    I could use some help
    682
    64.7k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @fcwilt I just ran M119 again, it's reporting: X not stopped, Y not stopped, Z at min stop, Z probe not stopped.
      OK let's leave Z for now and test X and Y.
        A Former User @fcwilt
        @fcwilt I'm going to test the X endstop, and then the Y endstop. Please wait for my report.
        fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          @mac
          I'm not going anywhere.
            A Former User @A Former User
            @fcwilt okay, here are the results: with X endstop pressed down, M119 reports X at min stop. With Y endstop pressed down, M119 reports Y at min stop.
            Interestingly, M119 continues to report Z at min stop even though I'm NOT pressing it down?
              @fcwilt
              M208 X0 Y0 Z0 S1                                   ; set axis minima
              M208 X220 Y220 Z240 S0                             ; set axis maxima
                @fcwilt are the S0 and S1 reversed?
                • fcwiltundefined
                  No they are correct.
                  But, just FYI, there is a simpler form of M208 (at least I think it is simpler)
                  M208 X0:220 Y0:220 Z0:240
                  Notice no S0 or S1.
                  The number before the : character is the min value for the axis specified by the letter.
                  The number after the : character is the max value for the axis specified by the letter.
                  I find it easier to remember "min then max" rather then "is it S0 or S1".
                  That's just me.
                    @fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
                    But I figured it out!
                      @fcwilt so where do these responses put us?
                      • fcwiltundefined
                        We are still need to test the X and Y endstop switches to see what M119 reports when a switch is pressed or not pressed.
                          @fcwilt with X depressed, X is at min stop, everything else is as it has been.
                          With Y depressed, Y is at min stop, everything else is as it has been.
                          A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                            @fcwilt the Z-endstop is still saying it's at the min stop.
                              @fcwilt Z must be wrong, don't you think?
                              • fcwiltundefined
                                Fantastic.
                                So we know the X and Y endstop are working.
                                But the Z is not. It should do the same as the X and Y.
                                Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
                                  @fcwilt
                                  6/27/2022, 9:17:19 AM	M574
                                  Endstop configuration:
                                  X: low end switch connected to pin !io5.in
                                  Y: low end switch connected to pin !io6.in
                                  Z: low end switch connected to pin io2.in
                                    @fcwilt something about that doesn't look right?
                                    • fcwiltundefined
                                      @fcwilt
                                      Great. You getting the hang of this, aren't you!
                                      So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
                                      But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
                                      Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
                                        droftarts administrators @A Former User
                                        @mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
                                          A Former User @droftarts
                                          @droftarts hey's baaaaaaaaaccccccccckkkkkkk
                                          I just moved the white wire on the 5 pin io2 connector from io2_out to io2_in, The green wire is still in the center of the connector / connected to GND.
                                          • fcwiltundefined
                                            Well that certainly should make a difference.
                                            Please run the M119 tests with the Z endstop switch pressed and not pressed.
