    Software bundle 3.4.1RC1 now available
    Firmware installation
    10
    17
    2.1k
    • BoAundefined
      BoA
      I uploaded to Duet3 standalone, and board no longer starts. I think I need to find some recovery from this state.
      Update from 3.4 -> 3.4.1RC1
      Edit. Restored 3.4 with bossa, flashed 3.4.1rc1 again - no issues this time. So some kind of a glitch 🙂
        jay_s_uk @BoA
        @boa i had an issue with 3.4 where the firmware got wiped from the board.
        plug a USB in and see if a BOSSA port appears. If so, reflash the firmware
        • chrishammundefined
          chrishamm administrators @Alex.cr
          @alex-cr There is no need to update them because they target 3.4 and not 3.4.0. If you run into problems, try to download and reinstall the affected plugin(s).
          Duet software engineer
          oozeBotundefined Alex.crundefined Exerqtorundefined 3 Replies Last reply Reply Quote 0
          • oozeBotundefined
            oozeBot @chrishamm
            @dc42 We finally had time to install this on a machine. No issues so far, but testing has just begun. Something we'd really like to see addressed in 3.4.1 is fixing job progress when thumbnails are used as the current calculation appears to count the thumbnails as part of the print job, skewing the results.
              @oozebot said in Software bundle 3.4.1RC1 now available:
              This should only be an issue when the print file is small. It won't be changed in 3.4.1 but is already on the list for 3.5.
              oozeBotundefined 1 Reply Last reply Reply Quote 0
              • oozeBotundefined
                oozeBot @dc42
                @dc42 Thanks for the response. I do want to point out that it does affect larger jobs as well when multiple thumbnails are embedded. However, this isn't a showstopper - just something we'd like to see addressed soon as we really like the thumbnail feature!
                • Alex.crundefined
                  Alex.cr @chrishamm
                  @chrishamm said in Software bundle 3.4.1RC1 now available:
                  After reinstall they worked again. Thanks for the help!
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                  • Exerqtorundefined
                    Exerqtor @chrishamm
                    Having issues with the 3.4.0-b1 input shaping plugin not wanting to install on DWC 3.4.1-rc1 for some reason 🤔
                    EDIT: found out that the plugin was looking for DWC 3.4.0, changed it to 3.4 and repacked it so now it works ✌
                    CR3Dundefined 1 Reply Last reply Reply Quote 0
                    • CR3Dundefined
                      CR3D @Exerqtor
                      it still contains the following BUG:
                      https://forum.duet3d.com/topic/27288/rrf-3-4-beta-7-tool-offsets-issue
                      Regards Christian (CR-3D)
                      Christian from CR-3D
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      https://www.facebook.com/cr3d.official
                      Our Discord Server
                      https://discord.gg/SxRaPNuRdA
                      Thingiverse Profile:
                      https://www.thingiverse.com/cr-3d_official/about
                        jay_s_uk @CR3D
                        @cr3d no it doesnt
                        • CR3Dundefined
                          CR3D @jay_s_uk
                          @jay_s_uk
                          do you know the solution?
                          I have made a video today...
                          Homepage:
                          www.cr-3d.de
                          Facebook:
                          Our Discord Server
                            dc42 administrators @CR3D
                            @cr3d I have replied to the thread that you linked to.
