    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    5.9k
    • damaged_goodsundefined
      damaged_goods @BoA
      @boa Thank you,
        damaged_goods @zapta
        @zapta It's a custom built very large printer with a duet 3 MB6HC.
          jay_s_uk @Schickfus
          @schickfus can you open a separate thread for your issue please
          Schickfusundefined 1 Reply Last reply Reply Quote 0
          • Schickfusundefined
            Schickfus @jay_s_uk
            @jay_s_uk ok
            • Stephen6309undefined
              Stephen6309 @damaged_goods
              @damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
              It has thumbnails compatible with the PanelDue.
              • chrishammundefined chrishamm unpinned this topic
              • tfjieldundefined
                tfjield
                @dc42 said in Software bundle 3.4.0 stable released!:
                Thumbnail
                Anyone know how to get thumbnail generation in Cura?
                • oliofundefined
                  oliof @tfjield
                  @tfjield Install the RRF plugin for Cura.
                    @tfjield said in Software bundle 3.4.0 stable released!:
                    https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
                    tfjieldundefined 1 Reply Last reply Reply Quote 0
                    • tfjieldundefined
                      tfjield @dc42
                      @dc42 @oliof
                      I installed it, and all I see is that it's asking me to link my printer...
                      Does this require me to send the file to the printer directly? Or can I just save the gcode with the image embedded?
                      Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @tfjield
                        @tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
                        • oliofundefined
                          oliof @tfjield
                          @tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
                          tfjieldundefined 2 Replies Last reply Reply Quote 1
                          • tfjieldundefined
                            tfjield @oliof
                            @oliof @Phaedrux Thank you!
                            • tfjieldundefined
                              tfjield @oliof
                              @oliof
                              After I installed it, I now have 4 options after slicing:
                              • Simulate on xxx
                              • Print on xxx
                              • Upload to xxx
                              • Save to Disk
                              If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
                              Is this correct, or am I doing something wrong?
                              oliofundefined resamundefined 2 Replies Last reply Reply Quote 0
                              • oliofundefined
                                oliof @tfjield
                                @tfjield its probably worth to open a separate thread for this discussion so we can drag in @resam who is the plugin author.
                                • resamundefined
                                  resam @tfjield
                                  @tfjield short answer: the "Save to Disk" option is from plain Cura - not my plugin. If you want a dedicated "Save to Disk with thumbnails"-like option, let's move the conversation to a new thread.
                                  • tfjieldundefined tfjield referenced this topic
