    Issues with pressure advance since RRF 3.4
    308
    37.9k
      dc42 administrators @Argo
      @argo this is close to the top of my list to look into. What's a good print to test this on - is a hollow square tube sufficient?
      Argoundefined 1 Reply Last reply Reply Quote 0
      • Argoundefined
        Argo @dc42
        You could just create a shape box in Prusa Slicer (or similar slicer that can generate shapes) with the following measurements:
        X: 50mm
        y: 20mm
        Z: 5mm
        Perimeters: 3
        Top Layer: 0
        Bottom Layer: 4
        Infill: Grid 20%
        Layer time goal: 0s (so it does not slow down the print)
        My speed settings: https://forum.duet3d.com/post/288649
        If you are using a direct drive extruder with PLA a PA value around 0.055 is usually a good value.
        I would not print it hollow so you can compare the quality of infill lines and corners.
        The issue I'm having is healthy infill lines and bulging corners or sharp(ish) corners but starving infill lines (example in this posting: https://forum.duet3d.com/post/288686).
          I confirm there is an issue with pressure advance in RRF 3.4. It works better in 3.3 but I think it is still not quite right. We'll issue another 3.4.2rc release when we have fixed it.
          1 Reply Last reply Reply Quote 6
            Further to my previous message: I made a mistake in my test program. Currently I can't see any difference in how PA behaves between 3.3 and 3.4 with input shaping disabled. I will investigate further next week.
            ctilley79undefined 1 Reply Last reply Reply Quote 1
            • ctilley79undefined
              ctilley79 @dc42
              @dc42 Try it with input shaping enabled. A problem people are having is tuning PA after enabling IS.
                dc42 administrators @ctilley79
                @ctilley79 before I look into the interaction of IS and PA, I need to understand why some users are reporting that even with IS disabled, PA behaves differently in 3.4 compared to 3.3.
                petriheinoundefined 1 Reply Last reply Reply Quote 2
                • petriheinoundefined
                  petriheino @dc42
                  @dc42 Could you share any of your test methods? Im currently just plotting step/dir signal outputs.
                  • michaelr123undefined
                    michaelr123
                    I've been debating whether or not to comment on this thread for weeks as I'm hesitant to blame PA for the print artifacts I've been seeing, but after a lot of testing it seems to be the culprit. It's possibly I'm still getting through some acceleration/jerk tuning stuff or I still need to play with belt tension and/or IS. However, since going from 3.3 to 3.4 on my voron 2.4 build with a Duet wifi 2, I have been seeing odd bulging behaviors on roundish perimeters, or with embossed text. I can post some pictures later of some examples. I sometimes see sections that are supposed to be straight end up with a gentle concave curve.
                    Again, it could be that I'm just new to tuning Core XY systems, or my external stepper driver setup not being super robust, or something else entirely, but it feels like I've spent a lot of time working out print artifacts on this machine to get close to what I'd consider a perfect FDM part.
                      dc42 administrators @michaelr123
                      @michaelr123 I am interesting in seeing any differences in the effects of pressure advance between RRF 3.3 and RRF 3.4.x with input shaping not used. [There is a separate discussion on the interaction of PA with IS.] Ideally with a quick-to-print example (e.g. just a few layers high) that demonstrates the difference.
                      michaelr123undefined Phaedruxundefined Argoundefined 3 Replies Last reply Reply Quote 0
                        michaelr123 @dc42
                        @dc42 totally understand, we need to narrow down whether it's 3.3 to 3.4 that causes issues for PA specifically. I think my comments are more along the lines of it's been tricky to tune a coreXY on 3.4 so far. I need to try rolling back to 3.3 yet as I've been on 3.4 for awhile now.
                          Phaedrux Moderator @dc42
                          @dc42 said in Issues with pressure advance since RRF 3.4:
                          I notice the difference with a simple hollow cube with 2mm thick walls. The corners bulge more in 3.4 and the extruder sounds different. I had to lower e jerk to prevent gaps and reduce the noise. e jerk went from 3000 to 1500. PA only 0.025.
                          • Argoundefined
                            Argo @dc42
                            Now things are getting complicated.
                            I have another printer which is a Bear Bondtech Mk3 bedslinger (originally was a Prusa Mk3s).
                            When I compare corners with RRF3.3 to RRF 3.4 there are hardly any differences. RRF 3.3 is a bit better but RRF 3.4 is not as worse as my previous results with the CoreXY (Voron 2.4) machine.
                            So what's different between those two printers.
                            The printer (Voron 2.4) having difficulties with bulging corners and RRF 3.4 differs in three things compared to the Bear Mk3:
                            • it's a Core XY machine
                            • prints perimeter double the speed
                            • uses a Duet 1LC toolboard V1.2
                            Maybe this helps somehow...
                              @argo it's entirely possible that there could be a bug that affects PA when the extruder is driven by a CAN-connected expansion board that is not present when it is driven by the main board, because different code is used. I will do some more tests with the extruder driven by a tool board.
                              Yesterday I did comparative tests between 3.3 and 3.4 using 120mm/sec perimeters, 160mm/sec infill and PA 0.4. The results were very similar. Extruder was driven from the Duet 3 Mini.
                              • Argoundefined
                                Argo @dc42
                                I bet your to-do list is quite full and time is limited but when you find the bug and did a possible fix to the firmware feel free to upload the compiled firmware for me/us for testing.
                                I've seen you did this before and uploaded the files to a Dropbox folder.
                                Argoundefined 1 Reply Last reply Reply Quote -1
                                • Argoundefined
                                  Argo @Argo
                                  Results are still unchanged with RRF 3.4.2rc2.
                                  PLA, PA set to 0.057:
                                    @argo please can you provide a small GCode print file that demonstrates the issue, along with the config.g file for the machine concerned, and details of the extruder (especially the length of the Bowden tube). A print file that does the print in the photo you posted above (and stops after a few layers as in the photo) would be suitable.
                                    • Argoundefined
                                      Argo @dc42
                                      Yes, sure.
                                      Extruder is a LGX (not the lite version) with a Rapido HF Hotend.
                                      The bowden tube length between the extruder gears and the hotend is about 15-20mm long.
                                      Printer: Voron 2.4 - 300mm
                                      Photo of the printer:
                                      Config.g:
                                      G4 S1        ; wait 1s for expansion boards to start
                                      G90                                         ; Send absolute coordinates...
                                      M83                                         ; ...but relative extruder moves
                                      M550 P"Walross"                        	; Set machine name
                                      M552 S1                                     	; Enable network
                                      ;*** Access point is configured manually via M587
                                      M586 P0 S1                                  ; Enable HTTP
                                      M586 P1 S1                                  ; Disable FTP
                                      M586 P2 S1                                  ; Disable Telnet
                                      M575 P1 S1 B57600							; Panel Due
                                      ; Printer geometry
                                      M669 K1                	                    ; Select CoreXY mode
                                      M208 X0:290 Y-3:300 Z-0.2:270              ; Axis Limits
                                      M564 H0							            ; allow unhomed movement
                                      ;------- drives from top---------------------------------------------------
                                      ;  B -------+------ A
                                      ;   | P.02 | P.03 |
                                      ;   -------+-------  Z-Drives
                                      ;   | P0.1 | P0.4 |
                                      ;        Front
                                      ; Drive Mappings
                                      M569 P121.0 S0 D2                             ; Drive 0: E Axis
                                      M569 P0.1 S1 D2                             ; Drive 1: Z-LeftFront Axis
