Solved M584 help needed
@phaedrux
; homey.g
; called to home the Y axis
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Apr 26 2022 14:49:38 GMT-0600 (Mountain Daylight Time)
G91 ; relative positioning
G1 H1 Y0 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y0 F360 ; move slowly to Y axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning -
@phaedrux
; homez.g
; called to home the Z axis
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
No, once everything is homed on dwc, i then try ti use the move "y" by 1,10 or 50 buttons to move the y which is my hotend. when i do that the x axis also moves it should not move at all.
@jlee73 it has nothing to do w Z
@jlee73 said in M584 help needed:
The corexy kinematic uses both motors to produce motion. Only 45 degree moves would use a single motor at a time. Is this what you're seeing?
Again, can you post a video so we can see what you're seeing?
Your original post says that Z moved.
but when I tried to move the Y axis the Z motors also move.
So I'm confused. Please make a video.
@phaedrux I tried the forum won’t let me upload it because it’s too big
@phaedrux I meant x moves when I try to move y sorry
You'd have to use something like youtube, or vimeo, or google drive, or dropbox, etc. Or a smaller clip in mp4 format.
@phaedrux I will have to get that to you tomorrow
Can you also send M122 and copy and paste the result?
Did you experiment with the X and Y values in M669?
@phaedrux After doing some more reading I think I’ve got it set up wrong on the M669 code. It should be M669K0. Will try that tomorrow
Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY,
So it's cartesian, and not corexy?
@phaedrux it has to be. K1 would most likely tell the motors on x&y to move at the same time right? But a K0 would allow the x&y motors to move independently correct?
What does the belt path for the printer look like? Can you show a photo?
This is what a corexy belt setup looks like.
@phaedrux Yeah that’s not it at all
This post is deleted! -
That is cartesian.
@phaedrux tomorrow when I get back there I will change it to you M669K0
