    I could use some help
    682
    64.0k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @droftarts @fcwilt if we're going to work on this together, I need to know you two are in agreement before I do anything.
      Do you both agree that I should tape X and Y closed? Then M119 again?
      Mac! You've cut me to the quick! Have you no faith in me! 😉
      I've only been doing this stuff for years.
        A Former User @fcwilt
        @fcwilt @droftarts I closed the z-endstop with my left finger, and hit M110 Send with my right finger. M119 reported Z: at end stop, Z probe: not stopped.
        I'm not making this up, guys.
          @fcwilt @droftarts I'm just trying to be respectful to Ian and you.
            droftarts administrators @A Former User
            @mac I’m not able to reply promptly now, I’m away from my computer. @fcwilt knows what he’s doing, though please keep it simple, Frederick!
            • fcwiltundefined
              fcwilt @droftarts
              @droftarts said in I could use some help:
              I try to keep it simple, I really do.
                @fcwilt @droftarts
                M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                M92 X40.00 Y40.00 Z2000.00 E420.00                 ; set steps per mm
                M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                M84 S0                                             ; Disable motor idle current reduction
                  A Former User @A Former User
                  @mac M92 cut and pasted to before M350, board rebooted.
                    @fcwilt okay, I get it, let's continue on, shall we, Frederick?
                    • fcwiltundefined
                      I know you are not. I have complete faith in you.
                      So as far as you can see M119 reports that same for the Z endstop switch regardless of it being pressed closed or not?
                      Interesting.
                      How about doing the same for the X and Y endstop switches. You can press just one at a time and execute the M119 for each one. It is not necessary to press them both at the same time.
                      What we want to verify is that M119 reports the correct thing for both states of the endstop switches, pressed and not pressed.
                        @fcwilt I just ran M119 again, it's reporting: X not stopped, Y not stopped, Z at min stop, Z probe not stopped.
                        A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                          @fcwilt I just verified that with the z-endstop pushed down, M119 is reporting the same information as above.
                          • fcwiltundefined
                            OK let's leave Z for now and test X and Y.
                              @fcwilt I'm going to test the X endstop, and then the Y endstop. Please wait for my report.
                              fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                @mac
                                I'm not going anywhere.
                                  @fcwilt okay, here are the results: with X endstop pressed down, M119 reports X at min stop. With Y endstop pressed down, M119 reports Y at min stop.
                                  Interestingly, M119 continues to report Z at min stop even though I'm NOT pressing it down?
                                    @fcwilt
                                    M208 X0 Y0 Z0 S1                                   ; set axis minima
                                    M208 X220 Y220 Z240 S0                             ; set axis maxima
                                      @fcwilt are the S0 and S1 reversed?
                                      • fcwiltundefined
                                        No they are correct.
                                        But, just FYI, there is a simpler form of M208 (at least I think it is simpler)
                                        M208 X0:220 Y0:220 Z0:240
                                        Notice no S0 or S1.
                                        The number before the : character is the min value for the axis specified by the letter.
                                        The number after the : character is the max value for the axis specified by the letter.
                                        I find it easier to remember "min then max" rather then "is it S0 or S1".
                                        That's just me.
                                          @fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
                                          But I figured it out!
                                            @fcwilt so where do these responses put us?