                                      M569 P0.2 S0 D2                             ; Drive 2: Z-LeftRear Axis
                                      M569 P0.3 S1 D2                             ; Drive 3: Z-RightRear Axis
                                      M569 P0.4 S0 D2                             ; Drive 4: Z-RightFront Axis
                                      M569 P0.5 S1 D2                             ; Drive 5: Expansion: B motor (X-axis)
                                      M569 P0.6 S0 D2                             ; Drive 6: Expansion: A motor (Y-axis)
                                      ; Motor remapping for dual Z and axis Limits
                                      M584 X5 Y6 Z1:2:3:4 E121.0                              ; Motor mapping
                                      M671 X-60:-60:360:360 Y-10:370:370:-10 S20	        ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front
                                      ; Microstepping and Speed
                                      M350 X32 Y32 E16 Z32 I1                     ; Configure microstepping with interpolation
                                      M92 X160.00 Y160.00 Z800.00 E400.00         ; Set steps per mm	1.8 motors
                                      ; Speeds, Acceleration and Jerk
                                      M566 X300.00 Y300.00 Z25.00 E400.00 P1          ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X24000.00 Y24000.00 Z900.00 E1200.00       ; Set maximum speeds (mm/min) ; SpreadCycle
                                      M201 X5000.00 Y5000.00 Z1000.00 E5500.00        ; Set accelerations (mm/s^2) ; SpreadCycle
                                      ; Motor currents
                                      M906 X1250.00 Y1250.00 Z1100.00 E700.00 I55        ; Set motor currents (mA) and motor idle factor in percent
                                      M84 S30                                            ; Set idle timeout
                                      ; Endstops for each Axis
                                      M574 X2 S1 P"io1.in" 				; Set X endstop controlled by switch
                                      M574 Y2 S1 P"io2.in"                      	; Set Y endstop controlled by switch
                                      M574 Z1 S2                                           ; Set endstops controlled by probe "OLD" VINDA
                                      ;M574 Z1 S1 P"io6.in"						; Z endstop switch
                                      ; Stallgaurd Sensitivy (maybe use to pause print after crash)
                                      M915 X S2 F0 H200 R0		                ; Set X axis Sensitivity  1.8 motors
                                      M915 Y S2 F0 H200 R0		                ; Set y axis Sensitivity  1.8 motors
                                      ; Input Shaper and Accelerometer
                                      ;M955 P121.0 I05 ;Accelerometer
                                      ;M593 P"zvdd" F46 S0.05
                                      M558 P8 C"121.io2.in" I1 H2 F250:100 T6000 A500 S0.0025	; VINDA
                                      ; Mesh Grid
                                      M557 X5:260 Y30:250 P7                         ;
                                      ; Z Probe Offset (Probe behind Afterburner)
                                      ;G31 P1000 X0 Y25 Z1.095	; VINDA - 3Djake Nano
                                      G31 P1000 X0 Y25 Z0.770		; VINDA - 3DSWay Textured
                                      ; Filament Runout sensor
                                      M591 D0 P3 L25.95 E3 R10:250 C"121.io1.in" S1		 		; Filament Sensor
                                      ; Heatbed Heaters and Thermistor Bed
                                      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Heatbed Thermistor
                                      M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater (SSR)
                                      M307 H0 R0.889 K0.762:0.000 D3.02 E1.35 S0.6 B0
                                      M140 H0										                    ; Bed uses Heater 0
                                      M143 H0 S116                                                    ; Set temperature limit for heater 0 to 115C Bed
                                      ; HotEnd Heaters and Thermistor HotEnd
                                      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8     	; define E0 temperature sensor
                                      M950 H1 C"121.out0" T1 Q100					                            ; Create HotEnd Heater
                                      M307 H1 R4.568 K0.683:0.000 D4.04 E1.35 S1.00 B0 V24.4				; PID as heater
                                      M143 H1 S295                                                    	; Set temperature limit for heater 1 to 285C HotEnd
                                      M302 S15 R15														; min extrusion (cold extrusion) temp
                                      ; Fans Hotend + Part
                                      M950 F3 C"121.out1" Q100				; Creates HOTEND Fan
                                      M106 P3 T65 L1.0 X1.0 H1                 ; HOTEND Fan Settings
                                      M950 F0 C"121.out2" Q100				; Creates PARTS COOLING FAN
                                      M106 P0 H-1                         ; Parts Cooling Fan
                                      ; Fans Electronic compartment & Exhaust
                                      M950 F1 C"out3" Q100				    ; Creates Case Fan 1
                                      M106 P1 T40 S170 L170 X170 H0                 ; Case Fan 1 Settings
                                      M950 F2 C"out4" Q100				    ; Creates Case Fan 2
                                      M106 P2 T40 S170 L170 X170  H0                  ; Case Fan 2 Settings
                                      M950 F5 C"out5" Q100				    ; Creates Exhaust Fan
                                      M106 P5 T82 S150 L150 X150 H0                  ; Exhaust fan
                                      ; Chamber Thermistor
                                      M308 S3 P"temp1" A"Chamber" Y"thermistor" T100000 B4725 C7.060000e-8     	; define chamber sensor
                                      M563 P0 D0 H1 F0                            ; Define tool 0
                                      G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
                                      G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
                                      And the generated gcode and stl file (print time 9 min max):
                                      Test.gcode
                                      TEST.stl
                                      Argoundefined 1 Reply Last reply Reply Quote 1
                                      • Argoundefined
                                        Argo @Argo
                                        I did a esteps calibration today to rule out any extruder calibration issues.
                                        Though Bondtech states it's not necessary, I wanted to be sure that esteps are spot on.
                                        Turns out esteps are within 1-2% accuracy. So the extruder does work as intended.
                                        What else should I (double) check to rule out hardware issues? I mean, only 3 people so far in this thread confirmed PA issues out of 1000+(?) RRF users. That is peculiar.
                                        Viscoelasticundefined 1 Reply Last reply Reply Quote 0
                                        • Viscoelasticundefined
                                          Viscoelastic @Argo
                                          @argo I have been meaning to do a test between the two firmware versions for a few weeks now and finally got a chance to do so on the weekend.
                                          I have two identical cartesian bedslinger machines both running everything directly off a MB6HC with SBC. One is running on version 3.3 and the other is running on version 3.4.0. I am not presently using input shaping. Both machines have direct drive Titan Aqua extruders.
                                          I printed a 50mm single outline square with a 1mm gap in one side, so that I can measure line starts and ends as well as seeing what happens at the corners of the print. I used a PA setting of 0.055 using ABS at a print speed of 45mm/s for both machines and a retraction of 0.4mm.
                                          I did not see a difference between the two firmware versions, either at the corners or at line starts or ends. This was determined by measuring the difference in thickness at line starts and ends as well as the first corner vs the thickness midspan between the line start and the first corner. In each case I measured the same difference.
                                          Based on some of your earlier comments and those from @dc42 it seems therefore that this problem may be confined to systems running with an attached tool board. Did you see any difference in printing when both machines were running on version 3.3 firmware? If not, then you can pretty much eliminate the mechanical hardware difference between the two machines as a cause of the problem.
                                          • Argoundefined
                                            Argo @Viscoelastic
                                            @viscoelastic
                                            Thanks for testing as well.
                                            My bed slinger is not affected by this issue. RRF 3.3 and 3.4 look identical, though I find with RRF 3.4 and enabled input shapers, PA can’t be tuned to get as sharp corners as with 3.3.
                                            As with the CoreXY machine (+Duet 1LC and Bondtech LGX extruder) RRF 3.3 does look better than RRF 3.4 (both disabled IS). But even the RRF 3.3 results with this machine do not look as good as with the bed slinger.
                                            I can’t remember I was having PA issues with this machine in the past. Only thing that changed was the Duet 1LC. And I don’t know what hardware issue may cause this as its only affecting corners and not infill lines.
