    Smart Effector Part Cooling, what's everyone using?
    Smart effector for delta printers
    10
    12
    1.8k
      jay_s_uk
      I use my own designs using radial fans.
      They are both on thingiverse.
      One is for using the original rods. https://www.thingiverse.com/thing:3603550
      The other is for haydns rods.https://www.thingiverse.com/thing:3768236
      • bartolomeusundefined
        bartolomeus
        This is what I use: https://www.thingiverse.com/thing:2909853
        themelleundefined 1 Reply Last reply Reply Quote 0
        • themelleundefined
          themelle @bartolomeus
          @bartolomeus said in Smart Effector Part Cooling, what's everyone using?:
          I can second that - this is by far the best solution in terms of raw part cooling performance I have come across so far.
          Every other solution I tried did not offer even remotely sufficient part cooling performance.
          That said, my long-term plan is to go for a frame-mounted CPAP blower and a CPAP tube to the effector (see Mark Rehorst's blog at https://drmrehorst.blogspot.com/2018/04/the-mother-of-all-print-cooling-fans.html).
          Might save some weight on the effector and provide ample cooling power.
          kookaburraundefined 1 Reply Last reply Reply Quote 0
          • kookaburraundefined
            kookaburra @themelle
            @themelle did you succeed with the smart effector CPAP design?
            • rjenkinsgbundefined
              rjenkinsgb
              I use this setup from Thingiverse, with the E3D V6 hotend heatsink from the kit, titanium heat break, plated copper block & 0.4mm Olsson ruby nozzle.
              https://www.thingiverse.com/thing:3893311
              That's with a Flex3drive system, so like this on top:
              https://flex3drive.com/product/g5-flex-for-duet-smart-effector/
              The end result is very light but as precise as a direct drive setup.
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              • Fred-Yundefined
                Fred-Y
                I have been working on a dual berd air pump setup lately for high speed.
                One this design the 2 pumps are combined before the pipes, the new version have one pump dedicated to in internal pipes and the other to to external pipes.
                I'm not an expert on CAD 😑
                • weed2allundefined
                  weed2all @NexxCat
                  @nexxcat I'm using my own designed fan mount for smart effector
                  https://www.thingiverse.com/thing:3960474
                  https://www.thingiverse.com/weed2all/designs
                  blt3dpundefined 2 Replies Last reply Reply Quote 0
                  • blt3dpundefined
                    blt3dp @weed2all
                    Using my own design as well. Using with Smart Effector v2, Revo, 2x 3010 blower fans and accelerometer.
                    https://cad.onshape.com/documents/08f479c5744e9a5daa711656/w/26ca6233e59d70953ce80476/e/0c329ee272cb5dea67e6660d?renderMode=0&uiState=62bde313f33a9b56662d05db
                    My 3D Printing YouTube Channel
                    Better Living Through 3D Printing
                    Follow me on Instagram and Twitter
                    Instagram
                    Twitter
                    apakundefined 1 Reply Last reply Reply Quote 0
                    • apakundefined
                      apak @blt3dp
                      I´ve got this
                      https://www.thingiverse.com/thing:4832361
                      • blt3dpundefined
                        blt3dp @weed2all
                        @weed2all said in Smart Effector Part Cooling, what's everyone using?:
                        I like this one, I'd like to see about fitting it to my setup, happen to have the step files?
                        Instagram
                        Twitter
                        • Fred-Yundefined
                          Fred-Y
                          I'm made a new version for the Bred Air pump specifically designed to the Rapido (standard or UHF)
                          It can be downloaded here: https://www.thingiverse.com/thing:5472580
                          This design is not compatible with the Revo as it is shorter, I am working on a new version with the tubes on the side.
