop
                      How do I know what macro, and column is the spot on line 10?
                      undefined 1 Reply Last reply 20 Mar 2022, 21:13 Reply Quote 0
                        @sculpt-fabricator
                        Amazing.
                        What are the odds you would have global variables with the exact same names as mine. 😉
                        In any case the variable mentioned in the error appears more than once in your config.g file but they are all commented out.
                        Enable the second one (the one with 1.9) by removing the comment character.
                        Also I see these two commands:
                        They should be moved to your config_probe.g file. If they are already in that file simply remove them from your config.g file.
                          @fcwilt
                          So, when I get a -
                          Well I test each macro as I code it so I know which macro is creating the error. Then since the error messages tells me what line and column I can focus in on the error.
                          I don't move on to some other coding until the macro is error free.
                          Do you have a bed.g file?
                          If so post it here, please.
                          undefined 1 Reply Last reply 20 Mar 2022, 21:19 Reply Quote 0
                            @fcwilt
                            Ok so me making 100 changes at once is not good ! LOL
                            ;M98 P"config_probe.g"        ; insure probe is using most recent configuration values
                            ; --- level bed ---
                             while true
                            ; run leveling pass
                            G30 P0 X10 Y10 Z-99999      ; probe near a leadscrew
                            G30 P1 X570 Y10 Z-99999     ; probe near a leadscrew
                            G30 P2 X570   Y570   Z-99999     ; probe near a leadscrew
                            G30 P3 X10   Y570   Z-99999 S4  ; probe near a leadscrew and calibrate 4 motors
                               if move.calibration.initial.deviation < 0.02
                                break
                               if iterations = 5
                             ; --- finish up ---
                             G1 X270 Y270 ; move probe to center of bed - set values aaa and bbb as appropriate
                            ; config_probe.g
                            G31 P25 X-30 Y0 Z1.688 ; set Z probe trigger value, offset and trigger height (larger value is closer)G31 P500 X-18 Y24 Z2.917
                            undefined 1 Reply Last reply 20 Mar 2022, 21:20 Reply Quote 0
                              Sculpt Fabricator @Sculpt Fabricator
                              that is my bed.g
                              and config_probe.g
                              undefined 1 Reply Last reply 20 Mar 2022, 21:24 Reply Quote 0
                                that is my bed.g
                                and config_probe.g
                                OK your config_probe.g file looks good. So remove the commands I mentioned from config.g
                                Please upload your bed.g file using the "upload file" tag. I will edit it to correct the errors.
                                You simply have not used the required indentation.
                                undefined 3 Replies Last reply 20 Mar 2022, 21:30 Reply Quote 0
                                  Got the lines changed in the config.g
                                  Here is the bed.g
                                  bed.g
                                  undefined 1 Reply Last reply 20 Mar 2022, 22:53 Reply Quote 0
                                    @fcwilt
                                    Here is homeall.g
                                    ; homeall.g
                                    ; called to home all axes
                                    G1
                                    mesh.g
                                    							 ; --- set Z=0 datum which is needed for creating a heightmap
                                    M557 X0:560 Y0:580 S58       ; define mesh grid 420 points S58
                                    G28
                                    G29 S0                       ; probe bed and create height map
                                      @fcwilt
                                      So another question. Modix had a Macro -
                                      Automatic tilt calibration + Bed Compensation - 101 points
                                      That Macro has all changed now with your code correct ?
                                      So how do I run the bed tilt calibration
                                      and the bed probe calibration ?
                                      I am confused on it I wipe those clean and add a M98 P"bed.g"
                                      and run it trough the macro
                                      or just type that into the console comand ?
                                      undefined 1 Reply Last reply 20 Mar 2022, 22:50 Reply Quote 0
                                        @sculpt-fabricator
                                        The current approach that the DWC expects is this:
                                        • the file mesh.g is used to create the height map needed for Mesh Bed Compensation.
                                        • the file bed.g is used for Manual or Automatic Bed Leveling.
                                        A G29 command executes mesh.g and creates the height map.
                                        To use the height map you would have a G29 S1 command somewhere in your print start code.
                                        A G32 command executes bed.g.
                                        I use G32 as part of my home all code.
                                        So it looks like you are already using the correct approach.
                                          @sculpt-fabricator
                                          See if this bed.g file works for you:
                                          bed.g
                                          undefined 3 Replies Last reply 20 Mar 2022, 22:54 Reply Quote 0
