    Heated chamber PID and 3.4 stable
    908
    • martin7404undefined
      martin7404 @Tinchus
      @tinchus yes it is a chamber anyway.
      Mine holds temp within 0.2 deg C
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      Tinchusundefined 1 Reply Last reply Reply Quote 0
      • Tinchusundefined
        Tinchus @martin7404
        @martin7404 this topic is not for a debate about this I guess. But you chamber limit is 70, is way low compared to me 180 degrees chamber. At those temperatures, using bang bang is somehow complicated in order to mantein stable temperatures across the chamber for many reasons. Reaching 70 degrees is easy for my chamber with the actual "failed PID", the problem Im having is for reaching above 85 degrees, that is where I start getting errors.
        This arise with version 3.4, with previous 3.3, I had the PID working with no problems, and those values also dont work with version 3.4
          Does the PID tune fail at the same point each time?
          Does it succeed when tuning to a lower temperature?
          • Tinchusundefined
            Tinchus @Phaedrux
            @phaedrux The tunning finishes and reports me the value, I saved them using M500 and I checked those values are in the override file. Printer has been rebooted too and those values are being used. But when I try to reach the same temperature the calibration was suposed to tune, I got the errors described above.
            • Tinchusundefined
              Tinchus
              More information I forgot: definition of the heater is this:
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"chamber" ; sensor 0 en pin temp0
              M950 H0 C"out7+out8" T0 ; pins out 7 and out8 for chamber heaters
              M307 H0 R0.015 K0.083:0.083 D150.25 E1.35 S0.90 B0 ; enable PID mode for the chamber heater and set PWM limit
              M141 P0 H0 ; Define H0 as a chamber heater
                What's the reason you're using only a 0.9 PWM value?
                • Tinchusundefined
                  Tinchus @Tinchus
                  @Phaedrux voltage tension at home is over normal values. I should have 220V, but I have 235 V always!. The electric resistor I have is meant to be used on 220V, if I use it at 235 it burns. So by reducing the pwm to 0.9 I can use it without the need to get a new one able to work at 235V.
                  I already tried both ways: I tried to tune the PID with the PWM value at 0.9 and also at 1.0 without success. Each time tunning finishes, I get what are suposed to be the values for PID. Then those values... just dont work.
                  I couldnt find an explanation of what te new PID values mean or how to tune them manually, is that information available?
                  • Tinchusundefined Tinchus referenced this topic
                  • Tinchusundefined
                    Tinchus
                    I have ran the tunning again. Tunning ends and I get this (in the case of tunning being made for a temp chamber of 85 degrees):
                    M307 H0 R0.097 K0.077:0.000 D93.61 E1.35 S0.90 B0
                    I have just noticed that second pair of values on the KK0.077:0.000
                    My config includes 2 heaters separated, so just in case 1 burns I can easily detect wich one, replace it, etc.
                    Version 3.4 allows me to put tgether 2 heater under the same control, so my config uses:
                    M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"chamber" ; configuro sensor 0 en pin temp0
                    M950 H0 C"out7+out8" T0 ; create bed heater output on out0 and map it to sensor 0, pins out 7 and out8
                    M307 H0 R0.097 K0.077:0.000 D93.61 E1.35 S0.90 B0 ; enable PID mode for the chamber heater and set PWM limit
                    As I said, when I try to heat up the chamber, it goes to something like 60/70 degrees and I get a fault. Can be those cero values on the second pair of the K be a problem?
                    Thanks in advance
                    baird1faundefined 1 Reply Last reply Reply Quote 0
                    • baird1faundefined
                      baird1fa @Tinchus
                      @tinchus I have the same issue changing from 3.3 to 3.4, my chamber heaters M307 values don't seem to work anymore and I too get the heater0 rising too slowly error.
                      I find that odd that I'm getting a heater0 error since my chamber is heater3. But that aside I've tried to change the vales to get the heater to work and I'm having a tough time. My chamber is much slower heating than yours and it takes a very long time to even reach 50C. I've been running the autotunner now for several hours.
                      Phaedruxundefined Tinchusundefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @baird1fa
                        @baird1fa said in Heated chamber PID and 3.4 stable:
                        I think that is a bug in 3.4 that has been fixed in 3.4.1 RC1.
                        When a heater fault event was generated on the main board, the heater number and CAN address parameters were swapped. This resulted in the heater number always being reported as 0.
                        When a filament error event was generated on the main board, the extruder number and CAN address parameters were swapped. This resulted in the extruder number always being reported as 0.
                        Would you be able to test 3.4.1 RC1?
                        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.1rc1
                        • Tinchusundefined
                          Tinchus @Phaedrux
                          @phaedrux Im not good on this github stuff, How can I upgrade to 3.4.1 RC1? I usually do the update using th sudo apt commands
                          • Tinchusundefined
                            Tinchus @baird1fa
                            @baird1fa In my case, heater 0 is my chamber heater
                              Phaedrux Moderator @Tinchus
                              @tinchus said in Heated chamber PID and 3.4 stable:
                              The board is a duet3 running in SBC mode, 3.4 version
                              In your case running a SBC you would need to use these directions to switch to the unstable package feed on the Pi.
                              https://docs.duet3d.com/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages
