    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    6.4k
    • SputnikOC3dundefined
      SputnikOC3d @dc42
      @dc42 - this release seems to be breaking my Nozzle Heater on the 1LC.
      my lonely forum post
      • damaged_goodsundefined
        damaged_goods @dc42
        @dc42 Hey David. Thanks to you and others for all the work you are putting into reprap.
        As a Prusa user I am use to being spoon fed firmware and Slicer settings. Is there a Reprap Slicer that the community finds works best?
        Thanks again.
        BoAundefined zaptaundefined Stephen6309undefined 3 Replies Last reply Reply Quote 0
        • BoAundefined
          BoA @damaged_goods
          @damaged_goods I use Prusa Slicer - it works perfectly fine.
          damaged_goodsundefined 1 Reply Last reply Reply Quote 0
          • zaptaundefined
            zapta @damaged_goods
            @damaged_goods said in Software bundle 3.4.0 stable released!:
            For what printer and what Duet board? Duet3d Mini5 on Prusa MK3?
            • Schickfusundefined
              Schickfus
              I have a MB6HC with a SBC-Rasbarry Pi 4.
              I am using the apt-get update / apt-get upgrade. It says that nothing to upgrade. But when I try the M115 command it says firmware 3.2.2
              Do I do something wrong?
              I have been following the documentation.
                damaged_goods @BoA
                @boa Thank you,
                  damaged_goods @zapta
                  @zapta It's a custom built very large printer with a duet 3 MB6HC.
                    jay_s_uk @Schickfus
                    @schickfus can you open a separate thread for your issue please
                    Schickfusundefined 1 Reply Last reply Reply Quote 0
                      Schickfus @jay_s_uk
                      @jay_s_uk ok
                      • Stephen6309undefined
                        Stephen6309 @damaged_goods
                        @damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
                        It has thumbnails compatible with the PanelDue.
                        • chrishammundefined chrishamm unpinned this topic
                        • tfjieldundefined
                          tfjield
                          @dc42 said in Software bundle 3.4.0 stable released!:
                          Thumbnail
                          Anyone know how to get thumbnail generation in Cura?
                          • oliofundefined
                            oliof @tfjield
                            @tfjield Install the RRF plugin for Cura.
                              @tfjield said in Software bundle 3.4.0 stable released!:
                              https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
                              tfjieldundefined 1 Reply Last reply Reply Quote 0
                              • tfjieldundefined
                                tfjield @dc42
                                @dc42 @oliof
                                I installed it, and all I see is that it's asking me to link my printer...
                                Does this require me to send the file to the printer directly? Or can I just save the gcode with the image embedded?
                                Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @tfjield
                                  @tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
                                  • oliofundefined
                                    oliof @tfjield
                                    @tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
                                    tfjieldundefined 2 Replies Last reply Reply Quote 1
                                    • tfjieldundefined
                                      tfjield @oliof
                                      @oliof @Phaedrux Thank you!
                                      • tfjieldundefined
                                        tfjield @oliof
                                        @oliof
                                        After I installed it, I now have 4 options after slicing:
                                        • Simulate on xxx
                                        • Print on xxx
                                        • Upload to xxx
                                        • Save to Disk
                                        If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
                                        Is this correct, or am I doing something wrong?
                                        oliofundefined resamundefined 2 Replies Last reply Reply Quote 0
                                        • oliofundefined
                                          oliof @tfjield
                                          @tfjield its probably worth to open a separate thread for this discussion so we can drag in @resam who is the plugin author.
                                          • resamundefined
                                            resam @tfjield
                                            @tfjield short answer: the "Save to Disk" option is from plain Cura - not my plugin. If you want a dedicated "Save to Disk with thumbnails"-like option, let's move the conversation to a new thread.
                                            • tfjieldundefined tfjield referenced this topic
