    I could use some help
    682
    64.7k
      A Former User @fcwilt
      @fcwilt I just ran M119 again, it's reporting: X not stopped, Y not stopped, Z at min stop, Z probe not stopped.
      A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
        A Former User @A Former User
        @fcwilt I just verified that with the z-endstop pushed down, M119 is reporting the same information as above.
        • fcwiltundefined
          fcwilt @A Former User
          @mac said in I could use some help:
          OK let's leave Z for now and test X and Y.
            @fcwilt I'm going to test the X endstop, and then the Y endstop. Please wait for my report.
            fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              @mac
              I'm not going anywhere.
                @fcwilt okay, here are the results: with X endstop pressed down, M119 reports X at min stop. With Y endstop pressed down, M119 reports Y at min stop.
                Interestingly, M119 continues to report Z at min stop even though I'm NOT pressing it down?
                  @fcwilt
                  M208 X0 Y0 Z0 S1                                   ; set axis minima
                  M208 X220 Y220 Z240 S0                             ; set axis maxima
                    @fcwilt are the S0 and S1 reversed?
                    • fcwiltundefined
                      No they are correct.
                      But, just FYI, there is a simpler form of M208 (at least I think it is simpler)
                      M208 X0:220 Y0:220 Z0:240
                      Notice no S0 or S1.
                      The number before the : character is the min value for the axis specified by the letter.
                      The number after the : character is the max value for the axis specified by the letter.
                      I find it easier to remember "min then max" rather then "is it S0 or S1".
                      That's just me.
                        @fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
                        But I figured it out!
                          @fcwilt so where do these responses put us?
                          • fcwiltundefined
                            We are still need to test the X and Y endstop switches to see what M119 reports when a switch is pressed or not pressed.
                              @fcwilt with X depressed, X is at min stop, everything else is as it has been.
                              With Y depressed, Y is at min stop, everything else is as it has been.
                                @fcwilt the Z-endstop is still saying it's at the min stop.
                                  @fcwilt Z must be wrong, don't you think?
                                  • fcwiltundefined
                                    Fantastic.
                                    So we know the X and Y endstop are working.
                                    But the Z is not. It should do the same as the X and Y.
                                    Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
                                      @fcwilt
                                      6/27/2022, 9:17:19 AM	M574
                                      Endstop configuration:
                                      X: low end switch connected to pin !io5.in
                                      Y: low end switch connected to pin !io6.in
                                      Z: low end switch connected to pin io2.in
                                        @fcwilt something about that doesn't look right?
                                        • fcwiltundefined
                                          @fcwilt
                                          Great. You getting the hang of this, aren't you!
                                          So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
                                          But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
                                          Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
                                            droftarts administrators @A Former User
                                            @mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
