    M584 help needed
    987
    • jlee73undefined
      jlee73 @Phaedrux
      @phaedrux actually yes I do. Says m669 k1. Nothing after that
      • jlee73undefined
        jlee73 @Phaedrux
        @phaedrux What should it say after K-1
          Phaedrux Moderator @jlee73
          @jlee73 said in M584 help needed:
          I don't know what you mean by k-1
          Are you sure you have the motors connected to the right drivers?
          You can also try the explicit matrix shown by @fcwilt
          jlee73undefined 1 Reply Last reply Reply Quote 0
          • jlee73undefined
            jlee73 @Phaedrux
            @phaedrux the line says m669 k1. Nothing after that
              Yes, K1 is corexy mode. It doesn't need more after that. And by the looks of your screen shot when you sent M669 by itself it does report that it's in corexy mode. So that seems correct. Which is why I ask if the motors are all connected to the expected drivers.
              The problem is once I have homed everything X moves fine, but when I tried to move the Y axis the Z motors also move.
              How much z movement are you seeing exactly?
              Can you post your homing files? Your entire config.g would also be good. And for good measure can you send M122 and M98 P"config.g" in the gcode console tab and copy and paste the text here?
              jlee73undefined 6 Replies Last reply Reply Quote 0
              • jlee73undefined
                jlee73 @Phaedrux
                @phaedrux
                M98 P"config.g"
                Error: in file macro line 14: M540: invalid MAC address
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Debugging enabled for modules:
                Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16) CAN(17)
                Warning: Macro file config-override.g not found
                • jlee73undefined
                  jlee73 @Phaedrux
                  @phaedrux
                  ; Configuration file for Duet 3 (firmware version 3.3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Apr 26 2022 14:49:38 GMT-0600 (Mountain Daylight Time)
                  M550 P"Beast" ; set printer name
                  M669 K1 X1:1:0:0 Y1👎0:-1 Z0:0:1:0 ; select CoreXY mode
                  M551 P"Neiljess18" ; set password
                  M540 P0.0.0.0 S1 ; set custom MAC address
                  M552 P192.168.1.129 S1 ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0.4 S1 ; physical drive 0.4 goes forwards
                  M569 P0.5 S1 ; physical drive 0.5 goes forwards
                  M584 X0.0:0.1
                  M584 Y0.3
                  M584 Z0.4:0.5
                  M584 E0.2 ; set drive mapping
                  M92 X400.00 Y400.00 Z3.00 E611.15 ; set steps per mm
                  M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                  M906 X2500 Y2500 Z2500 E2000 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X965 Y400 Z300 S0 ; set axis maxima
                  M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                  M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                  ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
                  M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                  M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                  M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                  M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                  ; Custom settings
                  G21
                  M111
                  • jlee73undefined
                    jlee73 @Phaedrux
                    @phaedrux
                    ; homeall.g
                    ; called to home all axes
                    G91 ; relative positioning
                    G1 H1 X-970 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 H1 X-970 ; home X axis
                    G1 H1 Y-405 ; home Y axis
                    G1 H1 X-970 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 H1 Y-405 ; then move slowly to Y axis endstop
                    G90 ; absolute positioning
                    G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                    ;G91 ; relative positioning
                    ;G90 ; absolute positioning
                    • jlee73undefined
                      jlee73 @Phaedrux
                      @phaedrux
                      ; homex.g
                      ; called to home the X axis
                      G1 H1 X-970 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X5 F6000 ; go back a few mm
                      G1 H2 Z-5 F6000 ; lower Z again
                        So as part of your homing files it lowers the Z axis for clearance before moving in XY. Is that what you're seeing? if so, this is normal. If not, please post a video.
                        • jlee73undefined
                          jlee73 @Phaedrux
                          @phaedrux
                          ; homey.g
                          ; called to home the Y axis
                          G1 H1 Y0 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y5 F6000 ; go back a few mm
                          G1 H1 Y0 F360 ; move slowly to Y axis endstop once more (second pass)
                          • jlee73undefined
                            jlee73 @Phaedrux
                            @phaedrux
                            ; homez.g
                            ; called to home the Z axis
                            G1 X15 Y15 F6000 ; go to first probe point
                            • jlee73undefined
                              jlee73 @Phaedrux
                              @phaedrux
                              No, once everything is homed on dwc, i then try ti use the move "y" by 1,10 or 50 buttons to move the y which is my hotend. when i do that the x axis also moves it should not move at all.
                              jlee73undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • jlee73undefined
                                jlee73 @jlee73
                                @jlee73 it has nothing to do w Z
                                  @phaedrux
                                  The corexy kinematic uses both motors to produce motion. Only 45 degree moves would use a single motor at a time. Is this what you're seeing?
                                  Again, can you post a video so we can see what you're seeing?
                                    Your original post says that Z moved.
                                    So I'm confused. Please make a video.
                                    jlee73undefined 2 Replies Last reply Reply Quote 0
                                    • jlee73undefined
                                      jlee73 @Phaedrux
                                      @phaedrux I tried the forum won’t let me upload it because it’s too big
                                      • jlee73undefined
                                        jlee73 @Phaedrux
                                        @phaedrux I meant x moves when I try to move y sorry
                                          You'd have to use something like youtube, or vimeo, or google drive, or dropbox, etc. Or a smaller clip in mp4 format.
                                          • jlee73undefined
                                            jlee73 @Phaedrux
                                            @phaedrux I will have to get that to you tomorrow
