    Toolboard + NO NPN probe
    922
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
        jay_s_uk @tecno
        @tecno well there you go. use P8 and not P5
        tecnoundefined 2 Replies Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk
          a61bae5c-9ac9-475e-a5c0-a73e2738dc4c-config.g
          Hard DIVE into the bed, led on probe lights up but no reaction to that
            jay_s_uk @tecno
            @tecno maybe you don't need the pullup?
            best to check these things far away from the bed rather than relying on that as a last resort
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              M558 C"!121.io0.in" P8 H10 F120 T8000
              With probe not triggered Prove value is 0 triggered is 0
              If I set probe not inverted Probe value is 1000 triggered still 1000
              No change whatever I try
              jay_s_ukundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @tecno
                @tecno maybe you need a diode as detailed here https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#npn-output-normally-open-inductive-or-capacitive-sensor?
                other than that, no idea
                • infiniteloopundefined
                  infiniteloop @tecno
                  @tecno said in Toolboard + NO NPN probe:
                  Either you have no signal on the pin, or it is constantly tied to 3.3V by the probe. Check function of the probe stand-alone with a multimeter: What voltages do you read when the probe is triggered/untriggered?
                  A third possibility might be the port being defective, but first, check your probe signal.
                  • tecnoundefined
                    tecno @infiniteloop
                    @infiniteloop
                    NPN and no 3.3V ! Vin as these need 6-30V
                    Vin non triggered = out Vin
                    Triggered = out under 0.6V
                    So probe is OK
                    Looks like the Tollboard is busted again ๐Ÿ˜ž
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk said in Toolboard + NO NPN probe:
                      Select mode 5 (P5) in the M558 command. Invert the probe output From the manual you linked !
                        jay_s_uk @tecno
                        @tecno https://docs.duet3d.com/en/User_manual/RepRapFirmware/CAN_limitations
                        only P8 and P9 can be used on CAN boards
                        • tecnoundefined
                          tecno @jay_s_uk
                          @jay_s_uk
                          Doh... too many variables so confusing it is.
                          How can i check port that it is working? Short GND to INP or 5V?
                          Set it as P8 so I can see Probe value 0 or 1000
                            infiniteloop @tecno
                            Do I understand this right: The signal has 6-30V non-triggered?
                            • tecnoundefined
                              tecno @infiniteloop
                              @infiniteloop
                              Yes
                                infiniteloop @tecno
                                Yes
                                Then you've fried the port. ๐Ÿ˜ข
                                • tecnoundefined
                                  tecno @infiniteloop
                                  @infiniteloop
                                  That is what I suspect, not the first toolboard to go south on me.
                                    infiniteloop @tecno
                                    Yes, you can short GND to INP. Does this trigger the endstop?
                                    • tecnoundefined
                                      tecno @infiniteloop
                                      @infiniteloop said in Toolboard + NO NPN probe:
                                      not shorted = value is 0
                                      shorted = value is 1000
                                      So go figure what is wrong, I only have 1N4148 diode's at hand no BATยดs
                                      infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        infiniteloop @tecno
                                        That's good news, the board still works. Your test means that the probe doesn't pull down the signal strong enough to trigger. Try the diode - according to the documentation, this might work:
                                        The diode should preferably be a small-signal Schottky diode such as BAT43 or BAT85, but a small signal silicon diode such as 1N4148 works for some people.
                                        • tecnoundefined
                                          tecno @infiniteloop
                                          @infiniteloop
                                          Already tried the diod = no go
                                            infiniteloop @tecno
                                            @tecno Hm, I'm guessing, but maybe a pull-down resistor between GND and INP might help. Can't tell you a value, though, but I would start with something like 10k - and go down until the probe triggers reliably.
