    1XD Closed Loop Servo Setup
    41
    2.7k
    • ShaunCroundefined
      ShaunCro @code7
      @code7
      You need to choose whether you going to run high or low on the step/dir.
      So typically you daisy chain the positive from the 5V+ and the have the Negative as the pulse input, so only they get connected to the corresponding pins. ENA is typically left unconnected from the documentation I have read on my drivers.
      I assume your driver also has a 25\26 pin D-Sub interface, if so, you only need to connect up the corresponding wires and leave the rest, as they aren't used in our instance. But, you may need to grab the software from leadshine to change a few parameters and ensure they are funning step/dir and not RS485 for communication.
      Lets just get one thing straight....
      You don't own a Delta! It's true, you don't!
      It owns you!
      ShaunCroundefined 1 Reply Last reply Reply Quote 0
      • ShaunCroundefined
        ShaunCro @ShaunCro
        @shauncro Nope, if I look at my user manual, I need a bit more. Fiddling and will post a bit later what I happen upon. But still getting everything up and running.
        It owns you!
        code7undefined 1 Reply Last reply Reply Quote 0
        • code7undefined
          code7 @ShaunCro
          @shauncro Leadshine contacted me and recommended the Differential Connection option wired as follows:
          I tried this but it tripped the "Motor speed out of control" alarm right away even before sending a G1 command to turn the servo.
          @jay_s_uk I added T5:5:10:10 to the config but I am still receiving the alarm.
          Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
          jay_s_ukundefined alankilianundefined 3 Replies Last reply Reply Quote 0
            jay_s_uk @code7
            @code7 can you share the full datasheet for the driver. Thanks
            • code7undefined
              code7 @jay_s_uk
              @jay_s_uk Here is the full data sheet for the Leadshine ELD2 Driver:
              http://leadshineusa.com/UploadFile/Down/ELD2-RS70-- User Manual_2021_Ver1.09.pdf
              • alankilianundefined
                alankilian @code7
                @code7 said in 1XD Closed Loop Servo Setup:
                Wow, this is a pretty sophisticated servo controller. I'd like to know more about it in case I want to use one like it in the future. Can you share some more information about your setup?
                • What motor do you have connected?
                • What encoder do you have connected?
                • Are you configuring it using the RS232 or RS485 serial connection?
                • Did Leadshine supply you configuration software for a Windows machine?
                There seem to be a lot of things to get right before it's going to move at all, and then tuning the servo controller can get complex, but I think if you go step-by-step you'll get it running.
                I've designed servo controllers in the (long ago) past and have used many different types, so I'll try to help as much as I can.
                  alankilian @code7
                  Page 67 of your manual says this may be caused by:
                  • UVW connection error
                  • Encoder error
                  Do you know that you have the motor U, V and W wires connected to the correct place on the driver?
                  Do you know that the encoder is correctly connected to the driver?
                  Sometimes, the motor has a connector that's perfect and things can't get out-of-order, but I don't know what you've got, so I' apologize if this is a dumb thing for me to ask you.
                  • code7undefined
                    code7 @alankilian
                    @alankilian Thanks for looking into this. The motor is a Leadshine
                    ELDM4010V24HL-B5
                    Here is the response from Leadshine: "Motor speed out of control " this Alarm is from 1XD controller.
                    Please check controller electronic/PPR setting ,make it correspond to servo driver and machine transmission devices.
                    I downloaded the Leadshine software to configure it but am waiting for an RS232 cable to test it out.
                    I'm using the ELD2 Servo controller.
                    alankilianundefined ShaunCroundefined 2 Replies Last reply Reply Quote 0
                      alankilian @code7
                      @code7
                      Here's what I would do: (Step 1 of many)
                      Disconnect the 1XD and connect the motor to the servo controller.
                      Do not connect anything else to the servo.
                      Apply power to the servo drive.
                      What do you get for blinking lights or codes on the servo controller?
                      Send us a photo of the setup.
                      • ShaunCroundefined
                        ShaunCro @code7
                        @code7
                        Hey Code,
                        I have MOVEMENT! But only on the older drivers which are the ACS806
                        Here's my config
                        I changed my 1XD to address 20 so configure for your address
                        M569 P20.0 S1 R0 T5:5:5:5                    ; physical drive 20.0 goes forwards
                        M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                        M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                        M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                        M584 X20.0 Y0.0 Z0.1 E0.3                          ; set drive mapping
                        M350 X16 I0                                       ; configure microstepping without interpolation
                        M350 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E420.00                ; set steps per mm
                        M566 X6000.00 Y6000.00 Z60.00 E120.00              ; set maximum instantaneous speed changes (mm/min)
                        M203 X120000.00 Y120000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
                        M201 X12000.00 Y12000.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
                        M906 Y300 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                            ; Set idle timeout
                        M208 X0 Y0 Z0 S1                                   ; set axis minima
                        M208 X450 Y450 Z450 S0                             ; set axis maxima
                        M950 J4 C"!^20.io0.in" ; create input pin number 4 on 1XD board at CAN address 20 for servo alarm. The alarm is active low so invert the input and enable the pullup to prevent spurious alarms caused by noise
                        M950 P5 C"20.io0.out" ; create a GPIO pin number 5 on 1XD board at CAN address 20 for alarm reset
                        M574 X1 J4 S2                                   ; configure sensorless endstop for low end on X
                        M574 Y1 S3                                       ; configure sensorless endstop for low end on Y
                        M574 Z1 S2                                       ; configure Z-probe endstop for low end on Z
                        M581 P4 S0 T3 R1 	 ; invoke trigger 3 when an active-to-inactive edge is detected on input 4 and a file is being printed from SD card
                        This is still testing, so treat as test code. I'm still discovering, I do have to edit the Gear Numerator and Gear Denominator on the driver it self, which means you need your cable, I also had to set a few things in the driver for it to work, not sure what yours will be but here is a pic of what I set to get a few bits of rotation. I need to figure out what the gear denominator and numerator role play in this, also, I need to play with the timing in the config, but hey, it moves with no errors. So I'm chuffed for now.
