Printer just stopped, can't find the reason
803
    appjaws
    @deckingman thanks, I thought it could have been the SD card so I opened a new 32GB card and copied all the directories and files from the original card to it.
    This didn't make any difference.
    I even tried to enter G1 X10 but nothing happened except the rotation circle busy sign again.
    I have an awful feeling that the processor is damaged , how I don't know, unless it overheated because of the hot weather. I don't want to buy another duet2 untill I am sure that it is damaged and that the dueX5 is OK.
    appjaws - Core XYUV Duet Ethernet Duex5
    firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
    Ormerod 1-converted to laser engraver, Duet wifi
    OpenSCAD version 2024.03.18
    Simplify3D 5.1.2
    undefined undefined 2 Replies Last reply 14 Jul 2022, 21:31 Reply Quote 0
      Are you able to safely test individual motor movement commands using G1 H2 for each axis?
      At this point it would help if you gave some more information about the machine and configuration. I see you have a U and V axis, so your homing files and config.g would be helpful.
      @appjaws said in Printer just stopped, can't find the reason:
      I then issued G1 X100 Y100 and pressed send button but nothing happened, the button just shows the rotating circle.
      This makes me think that there is something preventing the motors from actually moving. Where are the motors physically connected? The Duet or the Duex?
      undefined 1 Reply Last reply 15 Jul 2022, 15:22 Reply Quote 0
        deckingman @appjaws
        @appjaws I have the original Duet Ethernet from my machine that I could lend you. It'll cost you the postage and I'd want it back. Pm or email me if that's any use.
        Edit. I also have the Duex 5 so I could lend them both
          jay_s_uk @appjaws
          @appjaws I also have some refirb duet 2s I'll be selling if you're interested
            appjaws @Phaedrux
            @deckingman Thank you so much for the offer, I am pretty convinced that it is a processor fault, so I will be buying a used Duet2. In the unlikely event that the replacement board doesn't solve the problem, I'll ask you for a loan of your dueX5 so I can confirm the state of mine.
            @deckingman @Phaedrux
            I don't think it is the dueX5 board because I have 3 Z motors connected and they are working as well as the XU, YV and E motors.
            It's almost as if the processor is only handling the first instructions and not releasing for the next set. As an example I ran my auto start macro, the macro started and the first thing it does is the set the bed temperature to 60C, when that is reached it then sets to 65C and the nozzle to 195C. What happened is that the bed reached 60C and then nothing else... very strange. This macro is used daily and is included at the end of this entry FYI.
            I have calibrated the MCU temperature and it now reads about 36 degrees
            Nothing has changed in my config or macro files and bearing in mind that the machine stopped towards the end of a print and the head stayed at the last extruder position instead of moving to the park position at the end of the print, I think it must be the processor at fault.
            Has there been any changes in the firmware since the beta version of 3.4.1 that would require config or macro changes?
            this is the start up macro:-
            ; Conditional Startup Macro
            M98 P"0:/macros/extra/Set LED Red"
            M561 ; clear any existing bed transforms
            T0 ; select first hot end
            M501 ; Load override
            M584 X0:3 Y1:4 Z7:8:9 E2:5:6 P3
            M291 P"Preheating bed and nozzle for accurate probing " R" Conditional Startup Macro " S1 T0; Display message
            if heat.heaters[0].current <=65 && heat.heaters[1].current <=195
            if heat.heaters[0].current <60
            M104 S0 ; Set tool to 0
            M140 S60 ; Set bed temperature to 60
            M116 ; waiting for bed to reach temperature
            M140 S65
            if heat.heaters[0].current >60
            M104 S195 ; Set current tool temperature to 195C
            M116 S3 ; waiting for heaters to reach temperature
            M98 P"0:/macros/Auto Bed Levelling"
            M291 P"Reducing Nozzle heater 120" R"Startup Macro" S1 T0; Display message
            M400 ; Wait for moves to complete
            G92 E0 ; Zero Extruder
            M104 S120 R120 ; Set current tool temperature to 120C
            M98 P"0:/macros/extra/Set LED Green"
            M291 P"Startup Completed " R" Conditional Startup Macro" S1 T5; Display message
            Simplify3D 5.1.2
              Waiting for @DC42 to have a look. I haven't seen a CPU failure like this before. Usually it either works or it's dead.
                dc42 administrators @appjaws
                @Phaedrux thanks for any help, I am at a loss.
                Hope the file has been uploaded this time.
                M122-output.txt
                That output just shows that the last reset was a software reset commanded by you 5 min 21 seconds before you ran M122.
                After the update I homed all XU, YV, Z which worked fine but the homeall button just showed a rotating circle. Eventually that stopped and the button label was correct so I tried my macro auto bed levelling, nothing happened except a rotating circle against the maco entry.
                1. Check that your versions of RRF and DWC are in step.
                2. One reason for the printer doing nothing and DWC showing a wait-circle which goes away after a while is that the motors were unable to move, for example because the Duet had 5V power but not VIN power. Are you using external 5V power?
                  appjaws
                  @dc42 Thank you for your interest.
                  RRF and DWC are in step both at v3.4.1
                  I am not using an external 5V system, The whole system is powered by a 24V supply
                  I can move each motor set XU, YV, Z individually and they move as expected.
                  If I home just the XU then when the moves are finished, I just get the rotating circle on the "HomeX" button and I can't do anything else.
                  It is the same if I Home YV or Z
                  very strange.
                  Simplify3D 5.1.2
                  undefined 1 Reply Last reply 17 Jul 2022, 12:55 Reply Quote 0
                    appjaws @appjaws
                    Just disconnected the boards and have found no signs of burning on the duet or the deuX5.
                    So still baffled by this strange fault.
                    Simplify3D 5.1.2
                      Tinchus
                      I was having some time ago the same exact problem. What I found finally was that for some reason, the gcode file I was uploading thorugh wifi, was being uploaded incomplete. So I started the prints and the print finished when the gcode just ended. Since the endgcode was not there, everything was on: nozzle, bed...
                      To check this: download the file you have on the printer and open in and check if the file is complete..
                      In my case the problem was caused by a bad wifi conection
                      undefined 1 Reply Last reply 18 Jul 2022, 09:47 Reply Quote 0
                        appjaws @Tinchus
                        @tinchus Thank you for the info but I don't think this is my problem, I can't even get the printer setup to do a print. Hopefully another board will arrive today, which I hope will solve the problem.
                        Simplify3D 5.1.2
                        16 out of 17
