    1HCL 1.0 closed loop controller
    2.6k
    • supertb1undefined
      supertb1
      • supertb1undefined
        supertb1
        Hello, I have my new 1.0 boards installed and I am trying to do calibrations. I am getting this error, any help would be great
        supertb1undefined 1 Reply Last reply Reply Quote 0
        • supertb1undefined
          supertb1 @supertb1
          M122 B50.0
          Diagnostics for board 50:
          Duet EXP1HCL firmware version 3.4.0beta7+8 (2022-01-25 10:33:00)
          Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
          All averaging filters OK
          Never used RAM 52328, free system stack 2600 words
          Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,93) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,31.3%,360) CLSend(notifyWait,0.0%,152) MAIN(running,66.9%,400) IDLE(ready,0.0%,39) AIN(notifyWait,1.8%,265), total 100.0%
          Last reset 00:00:18 ago, cause: software
          Last software reset data not available
          Closed loop enabled: no, pre-error threshold: 0.00, error threshold: 0.00, encoder type none
          Driver 0: pos 0, 106.5 steps/mm,standstill, SG min 0, mspos 968, reads 48852, writes 19 timeouts 0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter -4/6, peak Rx sync delay 180, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.2, current 24.3, max 24.3
          V12 voltage: min 18.0, current 18.0, max 18.0
          MCU temperature: min 26.2C, current 26.2C, max 26.2C
          Last sensors broadcast 0x00000000 found 0 87 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 174, send timeouts 0, received 164, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          supertb1undefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • supertb1undefined
            supertb1 @supertb1
            @supertb1 ; Drives
            G4 S1 ;wait for expansion boards to start
            M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            M569.1 P51.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
            M569 P51.0 D4 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
            M584 X50.0 Y51.0 Z0.0 E0.1 ; set drive mapping
            M92 X106.50 Y106.50 Z400.00 E420.00 ; set steps per mm
            M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M917 X10 Y10 ; Set the closed loop axes to have a holding current of zero
            • alankilianundefined
              alankilian @supertb1
              @supertb1 said in 1HCL 1.0 closed loop controller:
              I don't <think> this has anything to do with your problem, but why do you think the 12 Volt rail is reading 18 Volts?
              • supertb1undefined
                supertb1 @alankilian
                @alankilian Great question, it is a 24V system, but the nema 17 encoded steppers should only be seeing 12VDC as far as I know.. I wouldn't even knw what to do about that @t3p3tony @dc42
                  T3P3Tony administrators @supertb1
                  @supertb1 please upgrade the firmware to 3.4 stable and try again.
                  supertb1undefined 2 Replies Last reply Reply Quote 1
                  • supertb1undefined
                    supertb1 @T3P3Tony
                    @t3p3tony Cheers mate
                    • supertb1undefined
                      supertb1 @T3P3Tony
                      It gave me this error when I tried to update to the new firmware, and then when I try to update the DWC the board resets about half way down the list... not sure if the two events are related but I am wondering if it wouldn't be a bad idea to just reset the board to manufacturer and start over. Thoughts?
                      • supertb1undefined
                        supertb1 @supertb1
                        @supertb1 I did the same update on my older unit and everything worked perfectly... so good news there.
                          dc42 administrators @supertb1
                          @supertb1 try uploading the RRF 3.4 release zip file again.
                          supertb1undefined 2 Replies Last reply Reply Quote 0
                          • supertb1undefined
                            supertb1 @dc42
                            @dc42 Is Symbols-RepRapFirmware-Duet3_MB6HC different from the RRF 3.4, I reinstalled it and again got the same error when I tried to install the Duet3Firmware_MB6HC. Is there another place to find "RRF 3.4"?
                            Stephen6309undefined 1 Reply Last reply Reply Quote 0
                            • Stephen6309undefined
                              Stephen6309 @supertb1
                              @supertb1 The symbols file is not the firmware. Use Duet2and3firmware-3.4.0.zip. That's the first file on the release page.
                              The firmwares all have firmware in the filename.
                              https://github.com/Duet3D/RepRapFirmware/releases
                                alankilian @Stephen6309
                                @supertb1 THIS is a link to the 3.4.0 release ZIP file.
                                • supertb1undefined
                                  supertb1 @dc42
                                  @dc42 So I did the Duet2and3Firmware-3.4.0 that took ,and then I did the Duet3Firmware_MB6HC which yielded :3.4 6mainboard error.jpg
                                  and it basically bricked the controller, I can't get on the DWC and I can't make it do anything from the touch screen... I hope a reset will fix this and nothing permanent has been done. any help would be great.
                                    If you send M115 on the paneldue does it respond?
                                    You can use this method to flash the desired firmware directly to the 6HC.
                                    https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                                    Can you also check what firmware version you have running on the PanelDue in the setup page? You should probably update it as well using USB and similar procedure.
                                    https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
                                    • supertb1undefined
                                      supertb1 @Phaedrux
                                      No response, and to boot the status light on the main board is dimly lit, the status on the 1HLC boards are flashing red....so at this point is my best coarse of action to connect my computer directly to the Main Board and use BOSSA to flash the firmware? or am I someplace else?
                                      what is the correct board sequence to flash? What have I done to this thing? so exciting to have messed this thing up and now I get to learn how to fix it😵 😨 😰 😬 🤔 😟
                                      • supertb1undefined
                                        supertb1 @Phaedrux
                                        @phaedrux one last thing, while using BOSSA what is the correct order to install the software?
                                          Phaedrux Moderator @supertb1
                                          I'm not sure what you mean by correct order. Have you looked at this link yet? https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                                          • supertb1undefined
                                            supertb1 @Phaedrux
                                            @phaedrux Have you guys made a video someplace demonstrating a BOSSA or other method of erasure through firmware install... this is making me a little nervous never having done this before
