    Is there NO WAY to connect to DWC?????
    duet web control firmware update duet 3 mini 5+
    1.8k
      A Former User @fcwilt
      @fcwilt thank you, reading your post a few times has made it make more sense now.
      • engikeneerundefined
        engikeneer @A Former User
        @corlissmedia yes via serial tools.
        The colouring is just me and the others using the code snippet tag on the forum to make it easier to read šŸ™‚
        i3 clone with a bunch of mods
          A Former User @engikeneer
          @engikeneer to reveal my stupidity even more, what is "the code snipet tag?"
          jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @A Former User
            @corlissmedia
            • fcwiltundefined
              fcwilt @A Former User
              @corlissmedia said in Is there NO WAY to connect to DWC?????:
              Above the area where you enter your post there are a number of icons.
              The </> is the tag for used for entering code. You just click it and it will create a place to enter code.
              Like this
              this is some code
              • alankilianundefined
                alankilian @A Former User
                WiFi module is idle
                WiFi module is connected to access point NETGEAR83, IP address 192.168.0.XX
                OK, I get it that you removed the last two digits, although there's no reason at all to keep them secret.
                So, after you get your machine to connect to your WiFi, can you connect using
                http://192.168.0.XX/
                in your browser?
                • If not, what does the message in your browser say
                Of course, replace the "XX" with your secret numbers.
                  A Former User @Phaedrux
                  @phaedrux I unplugged my extender to see what that might accomplish. I’m looking at a 27ā€ picture of DWC now. I’m logged on to the main 2.4G network in my house.
                  Up next, I’m going to pursue updating all of the files on the boards card to their current versions.
                    A Former User
                    I unplugged my extended network this morning.
                    This is what happens when you practice KISS.
                    I'm thinking the IP address presented is what I've been looking for.
                    I guess I'll try to log on to it via Chrome, to see what happens.
                    RepRapFirmware for Duet 3 Mini 5+ version 3.3RC2
                    Executing config.g... Done!
                    RepRapFirmware for Duet 3 Mini 5+ is up and running.
                    WiFi module started
                    WiFi module is connected to access point NETGEAR83, IP address 100.101.1.11 (not the real IP address).
                      Glad you've made some progress. If we had some more details about the extender and network in general we might be able to take a guess at why it wasn't working.
                        @phaedrux you're far too busy, and way too important and powerful for such work!
                          A Former User @jay_s_uk
                          @jay_s_uk very clever! thank you!
