    M584 help needed
    989
      Phaedrux Moderator @jlee73
      @jlee73 said in M584 help needed:
      G1 H1 X-970 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      So as part of your homing files it lowers the Z axis for clearance before moving in XY. Is that what you're seeing? if so, this is normal. If not, please post a video.
      jlee73undefined 1 Reply Last reply Reply Quote 0
      • jlee73undefined
        jlee73 @Phaedrux
        @phaedrux
        ; homey.g
        ; called to home the Y axis
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Apr 26 2022 14:49:38 GMT-0600 (Mountain Daylight Time)
        G91 ; relative positioning
        G1 H1 Y0 F1800 ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y5 F6000 ; go back a few mm
        G1 H1 Y0 F360 ; move slowly to Y axis endstop once more (second pass)
        G1 H2 Z-5 F6000 ; lower Z again
        G90 ; absolute positioning
        • jlee73undefined
          jlee73 @Phaedrux
          @phaedrux
          ; homez.g
          ; called to home the Z axis
          G1 X15 Y15 F6000 ; go to first probe point
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          • jlee73undefined
            jlee73 @Phaedrux
            @phaedrux
            No, once everything is homed on dwc, i then try ti use the move "y" by 1,10 or 50 buttons to move the y which is my hotend. when i do that the x axis also moves it should not move at all.
            jlee73undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • jlee73undefined
              jlee73 @jlee73
              @jlee73 it has nothing to do w Z
                @phaedrux
                The corexy kinematic uses both motors to produce motion. Only 45 degree moves would use a single motor at a time. Is this what you're seeing?
                Again, can you post a video so we can see what you're seeing?
                  Your original post says that Z moved.
                  but when I tried to move the Y axis the Z motors also move.
                  So I'm confused. Please make a video.
                  jlee73undefined 2 Replies Last reply Reply Quote 0
                  • jlee73undefined
                    jlee73 @Phaedrux
                    @phaedrux I tried the forum won’t let me upload it because it’s too big
                    • jlee73undefined
                      jlee73 @Phaedrux
                      @phaedrux I meant x moves when I try to move y sorry
                        You'd have to use something like youtube, or vimeo, or google drive, or dropbox, etc. Or a smaller clip in mp4 format.
                        • jlee73undefined
                          jlee73 @Phaedrux
                          @phaedrux I will have to get that to you tomorrow
                            Can you also send M122 and copy and paste the result?
                            • fcwiltundefined
                              fcwilt @jlee73
                              Did you experiment with the X and Y values in M669?
                              • jlee73undefined
                                jlee73 @Phaedrux
                                @phaedrux After doing some more reading I think I’ve got it set up wrong on the M669 code. It should be M669K0. Will try that tomorrow
                                  Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY,
                                  So it's cartesian, and not corexy?
                                  • jlee73undefined
                                    jlee73 @Phaedrux
                                    @phaedrux it has to be. K1 would most likely tell the motors on x&y to move at the same time right? But a K0 would allow the x&y motors to move independently correct?
                                      What does the belt path for the printer look like? Can you show a photo?
                                      This is what a corexy belt setup looks like.
                                      830b2d43-d5a8-4198-8222-fab5d99ed54d-simple_belts_corexy_annotated.jpg simple_belts_corexy_annotated.jpg
                                      • jlee73undefined
                                        jlee73 @Phaedrux
                                        @phaedrux Yeah that’s not it at all
                                        • jlee73undefined
                                          jlee73 @Phaedrux
                                          This post is deleted!
                                            That is cartesian.
