    5-axis 3D printer on Prusa i3
    MultiAxis Printing
    2.8k
    • o_lampeundefined
      o_lampe @Freddiester
      @freddiester
      Awesome project!
      Is there any reason, why you picked the I3 hardware as starting point? Was it easier to rebuild than eg. a coreXY or Delta printer?
      Freddiesterundefined 1 Reply Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe
        As a sidenote: I just started to build a rotary axis for my CO2 laser, but now I'm wondering if that device would come handy in a laser, too?
        • Freddiesterundefined
          Freddiester @RAFFACNC
          @raffacnc Hello, excited to hear that you are also working on 5-axis printing. I expect that the Github repository will go public and you can download the grasshopper definition and try!
          RAFFACNCundefined 1 Reply Last reply Reply Quote 0
            Freddiester @o_lampe
            @o_lampe I picked i3 hardware because it's common and inexpensive. I have another machine built into coreXY but they work quite similar in principal. I assume it is harder to implement the kinematics on delta.
            • RAFFACNCundefined
              RAFFACNC @Freddiester
              @freddiester
              thank you so much, in git hub insert a link for donations, for support your project.
                T3P3Tony administrators @Freddiester
                @freddiester really interesting work, thanks for sharing it here!
                @xyzdims is also doing interesting work in this area.
                (https://xyzdims.com/)
                As are others on this forum.
                This has felt like a chicken and egg issue for a while: not a huge amount of focus on the hardware because there were not a lot of optins on the software tool chain side. Similarly not a lot of work on the software because there were few hardware options available. I think the corner is being turned in that regard!
                  This was great to see in person at 3d Meetup Sweden
                  Would love to hear from anyone else who is planning on building one!
                  o_lampeundefined 1 Reply Last reply Reply Quote 1
                  • o_lampeundefined
                    o_lampe @T3P3Tony
                    @t3p3tony said in 5-axis 3D printer on Prusa i3:
                    I don't have enough imagination to see what else could be printed by it?
                    OTOH, I proposed this rotary table to my friends in a laser-forum, where I'm currently working on 2.5D laser engraving (aka powermapping)
                      T3P3Tony administrators @o_lampe
                      @o_lampe this has so much potential both for support less printing, and for non planar printing where the layers are oriented and optimised for the shapes function.
                      • o_lampeundefined
                        o_lampe @T3P3Tony
                        I see, but the blades of the propellers from the example prints are no good example then. Their strength relies completely on layer bonding, which IMHO is the weakest. (except for ABS cured afterwards)
                        In other words: I want to see more prints 😀
                          @o_lampe said in 5-axis 3D printer on Prusa i3:
                          For some materials printed incorrectly this is true (e.g. HIPS at too low temperatures) but is interesting to see research done to show that interlayer adhesion is not always the dominant failure mode:
                          https://www.researchgate.net/publication/341289167_Interlayer_bonding_has_bulk-material_strength_in_extrusion_additive_manufacturing_New_understanding_of_anisotropy
                          That said the ability to orient the extrusion path with more freedom using 5 axis printing will certainly help in a lot of situations, especially when continuous fibre tools are used.
                          • CNCModellerundefined
                            CNCModeller
                            Hi All,
                            Seems to me that if we could find a way to print a first wall in the optimum direction for printing and then wrap a second around that core with the filament direction aligned for strength this would be an optimal solution. It'd be a bit like a fibre placement machine.
                            Very impressive 👍👍👍
                            Looking forward to seeing how the slicer works too.
                            All the best
                            Barry M
                            Polar Duet3 Mini + 1HCL
                            https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                            Wanhao D4S: Duet2
                            https://forum.duet3d.com/post/296755
                            K40 Laser, Duet2
                            https://forum.duet3d.com/post/312082
                            Wanhao D5S
                            https://www.youtube.com/CNCModellerUK
                              T3P3Tony administrators @CNCModeller
                              @cncmodeller the "slicer" is currently written in grasshopper which is part of the CAD software Rhino.
                              @xyzdims is working on open source slicing options for non planarity, I highly recommend following his blog.
                              CNCModellerundefined 1 Reply Last reply Reply Quote 0
                                CNCModeller @T3P3Tony
                                Thanks for the heads up. I'll have a look when I have some spare headroom.
                                It'd be interesting if the approach could be ported over to Fusion 360 as they have a fully integrated CAM approach.
                                I've often wondered if a 5 axis 3D surface toolpath with a ball end mill would work as a way to generate a wrap layer for such an application.
                                Anyway great stuff!
                                Cheers
                                Barry M
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                • o_lampeundefined o_lampe referenced this topic
                                • T3P3Tonyundefined T3P3Tony referenced this topic
                                • T3P3Tonyundefined T3P3Tony moved this topic from My Duet controlled machine
                                • JoergS5undefined JoergS5 referenced this topic
