    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    5.9k
    • Stephen6309undefined
      Stephen6309 @damaged_goods
      @damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
      It has thumbnails compatible with the PanelDue.
      • chrishammundefined chrishamm unpinned this topic
      • tfjieldundefined
        tfjield
        @dc42 said in Software bundle 3.4.0 stable released!:
        Thumbnail
        Anyone know how to get thumbnail generation in Cura?
        • oliofundefined
          oliof @tfjield
          @tfjield Install the RRF plugin for Cura.
            @tfjield said in Software bundle 3.4.0 stable released!:
            https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
            tfjieldundefined 1 Reply Last reply Reply Quote 0
            • tfjieldundefined
              tfjield @dc42
              @dc42 @oliof
              I installed it, and all I see is that it's asking me to link my printer...
              Does this require me to send the file to the printer directly? Or can I just save the gcode with the image embedded?
              Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @tfjield
                @tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
                • oliofundefined
                  oliof @tfjield
                  @tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
                  tfjieldundefined 2 Replies Last reply Reply Quote 1
                  • tfjieldundefined
                    tfjield @oliof
                    @oliof @Phaedrux Thank you!
                    • tfjieldundefined
                      tfjield @oliof
                      @oliof
                      After I installed it, I now have 4 options after slicing:
                      • Simulate on xxx
                      • Print on xxx
                      • Upload to xxx
                      • Save to Disk
                      If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
                      Is this correct, or am I doing something wrong?
                      oliofundefined resamundefined 2 Replies Last reply Reply Quote 0
                      • oliofundefined
                        oliof @tfjield
                        @tfjield its probably worth to open a separate thread for this discussion so we can drag in @resam who is the plugin author.
                        • resamundefined
                          resam @tfjield
                          @tfjield short answer: the "Save to Disk" option is from plain Cura - not my plugin. If you want a dedicated "Save to Disk with thumbnails"-like option, let's move the conversation to a new thread.
                          • tfjieldundefined tfjield referenced this topic
