Solved Is there a terminal like YAT for RPI?
VIN undervoltage may just mean that VIN power has been removed but the duet is still powered by 5v via usb.
Where are you seeing the undervoltage event message?
@phaedrux said in Is there a terminal like YAT for RPI?:
In CuteCom when unplugged power.
Anyhow this morning I get response to commands, have not touched anything from last night so go figure what was going on yesterday evening. Config.g empty 'again'.
@tecno
minicom
should work, too. It comes preconfigured for the Duet on DuetPi. -
OK, satisfied with Cutecom.
@tecno said in Is there a terminal like YAT for RPI?:
Was this the original problem here or that it had happened previously?
Both
Had you edited config.g before it had gone empty?
Was config.g missing completely, or just blank?
Was config.g.bak present and complete? -
No
Blank
Present -
Thanks. Had we replaced this board for you already when it first happened?
No config this morning, printer been offline for 2 days.
Today no config.g and no config.g.bak
re. board To be honest I do not remember. M552 S1 keeps me running
Here some moore
Now no CAN connection, WTF is going on??
@tecno i've seen that happen when i reboot. the board reboots before the toolboard can respond. its normal I think
Edited config.g (probe) and now CAN is back, this a bit fishy.
@jay_s_uk
; WAIT FOR CAN
G4 S4 should be plenty -
@tecno the red line issue you showed above was after the emergency stop and not to do with startup
@jay_s_uk
Ain't that same as remote boot up? -
@tecno no
@jay_s_uk
So only power off and on? -
@tecno imagine you're on the phone to someone and you ask them a question but they hang up before they can answer, thats the same as whats happening when you press the emergency stop button. the main board asks the heater to turn off to make sure its off but its already rebooting, so you get the error that the remote heater can't be turned off. it has nothing to do with startup delay
@tecno use M122 B121 to check which bootloader version is installed on the tool board.
