    Smart Effector Part Cooling, what's everyone using?
    Smart effector for delta printers
    10
    12
    1.8k
    • NexxCatundefined
      NexxCat
      Pretty much as title.
      I'm currently experementing with different part cooling on my converted Anycubic Predator and would be really interested to hear what people are using on their setups.
      Right now I'm testing a BerdAir setup, but also have some decent 4010 radial fans which I may try.
      Bonus points for linking STL's of your setups ๐Ÿ˜‰
      weed2allundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        I use my own designs using radial fans.
        They are both on thingiverse.
        One is for using the original rods. https://www.thingiverse.com/thing:3603550
        The other is for haydns rods.https://www.thingiverse.com/thing:3768236
        • bartolomeusundefined
          bartolomeus
          This is what I use: https://www.thingiverse.com/thing:2909853
          themelleundefined 1 Reply Last reply Reply Quote 0
          • themelleundefined
            themelle @bartolomeus
            @bartolomeus said in Smart Effector Part Cooling, what's everyone using?:
            I can second that - this is by far the best solution in terms of raw part cooling performance I have come across so far.
            Every other solution I tried did not offer even remotely sufficient part cooling performance.
            That said, my long-term plan is to go for a frame-mounted CPAP blower and a CPAP tube to the effector (see Mark Rehorst's blog at https://drmrehorst.blogspot.com/2018/04/the-mother-of-all-print-cooling-fans.html).
            Might save some weight on the effector and provide ample cooling power.
            kookaburraundefined 1 Reply Last reply Reply Quote 0
            • kookaburraundefined
              kookaburra @themelle
              @themelle did you succeed with the smart effector CPAP design?
              • rjenkinsgbundefined
                rjenkinsgb
                I use this setup from Thingiverse, with the E3D V6 hotend heatsink from the kit, titanium heat break, plated copper block & 0.4mm Olsson ruby nozzle.
                https://www.thingiverse.com/thing:3893311
                That's with a Flex3drive system, so like this on top:
                https://flex3drive.com/product/g5-flex-for-duet-smart-effector/
                The end result is very light but as precise as a direct drive setup.
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                • Fred-Yundefined
                  Fred-Y
                  I have been working on a dual berd air pump setup lately for high speed.
                  One this design the 2 pumps are combined before the pipes, the new version have one pump dedicated to in internal pipes and the other to to external pipes.
                  I'm not an expert on CAD ๐Ÿ˜‘
                  • weed2allundefined
                    weed2all @NexxCat
                    @nexxcat I'm using my own designed fan mount for smart effector
                    https://www.thingiverse.com/thing:3960474
                    https://www.thingiverse.com/weed2all/designs
                    blt3dpundefined 2 Replies Last reply Reply Quote 0
                    • blt3dpundefined
                      blt3dp @weed2all
                      Using my own design as well. Using with Smart Effector v2, Revo, 2x 3010 blower fans and accelerometer.
                      https://cad.onshape.com/documents/08f479c5744e9a5daa711656/w/26ca6233e59d70953ce80476/e/0c329ee272cb5dea67e6660d?renderMode=0&uiState=62bde313f33a9b56662d05db
                      My 3D Printing YouTube Channel
                      Better Living Through 3D Printing
                      Follow me on Instagram and Twitter
                      Instagram
                      Twitter
                      apakundefined 1 Reply Last reply Reply Quote 0
                      • apakundefined
                        apak @blt3dp
                        Iยดve got this
                        https://www.thingiverse.com/thing:4832361
                        • blt3dpundefined
                          blt3dp @weed2all
                          @weed2all said in Smart Effector Part Cooling, what's everyone using?:
                          I like this one, I'd like to see about fitting it to my setup, happen to have the step files?
                          Instagram
                          Twitter
                          • Fred-Yundefined
                            Fred-Y
                            I'm made a new version for the Bred Air pump specifically designed to the Rapido (standard or UHF)
                            It can be downloaded here: https://www.thingiverse.com/thing:5472580
                            This design is not compatible with the Revo as it is shorter, I am working on a new version with the tubes on the side.