                        Wiring for this driver is very different than the eld5 I have, but, I needed the alarm+ and Alarm- connected to IO0.0 out with inverted and pulled up,
                        Then all the dir+/- Pul+/- and Ena+/- to their corresponding pins, and my settings in the software for the driver are this
                        I must say that the driver software for the ACS series of drivers is pure K@K. Nothing under the motor parameters saves. And It seems no one in leadshine believes in firmware updates 😐
                        Will post as I figure out stuff hopefully to help.
                        It owns you!
                        • ShaunCroundefined
                          ShaunCro @ShaunCro
                          @shauncro I see my enable motor in the pic is active high, this should be set to low.
                          But what I find weird, is I only get movement for a 1/4 of the motor, so 50mm to -250mm if I disable motors and turn it to the next pole, I can move with in that pole, but the numbers are different. 50-350 etc currently have my Gear numerator set 1:1 with the denominator. Motor movement is slow though.
                          It owns you!
                          • code7undefined
                            code7 @ShaunCro
                            @alankilian Thanks for double checking. Everything is connected properly.
                            With everything connected or disconnected I am still receiving the blinking green light with no errors. I'm going to try a simpler motor/driver for now and I may come back to the Leadshine system later.
                            @shauncro Thanks for the details. I tested your config.g and servo driver settings with my Leadshine setup and am not getting any movement. If I come back to this setup and have success I'll let you know.
                            alankilianundefined 2 Replies Last reply Reply Quote 0
                              alankilian @code7
                              If you want to send one motor driver and one motor to me I'll hook it up and getting working for you and send it back. No charge for postage or anything.
                              I only have a Duet2, but getting it working on that system will certainly get it working on your system also.
                              I've done this for other people in the past and have had success.
                              I'm in Cambridge, MA so you can estimate postage.
                              Let me know if you want to try this to get you a jumpstart on getting this working.
                              • code7undefined
                                code7
                                That's really kind @alankilian. I'll let you know if I decide to try this again.
                                  alankilian @code7
                                  @code7 OK, I've got your system setup on my bench.
                                  I can connect using the Leadshine software on a Windows-10 computer using a USB-to-RS232 and your cable and I can read values from the stepper driver and I can command motion and the motor turns.
                                  I also hooked up a pulse-generator and I can enable the stepper driver and the motor turns when I generate step signals.
                                  So...... I don't have a Duet-3 so I can't hook up the 1XD board you sent, but I'll hook up my Duet2 and see if I can get the motor to move using GCODE from the Duet2.
                                    alankilian @code7
                                    @code7 I now have the Duet controlling the stepper motor through axis U driver 5 step/direction outputs.
                                    I'll go back through this thread and see what I have hooked up differently than you did.
                                    I really just hooked:
                                    • Hooked PUL+ to Duet2 Step
                                    • Hooked PUL- to Duet2 Ground
                                    • Hooked DIR+ to Duet2 Direction
                                    • Hooked DIR-- to Duet2 Ground
                                    • Hooked ENA to Leadshine ground
                                    • Hooked the COM+ to leadshine 24 Volts DC
                                    I'll read some more and get back to you.
                                      alankilian @code7
                                      The blinking green light means the Leadshine motor driver is not enabled.
                                      The green light needs to be solid on when the driver is enabled.
                                      You absolutely must NOT connect EN+ to COM-IN since COM-IN is between 24 and 70 Volts! You might have dodged a smoke-event because you may not have had a common ground between the 1XD and the Leadshine power supply.
                                      I'll look in to how to hook up the enable properly and write again.
                                      • cosengundefined
                                        coseng
                                        I know you may have different hardware, but I have 2 Clearpath SDSK servo/steppers running from Duet step and direction outputs and they are providing awesome acceleration, no vibration and near zero noise at any speed.
                                        They are a bit expensive and the specs are quite overkill, but they are highly recommended.
                                        Chris
                                        Cosentino Engineering
                                        • code7undefined
                                          code7 @alankilian
                                          @alankilian Thanks for the update. Is there any other straightforward way to test the LeadShine encoder on the Duet2 or would you need a Duet3?
                                          • code7undefined
                                            code7 @coseng
                                            @coseng said in 1XD Closed Loop Servo Setup:
                                            They
                                            Thanks - I'll keep this in mind for future projects.
